M37XX系列直径15至135mm,50至6400N,0.5至320Nm,是矩阵解耦型6轴力传感器。M3701的直径15mm,厚度14mm,是全球商业化六轴力传感器。M37XX系列非线性、迟滞小于0.5%F.S,串扰小于2%F.S。3倍过载能力。传感器标定报告中会提供一个 6X6 的解耦矩阵。信号放大器M830X系列和数据采集卡M812X系列可用于信号调理和采集。放大器或采集卡也可内置于传感器中。
防护等级IP60,可选IP68(10m水深) 。模型号末尾加字母“P”表示IP68防护等(e.g.M3716BP)。
型号 | 描述 | 量程范围(N/Nm) | 尺寸(mm) | 重量 (kg) | |||||
FX,FY | FZ | MX,MY | MZ | OD | Height | ID | |||
M3701A | SIX AXIS CIRCULAR LOAD CELL D15MM F50N | 50 | 100 | 0.5 | 0.5 | 15 | 14 | 4.4 | 0.01 |
M3701B | SIX AXIS CIRCULAR LOAD CELL, COUPLED D15MM F100N | 100 | 200 | 1 | 1 | 15 | 14 | 4.4 | 0.01 |
M3701C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D15MM F200N | 200 | 400 | 2 | 2 | 15 | 14 | 4.4 | 0.01 |
M3702A | SIX AXIS CIRCULAR LOAD CELL, COUPLED D21MM F50N | 50 | 100 | 0.75 | 0.75 | 21 | 17 | 5.4 | 0.01 |
M3702B | SIX AXIS CIRCULAR LOAD CELL, COUPLED D21MM F100N | 100 | 200 | 1.5 | 1.5 | 21 | 17 | 5.4 | 0.01 |
M3702C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D21MM F200N | 200 | 400 | 3 | 3 | 21 | 17 | 5.4 | 0.01 |
M3702C1 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D21MM F200N | 200 | 400 | 3 | 3 | 21 | 17 | * | 0.01 |
M3712A | SIX AXIS CIRCULAR LOAD CELL, COUPLED D21MM F400N | 400 | 800 | 6 | 6 | 21 | 17 | 5.4 | 0.02 |
M3712A1 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D21MM F400N | 400 | 800 | 6 | 6 | 21 | 17 | 5.4 | 0.02 |
M3712B | SIX AXIS CIRCULAR LOAD CELL, COUPLED D21MM F800N | 800 | 1600 | 12 | 12 | 21 | 17 | 5.4 | 0.02 |
M3722C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D30MM F1600N | 1600 | 3200 | 40 | 40 | 30 | 23 | 6 | 0.07 |
M3733C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D35MM F120N | 120 | 200 | 5 | 5 | 35 | 19 | 7 | 0.04 |
M3703A | SIX AXIS CIRCULAR LOAD CELL, COUPLED D45MM F50N | 50 | 100 | 1.75 | 1.75 | 45 | 19 | 17 | 0.04 |
M3703B | SIX AXIS CIRCULAR LOAD CELL, COUPLED D45MM F100N | 100 | 200 | 3.5 | 3.5 | 45 | 19 | 17 | 0.04 |
M3703B2 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D45MM F100N | 100 | 200 | 5.0 | 5.0 | 45 | 19 | 17 | 0.043 |
M3703C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D45MM F200N | 200 | 400 | 7 | 7 | 45 | 19 | 17 | 0.04 |
M3713A | SIX AXIS CIRCULAR LOAD CELL, COUPLED D45MM F400N | 400 | 800 | 14 | 14 | 45 | 19 | 17 | 0.106 |
M3713B | SIX AXIS CIRCULAR LOAD CELL, COUPLED D45MM F800N | 800 | 1600 | 28 | 28 | 45 | 19 | 17 | 0.106 |
M3713C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D45MM F1600N | 1600 | 3200 | 56 | 56 | 45 | 19 | 17 | 0.11 |
M3713D | SIX AXIS CIRCULAR LOAD CELL, COUPLED D45MM F3200N | 3200 | 6400 | 112 | 112 | 45 | 19 | 17 | 0.11 |
M3704B | SIX AXIS CIRCULAR LOAD CELL, COUPLED D70MM F100N | 100 | 200 | 5.5 | 5.5 | 70 | 23 | 30 | 0.12 |
M3704C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D70MM F200N | 200 | 400 | 11 | 11 | 70 | 23 | 30 | 0.12 |
M3704C1 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D70MM F200N | 200 | 400 | 11 | 11 | 70 | 23 | 30 | 0.12 |
M3704CP | SIX AXIS CIRCULAR LOAD CELL, COUPLED D70MM F200N IP68 | 200 | 400 | 11 | 11 | 70 | 23 | 30 | 0.12 |
M3704S | SIX AXIS LOAD CELL, COUPLED 52×57MM F200N | 200 | 400 | 8 | 8 | 47 | 27 | * | 0.1 |
M3714A | SIX AXIS CIRCULAR LOAD CELL, COUPLED D70MM F400N | 400 | 800 | 22 | 22 | 70 | 23 | 30 | 0.29 |
M3714B | SIX AXIS CIRCULAR LOAD CELL, COUPLED D70MM F800N | 800 | 1600 | 44 | 44 | 70 | 23 | 30 | 0.29 |
M3714B1 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D70MM F900N, W/DAS & CAN BUS | 900 | 1800 | 50 | 50 | 70 | 23 | * | 0.32 |
M3714B3 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D70MM F900N, W/DAS & CAN BUS | 900 | 1800 | 100 | 100 | 70 | 23 | * | 0.32 |
M3714B4 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D60MM F900N, W/DAS & CAN BUS | 900 | 1800 | 100 | 100 | 60 | 23 | * | 0.32 |
M3714C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D70MM F1600N | 1600 | 3200 | 88 | 88 | 70 | 23 | 30 | 0.29 |
M3714C2 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D70MM F1600N, W/DAS & CAN BUS | 1600 | 3200 | 88 | 88 | 70 | 23 | * | 0.31 |
M3725A | SIX AXIS CIRCULAR LOAD CELL, COUPLED D88MM F200N, WITH DAS | 200 | 400 | 50 | 50 | 88 | 20 | 13 | 0.54 |
M3705B | SIX AXIS CIRCULAR LOAD CELL, COUPLED D90MM F100N | 100 | 200 | 7 | 7 | 90 | 23 | 45 | 0.18 |
M3705C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D90MM F200N | 200 | 400 | 14 | 14 | 90 | 23 | 45 | 0.175 |
M3705C7 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D90MM F200N | 200 | 400 | 14 | 14 | 90 | 23 | 45 | 0.175 |
M3715A | SIX AXIS CIRCULAR LOAD CELL, COUPLED D90MM F400N | 400 | 800 | 28 | 28 | 90 | 23 | 45 | 0.445 |
M3715B | SIX AXIS CIRCULAR LOAD CELL, COUPLED D90MM F800N | 800 | 1600 | 56 | 56 | 90 | 23 | * | 0.445 |
M3715BT1 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F3200N | 800 | 1600 | 56 | 56 | 90 | 23 | * | 1.0 |
M3715C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D90M F1600N | 1600 | 3200 | 112 | 112 | 90 | 23 | 45 | 0.445 |
M3715CT1 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D90MM F1600N, DIGITAL OUT | 1600 | 3200 | 112 | 112 | 90 | 23 | * | 1.0 |
M3715D | SIX AXIS CIRCULAR LOAD CELL, COUPLED D90MM F3200N | 3200 | 6400 | 224 | 224 | 90 | 23 | 45 | 0.445 |
M3715D1 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D90MM F3200N | 3200 | 6400 | 224 | 224 | 90 | 23 | 45 | 0.445 |
M3706B | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F100N | 100 | 200 | 10 | 10 | 135 | 25 | 80 | 0.39 |
M3706C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F200N | 200 | 400 | 20 | 20 | 135 | 25 | 80 | 0.39 |
M3706C2 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F200N | 200 | 400 | 20 | 20 | 135 | 25 | 80 | 0.39 |
M3716A | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F400N | 400 | 800 | 40 | 40 | 135 | 25 | 80 | 1.00 |
M3716AT1 | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F400N, DIGITAL OUT | 400 | 800 | 40 | 40 | 135 | 25 | 80 | 1.00 |
M3716AP | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F200N, IP68 | 400 | 800 | 40 | 40 | 135 | 25 | 80 | 1.00 |
M3716B | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F400N | 800 | 1600 | 80 | 80 | 135 | 25 | 80 | 1.00 |
M3716BP | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F400N, IP68 | 800 | 1600 | 80 | 80 | 135 | 25 | 80 | 1.00 |
M3716C | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F1600N | 1600 | 3200 | 160 | 160 | 135 | 25 | 80 | 1.00 |
M3716CR | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F1600N, DIGITAL OUT | 1600 | 3200 | 160 | 160 | 135 | 25 | * | 1.0 |
M3716D | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F3200N | 3200 | 6400 | 320 | 320 | 135 | 25 | 80 | 1.0 |
M3716DR | SIX AXIS CIRCULAR LOAD CELL, COUPLED D135MM F3200N, DIGITAL OUT | 3200 | 6400 | 320 | 320 | 135 | 25 | * | 1.0 |
