供应0.18寸-0.73寸MicroLED模组,也可以接受客制化MicroLED模组。
欢迎联系:13538284956(电话微信同号),杨生。
Screen Diagonal 0.18inch
FWHM(nm) 30±5nm
Pixel Pitch(um) 12.5umx12.5um
LED chip size(um) 9.5umx9.5um
LED Gap space(um) 3umx3um
Resolution 320X140
Active Area(mm X mm) 4x1.75(0.18inch)
Driver Panel Size(mm X mm) "4.75x2.7
(0.22inch)"
Gray Levels 15
Gray Level control PWM
frame Rate(Hz) 60HZ
Max Panel Current(mA) 110mA
LED Voltage drop(V) 3
Max Power Input(mW) 350mW
Working Current density(A/cm2) 70A/cm2
Backplane Driving mode Digital
显示比例 16:7
13538284956,杨磊
