`timescale 1 ns/ 1 psmodule LAMP_vlg_tst(); // constants // general purpose registers reg eachvec; // test vector input registers reg clk; reg rst_n; // wires wire led; // assign statements (if any) LAMP i1 ( // port map - connection between master ports and signals/registers .clk(clk), .led(led), .rst_n(rst_n) ); reg [7:0] memory [0:255]; integer scan; integer index=3; initial begin clk=0; #10 clk=~clk; end initial begin $readmemh("memory.list", memory); end if(index>0) begin for(scan=0;scan<index;scan=scan+1) if(memory[scan]>0) begin $display("%d",memory[scan]); end end else $display("error--indexiszero"); endmodule
复制代码
请高手解惑,谢谢!
