森利威尔针对120V DC降压产品、电动车USB芯片参数120V降压12V电流1A专门设计了一款PWM控制芯片SL3036H,Recently, senliwell micro has specially designed a PWM control chip SL3036H for 120V DC step-down products and electric vehicle USB chip parameters 120V step-down 12V current 1a,SL3036H 是一款支持宽电压输入的开关降压型DC-DC,芯片内置150V/3A功率MOS,最高输入电压可超过120V。SL3036H 具有低待机功耗、高效率、低纹波、优异的母线电压调整率和负载调整率等特性。支持大电流输出,输出电流可高达1.5A 以上。SL3036H内部集成软启动以及过温保护电路,输出短路保护,限流保护等功能,提高系统可靠性。120V降压12V电流1A非常适合应用在电动车USB上
功率参数:
+-宽输入电压范围:8V~120V
+-输出电压从4.2V 到30V 可调
+-支持输出恒压恒流
+-支持输出12V/1.5A,5V/1.5A
+-高效率:可高达95%
+-工作频率:140KHz
+-低待机功耗
+-良好的线路和负载调节
+-内置软启动
+-内置保护:内置过温保护、输出短路保护、内置软启动
+-提供ESOP-8封装
![SL3036H.jpg SL3036H.jpg](https://static.assets-stash.eet-china.com/forum/202206/29/092438ogl9my1sf3g03rdl.jpg)
![QQ截图20220627142717.png QQ截图20220627142717.png](https://static.assets-stash.eet-china.com/forum/202206/29/092541qn0j0ujrxuji3m4n.png)
