Zhenbang micro technology has newly launched a 90V step-down 12V structure diagram of ah5511 intelligent device. The ah5511 has a wide input voltage range of 7v-150v, and the output voltage can be modulated
AH5511是一款4管制的升降压控制器,高效率同步控制,10A大功率升降压芯片,无线充电,接收端线圈整流后的电压有个范围,65-100V之间,但最高电压能到150V左右,用buck做恒压恒流电路54V/3A给电池充电,需要一个65V-150V输出54V3A的同步降压控制器方案,(A 65v-150v output 54v3a Synchronous Step-Down Controller is required),
AH5511智能设备90V降压12V结构图同步高效率可高达95%{Ah5511 intelligent device 90V step-down 12V structure diagram synchronous efficiency can be as high as 95%}
AH5511是一颗开关可做升降压模式的电源管理芯片,(Ah5511 is a power management chip whose switch can be used for voltage rise and fall mode)内部集成基准电源,欠压保护、过温保护、支持蓄电池充电、具有输出短路保护,是电源设备的最佳选择芯片,
AH5511可用于移动储能设备、电动自行车控制器,便携式移动设备、逆变器系统等多方面产品上,电动自行车100V降压方案 AH5511智能设备90V降压结构图,150V高电压降压的管理芯片
