Looking for a high-performance networking solution that can meet the demands of your smart home or enterprise environment? Look no further than the Qualcomm Atheros IPQ8072A.
Featuring advanced Wi-Fi 6E technology, the IPQ8072A provides faster speeds, greater capacity, and improved reliability, making it the perfect solution for the most demanding networking applications. With a maximum speed of up to 4.8 Gbps and support for up to 12 spatial streams, the IPQ8072A delivers outstanding performance that can keep up with even the most data-intensive applications.
In addition to its impressive speed, the IPQ8072A also boasts advanced security features, including WPA3 encryption, to ensure that your network stays secure and protected. Plus, with Qualcomm's advanced network processing technology, you can be sure that your network will run smoothly and efficiently, even with multiple devices connected simultaneously.
So whether you're looking to upgrade your home network or build out a robust enterprise environment, the Qualcomm Atheros IPQ8072A is the perfect choice for high-performance networking.
Below is the router board -DR8072A on-board Qualcomm Atheros IPQ8072A AR Quad Core CPU.
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate 8 MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 802.11ac TX Beamforming
■ Support 802.11ac/802.11ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz ) + 4x4/2.4GHz
■ Supports Dynamic Frequency Selection (DFS
Symbol | Parameter |
CPU | Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU |
CPU Frequency | Derived from Qualcomm Atheros AP.HK09 |
System Memory | 1x 512MB, DDR4 2400MHz 16-bit interface |
Frequency Range | 2.412~2.472GHz, 5.150~5.825GHz |
MiniPCIe Slot | 1x MiniPCIe Slot with PCIe 3.0 |
Modulation Techniques | OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM |
Environmental Temperature | Operating: -20ºC to 70ºC, Storage: -40ºC to 90ºC |
Flash | NOR Flash: 8 MB NAND Flash: 256MB |
Wireless | On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 17dBm per chain On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 17dBm per chain 8x U.FL Connectors |
Reset Buttons | 1x S/W Reset Button |
DC Jack Input | 1x DC Jack Connector: 12V |
Interface | 4x 1Gbps Ethernet Port, 2x 2.5Gbps Ethernet Port 2x USB 3.0 Port 1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector |
LED | 2x RGB LED Indicators |
Power Consumption | TBD |
Wallys Communications (SuZhou) Co., Ltd., http://www.wallystech.com,which is mainly engaged in the research and development and production of wireless communication products,providing superior OEM/ODM/JDM services in wireless communications and customer-specific solution.In addition to the PCBA mainboard, we can also customize indoor or outdoor antennas, which we have extensive experience in. There is also the Tooling. We can do the Tooling for the customer, to undertake a variety of materials
mainly metal and plastic enclosure production. Whether antenna enclosure or router enclosure, we can customize for you. Besides of the Qualcomm chips we currently use, we can also use different chips to design according to customers' needs
MAIL:sales3@wallystech.com
WEB:https://www.wallystech.com/
