/*============================================================================* * LOGIC CORE: 显示设备驱动硬件配置头文件 * MODULE NAME: camera_init() * COMPANY: 武汉芯路恒科技有限公司 * http://xiaomeige.taobao.com * author: 小梅哥 * Website: www.corecourse.cn * REVISION HISTORY: * * Revision: 1.0 04/10/2019 * Description: Initial Release. * * FUNCTIONAL DESCRIPTION: ===========================================================================*/ module camera_init( Clk, Rst_n, Init_Done, camera_rst_n, camera_pwdn, i2c_sclk, i2c_sdat ); input Clk; input Rst_n; output reg Init_Done; output camera_rst_n; output camera_pwdn; output i2c_sclk; inout i2c_sdat; assign camera_pwdn = 0; wire [15:0]addr; reg wrreg_req; reg rdreg_req; wire [7:0] wrdata; wire [7:0]rddata; wire RW_Done; wire ack; reg [7:0]cnt; wire [23:0]lut; localparam device_id = 8'h78; localparam addr_mode = 1'b1; localparam RGB = 0; localparam JPEG = 1; parameter IMAGE_TYPE = RGB; parameter IMAGE_WIDTH = 640; parameter IMAGE_HEIGHT = 480; parameter IMAGE_FLIP = 0; parameter IMAGE_MIRROR = 0; wire [7:0]lut_size; generate if(IMAGE_TYPE == RGB) begin assign lut_size = 252; case ({IMAGE_FLIP[0], IMAGE_MIRROR[0]}) 2'b00: begin ov5640_init_table_rgb camera_init_table( .addr(cnt), .clk(Clk), .q(lut) ); defparam camera_init_table.IMAGE_WIDTH = IMAGE_WIDTH; defparam camera_init_table.IMAGE_HEIGHT = IMAGE_HEIGHT; defparam camera_init_table.IMAGE_FLIP = 8'h40; defparam camera_init_table.IMAGE_MIRROR = 4'h7; end 2'b01: begin ov5640_init_table_rgb camera_init_table( .addr(cnt), .clk(Clk), .q(lut) ); defparam camera_init_table.IMAGE_WIDTH = IMAGE_WIDTH; defparam camera_init_table.IMAGE_HEIGHT = IMAGE_HEIGHT; defparam camera_init_table.IMAGE_FLIP = 8'h40; defparam camera_init_table.IMAGE_MIRROR = 4'h0; end 2'b10: begin ov5640_init_table_rgb camera_init_table( .addr(cnt), .clk(Clk), .q(lut) ); defparam camera_init_table.IMAGE_WIDTH = IMAGE_WIDTH; defparam camera_init_table.IMAGE_HEIGHT = IMAGE_HEIGHT; defparam camera_init_table.IMAGE_FLIP = 8'h47; defparam camera_init_table.IMAGE_MIRROR = 4'h7; end 2'b11: begin ov5640_init_table_rgb camera_init_table( .addr(cnt), .clk(Clk), .q(lut) ); defparam camera_init_table.IMAGE_WIDTH = IMAGE_WIDTH; defparam camera_init_table.IMAGE_HEIGHT = IMAGE_HEIGHT; defparam camera_init_table.IMAGE_FLIP = 8'h47; defparam camera_init_table.IMAGE_MIRROR = 4'h0; end endcase end else //IMAGE_TYPE == JPEG begin assign lut_size = 250; case ({IMAGE_FLIP[0], IMAGE_MIRROR[0]}) 2'b00: begin ov5640_init_table_jpeg camera_init_table( .addr(cnt), .clk(Clk), .q(lut) ); defparam camera_init_table.IMAGE_WIDTH = IMAGE_WIDTH; defparam camera_init_table.IMAGE_HEIGHT = IMAGE_HEIGHT; defparam camera_init_table.IMAGE_FLIP = 8'h40; defparam camera_init_table.IMAGE_MIRROR = 4'h7; end 2'b01: begin ov5640_init_table_jpeg camera_init_table( .addr(cnt), .clk(Clk), .q(lut) ); defparam camera_init_table.IMAGE_WIDTH = IMAGE_WIDTH; defparam camera_init_table.IMAGE_HEIGHT = IMAGE_HEIGHT; defparam camera_init_table.IMAGE_FLIP = 8'h40; defparam camera_init_table.IMAGE_MIRROR = 4'h0; end 2'b10: begin ov5640_init_table_jpeg camera_init_table( .addr(cnt), .clk(Clk), .q(lut) ); defparam camera_init_table.IMAGE_WIDTH = IMAGE_WIDTH; defparam camera_init_table.IMAGE_HEIGHT = IMAGE_HEIGHT; defparam camera_init_table.IMAGE_FLIP = 8'h47; defparam camera_init_table.IMAGE_MIRROR = 4'h7; end 2'b11: begin ov5640_init_table_jpeg camera_init_table( .addr(cnt), .clk(Clk), .q(lut) ); defparam camera_init_table.IMAGE_WIDTH = IMAGE_WIDTH; defparam camera_init_table.IMAGE_HEIGHT = IMAGE_HEIGHT; defparam camera_init_table.IMAGE_FLIP = 8'h47; defparam camera_init_table.IMAGE_MIRROR = 4'h0; end endcase end endgenerate assign addr = lut[23:8]; assign wrdata = lut[7:0]; i2c_control i2c_control( .Clk(Clk), .Rst_n(Rst_n), .wrreg_req(wrreg_req), .rdreg_req(0), .addr(addr), .addr_mode(addr_mode), .wrdata(wrdata), .rddata(rddata), .device_id(device_id), .RW_Done(RW_Done), .ack(ack), .i2c_sclk(i2c_sclk), .i2c_sdat(i2c_sdat) ); wire Go; //initial enable reg [20:0] delay_cnt; //上电并复位完成20ms后再配置摄像头,所以从上电到开始配置应该是1.0034 + 20 = 21.0034ms //这里为了优化逻辑,简化比较器逻辑,直接使延迟比较值为24'h100800,是21.0125ms always @ (posedge Clk or negedge Rst_n) if (!Rst_n) delay_cnt <= 21'd0; else if (delay_cnt == 21'h100800) delay_cnt <= 21'h100800; else delay_cnt <= delay_cnt + 1'd1; //当延时时间到,开始使能初始化模块对OV5640的寄存器进行写入 assign Go = (delay_cnt == 21'h1007ff) ? 1'b1 : 1'b0; //5640要求上电后其复位状态需要保持1ms,所以上电后需要1ms之后再使能释放摄像头的复位信号 //这里为了优化逻辑,简化比较器逻辑,直接使延迟比较值为24'hC400,是1.003520ms assign camera_rst_n = (delay_cnt > 21'h00C400); always@(posedge Clk or negedge Rst_n) if(!Rst_n) cnt <= 0; else if(Go) cnt <= 0; else if(cnt < lut_size)begin if(RW_Done && (!ack)) cnt <= cnt + 1'b1; else cnt <= cnt; end else cnt <= 0; always@(posedge Clk or negedge Rst_n) if(!Rst_n) Init_Done <= 0; else if(Go) Init_Done <= 0; else if(cnt == lut_size) Init_Done <= 1; reg [1:0]state; always@(posedge Clk or negedge Rst_n) if(!Rst_n)begin state <= 0; wrreg_req <= 1'b0; end else if(cnt < lut_size)begin case(state) 0: if(Go) state <= 1; else state <= 0; 1: begin wrreg_req <= 1'b1; state <= 2; end 2: begin wrreg_req <= 1'b0; if(RW_Done) state <= 1; else state <= 2; end default:state <= 0; endcase end else state <= 0; endmodule
复制代码
