使用过ucosii的朋友应该都会知道,单片机+嵌入式实时操作系统能够做到尽可能最大化的利用cpu资源,通过加入实时操作系统能够做出更加强大的产品和应用。
不知道使用过ucosii的朋友有没有去了解过它进行任务调度的原理和实现方式呢?
我个人结合ucosii的源码和自己的理解,分享一些有关ucosii的任务管理和调度的实现。
1、ucos-ii 任务创建与任务调度1.1、任务的创建
当你调用 OSTaskCreate( ) 进行任务的创建的时候,会初始化任务的堆栈、保存cpu的寄存器、创建任务的控制块(OS_TCB)等的操作;
if (OSTCBPrioTbl[prio] == (OS_TCB *)0) { /* Make sure task doesn't already exist at this priority  */
  •         OSTCBPrioTbl[prio] = OS_TCB_RESERVED;/* Reserve the priority to prevent others from doing ...  */
  •                                              /* ... the same thing until task is created.              */
  •         OS_EXIT_CRITICAL();
  •         psp = OSTaskStkInit(task, p_arg, ptos, 0u);             /* Initialize the task's stack         */
  •         err = OS_TCBInit(prio, psp, (OS_STK *)0, 0u, 0u, (void *)0, 0u);
  •         if (err == OS_ERR_NONE) {
  •             if (OSRunning == OS_TRUE) {      /* Find highest priority task if multitasking has started */
  •                 OS_Sched();
  •         } else {
  •             OS_ENTER_CRITICAL();
  •             OSTCBPrioTbl[prio] = (OS_TCB *)0;/* Make this priority available to others                 */
  •         return (err);
  • 复制代码
    注意:ucosii不支持两个及以上相同的任务优先级的任务,ucosiii支持时间片轮转。
    ucosii 的任务控制块是任务中很重要,它记录了任务的信息,包括优先级、延时时间、状态等信息。控制块定义如下:
    typedef struct os_tcb {
  •     OS_STK          *OSTCBStkPtr;           /* Pointer to current top of stack                         */
  • #if OS_TASK_CREATE_EXT_EN > 0u
  •     void            *OSTCBExtPtr;           /* Pointer to user definable data for TCB extension        */
  •     OS_STK          *OSTCBStkBottom;        /* Pointer to bottom of stack                              */
  •     INT32U           OSTCBStkSize;          /* Size of task stack (in number of stack elements)        */
  •     INT16U           OSTCBOpt;              /* Task options as passed by OSTaskCreateExt()             */
  •     INT16U           OSTCBId;               /* Task ID (0..65535)                                      */
  • #endif
  •     struct os_tcb   *OSTCBNext;             /* Pointer to next     TCB in the TCB list                 */
  •     struct os_tcb   *OSTCBPrev;             /* Pointer to previous TCB in the TCB list                 */
  • #if (OS_EVENT_EN)
  •     OS_EVENT        *OSTCBEventPtr;         /* Pointer to          event control block                 */
  • #endif
  • #if (OS_EVENT_EN) && (OS_EVENT_MULTI_EN > 0u)
  •     OS_EVENT       **OSTCBEventMultiPtr;    /* Pointer to multiple event control blocks                */
  • #endif
  • #if ((OS_Q_EN > 0u) && (OS_MAX_QS > 0u)) || (OS_MBOX_EN > 0u)
  •     void            *OSTCBMsg;              /* Message received from OSMboxPost() or OSQPost()         */
  • #endif
  • #if (OS_FLAG_EN > 0u) && (OS_MAX_FLAGS > 0u)
  • #if OS_TASK_DEL_EN > 0u
  •     OS_FLAG_NODE    *OSTCBFlagNode;         /* Pointer to event flag node                              */
  • #endif
  •     OS_FLAGS         OSTCBFlagsRdy;         /* Event flags that made task ready to run                 */
  • #endif
  •     INT32U           OSTCBDly;              /* Nbr ticks to delay task or, timeout waiting for event   */
  •     INT8U            OSTCBStat;             /* Task      status                                        */
  •     INT8U            OSTCBStatPend;         /* Task PEND status                                        */
  •     INT8U            OSTCBPrio;             /* Task priority (0 == highest)                            */
  •     INT8U            OSTCBX;                /* Bit position in group  corresponding to task priority   */
  •     INT8U            OSTCBY;                /* Index into ready table corresponding to task priority   */
  •     OS_PRIO          OSTCBBitX;             /* Bit mask to access bit position in ready table          */
  •     OS_PRIO          OSTCBBitY;             /* Bit mask to access bit position in ready group          */
  •     INT8U            OSTCBDelReq;           /* Indicates whether a task needs to delete itself         */
  • #endif
  • #if OS_TASK_PROFILE_EN > 0u
  •     INT32U           OSTCBCtxSwCtr;         /* Number of time the task was switched in                 */
  •     INT32U           OSTCBCyclesTot;        /* Total number of clock cycles the task has been running  */
  •     INT32U           OSTCBCyclesStart;      /* Snapshot of cycle counter at start of task resumption   */
  •     OS_STK          *OSTCBStkBase;          /* Pointer to the beginning of the task stack              */
  •     INT32U           OSTCBStkUsed;          /* Number of bytes used from the stack                     */
  • #endif
  • #if OS_TASK_NAME_EN > 0u
  •     INT8U           *OSTCBTaskName;
  • #endif
  • #if OS_TASK_REG_TBL_SIZE > 0u
  •     INT32U           OSTCBRegTbl[OS_TASK_REG_TBL_SIZE];
  • #endif
  • } OS_TCB;
  • 复制代码
    2、任务调度实现2.1、将任务优先级进行分组
    因为ucosii最大优先级数量为64个,所以可以分成8组,每组8个优先级。
    当一个任务被创建成功之后,它的组号由优先级的高三位决定(bit5 bit4 bit3),它在组内的编号由优先级的低三位决定(bit2 bit1 bit0),如下:
    #if OS_LOWEST_PRIO <= 63u                                         /* Pre-compute X, Y                  */
  •         ptcb->OSTCBY             = (INT8U)(prio >> 3u);    // 组
  •         ptcb->OSTCBX             = (INT8U)(prio & 0x07u);  // 组内编号
  • #else
  • 复制代码
    2.2、任务就绪表
    ucosii对任务优先级的调度管理是通过查询任务就绪表进行的。任务就绪表里面保存着当前所有任务的就绪状态,如下:
    OSRdyTbl[8]
  • 说明:
  • 1)它是uint8的数据类型。它的长度是8,每一个元素代表一个组,
  • 比如 OSRdyTbl[0]代表第0组, OSRdyTbl[1]代表第1组,OSRdyTbl[2]代表第2组……以此类推。
  • 2)每一个元素中的每一个位(bit)代表组内的任务的就绪状态(1为就绪,0为未就绪)。
  • 说明:
  • 1)当优先级为12 的任务就绪时,那么对应的OSRdyTbl[1]的第4位bit,绝对等于1;
  • 当整个系统中,当只有优先级为12的任务就绪,其他所有任务都没有就绪时,那么OSRdyTbl[1] 绝对等于0x10。
  • 2)当优先级为0和1的任务就绪时,那么对应的OSRdyTbl[0]的第0位bit以及第1位bit,都绝对等于1;
  • 当整个系统中,当只有优先级为0和1的任务就绪,其他所有任务都没有就绪时,那么OSRdyTbl[0] 绝对等于0x03。
  • 复制代码
    2.3、任务释放CPU使用权
    当任务中调用 OSTimeDly( ) 时,会让任务进入休眠的状态,交出CPU的执行权给到其他就绪任务去执行,这个过程就发生了任务的切换。
    简单而言就是会把任务就绪表 OSRdyTbl 中对应的任务优先级在组内的编号状态改变,从而使任务自身进入休眠状态。代码如下:
    if (ticks > 0u) {                            /* 0 means no delay!                                  */
  •         y            =  OSTCBCur->OSTCBY;        /* Delay current task                                 */
  •         OSRdyTbl[y] &= (OS_PRIO)~OSTCBCur->OSTCBBitX;
  •         if (OSRdyTbl[y] == 0u) {
  •             OSRdyGrp &= (OS_PRIO)~OSTCBCur->OSTCBBitY;
  •         OSTCBCur->OSTCBDly = ticks;              /* Load ticks in TCB                                  */
  •         OS_Sched();                              /* Find next task to run!                             */
  • 复制代码
    在上面的代码中发现了一个东西:OSRdyGrp。这个有什么用呢?
    OSRdyGrp:管理任务就绪组的
    复制代码
    OSRdyGrp是INT8U类型的,它每一个bit代表一个组,只要这个组内有任何一个任务就绪了,那对应的这个bit就会被设置为1,表示这个组内目前有就绪的任务。否者对应的位为0。
    举个例子,如下:
    1)系统中只有任务0就绪了,那么OSRdyGrp 便等于 0x01(二进制00000001)。
  • 2)系统中有任务0和任务63都就绪了,那么OSRdyGrp 便等于 0x81(二进制10000001)。
  • 复制代码
    2.4、任务实现调度切换操作
    发生一次任务调度是通过 OS_Sched() 进行的。源码如下:
    void  OS_Sched (void)
  • #if OS_CRITICAL_METHOD == 3u                           /* Allocate storage for CPU status register     */
  •     OS_CPU_SR  cpu_sr = 0u;
  • #endif
  •     if (OSIntNesting == 0u) {                          /* Schedule only if all ISRs done and ...       */
  •         if (OSLockNesting == 0u) {                     /* ... scheduler is not locked                  */
  •             OS_SchedNew();
  •             OSTCBHighRdy = OSTCBPrioTbl[OSPrioHighRdy];
  •             if (OSPrioHighRdy != OSPrioCur) {          /* No Ctx Sw if current task is highest rdy     */
  •                 OSTCBHighRdy->OSTCBCtxSwCtr++;         /* Inc. # of context switches to this task      */
  • #endif
  •                 OSCtxSwCtr++;                          /* Increment context switch counter             */
  •                 OS_TASK_SW();                          /* Perform a context switch                     */
  • 复制代码
    这里的过程如下:
    (1)先通过 OS_SchedNew() 找到当前处于就绪状态的最高优先级的任务,如下:
    y = OSUnMapTbl[OSRdyGrp];
  • OSPrioHighRdy = (INT8U)((y << 3u) + OSUnMapTbl[OSRdyTbl[y]]);
  • 复制代码
    (2)然后通过 OS_TASK_SW() 进行任务切换,它的过程如下:
    1)OS_TASK_SW 只是一个宏,它实际替换的是 OSCtxSw()
  • #define  OS_TASK_SW()         OSCtxSw()
  • 2)OSCtxSw()是由汇编实现的
  • OSCtxSw
  •     PUSH    {R4, R5}
  •         LDR     R4, =NVIC_INT_CTRL    ;触发PendSV异常 (causes context switch)
  •         LDR     R5, =NVIC_PENDSVSET
  •         STR     R5, [R4]
  •     POP     {R4, R5}
  •         BX      LR
  • 复制代码
    就这样,上下文就完成了一次切换。
