更多详情请咨询,深圳市芯美力科技有限公司 黄先生:19928739245(微同) QQ:541777848
High Efficiency 4-Switch Buck-Boost Converter
1、Features
| 2、Applications
3、Description PL94053 is a synchronous 4-switch Buck-Boost controller capable of regulating the output voltage at above or below the input voltage. PL94053 operates over a wide input voltage range of 3.6 V to 32 V (36 V maximum) to support a variety of applications. Integrated two 9mΩ power MOSFETs. PL94053 employs Constant ON time control in buck, boost and buck-boost operation modes for superior load and line regulation. The switching frequency could be set to 150kHz, 300kHz, 600kHz or 1200kHz based on different resistor value between FREQ pin and GND pin. The device also features a programmable soft-start function and offers all kinds of protection features including cycle-by-cycle current limiting, input under voltage lockout (UVLO), output over voltage protection (OVP), input Over Voltage Protection, thermal shutdown and output short protection etc. VADJ, IADJ pins are used to program output VBUS voltage and output current limit, provides voltage control loop, constant current loop, thermal regulation loop, temperature sensing, which makes PL94053 an excellent option for USB Power Delivery (PD) application. |
4、Typical Application Schematic | 5、Pin Configuration and Functions |
