申矽凌CHT8305C温湿度传感器与市面主流温湿度传感器兼容,采用DFN3*3-6封装,温度精度±0.5℃ over 0℃ to 50℃ ,湿度±3.0%RH over 20 to 80%RH ,搭配BLE芯片,PHY6202。有兴趣的朋友可以一起交流探讨。徐先生 13424403436 jack.xu@cyberlink.net.cn
CHT8305C主要特点:
◆ VCC: 2.5V to 5.5V
◆ Average Current Consumption (each T orHmeasurement per second):
1.5uA(Typ.), 3.0uA(Max.)
◆ Shutdown Current: 0.15uA(Typ.),0.3uA(Max.)
◆ Temperature Accuracy: ±0.5oC over 0oC to 50oC
◆ Humidity Accuracy:±3.0%RH over 20 to 80%RH
◆ Conversion time (14-bit) for T or H: 5.5ms(Typ.)
◆ 14-bit ADC for Temperature and Humidity
◆ Compatible with I2C and 2-wire
◆ Programmablehigh-limit of Temperature/humidity
◆ Generate 4 different slave address bysetting AD0 pin
◆ Protection Cover is available option
◆ VCC: 2.5V to 5.5V
PHY6202主要特点:
1)ARM® Cortex™-M0 32-bit processor
2) Memory 512KB/2MB in-system flash memory 128KB ROM 138KB SRAM, all programmable retention in sleep mode 8-channel DMA•
3) 33/19 general purpose I/O pins
4) Power consumption 0.7μA @ OFF Mode (IO wake up only) 2μA @ Sleep Mode with 32KHz RTC Receiver: 6.7mA @sensitivity level Transmitter: 6.7mA @0dBm TX power
5) Sensitivity:-97dBm@BLE 1Mbps data rate-103dBm@BLE 125Kbps data rate
