这里就以Telink B91开发板来驱动一个8*8点阵的显示模块,当然在级联的情况下它就可显示更多的内容。
点阵模块与开发板的具体连接关系为:
CS ---PB5
为输出高低电平,所作的定义为:
#defineCLK_high gpio_set_level(GPIO_PB4, 1)
#defineCLK_low gpio_set_level(GPIO_PB4, 0)
#defineDIN_high gpio_set_level(GPIO_PB5, 1)
#defineDIN_low gpio_set_level(GPIO_PB5, 0)
#defineCS_high gpio_set_level(GPIO_PB6, 1)
#defineCS_low gpio_set_level(GPIO_PB6, 0)
以GPIO口方式串行字节数据的函数为:
voidWrite_Max7219_byte(unsignedchar DATA){ unsignedchar i; CS_low; for(i=8;i>=1;i--) { CLK_low; if(DATA&0x80) DIN_high; else DIN_low; DATA=DATA<<1; CLK_high; } }
复制代码Max7219向指定地址发送控制字的函数为:
void Write_Max7219(unsignedchar address,unsignedchar dat){ CS_low; Write_Max7219_byte(address); Write_Max7219_byte(dat); CS_high; }
复制代码对Max7219进行初始化的函数为:
voidInit_MAX7219(void){ Write_Max7219(0x09, 0x00); Write_Max7219(0x0a, 0x03); Write_Max7219(0x0b, 0x07); Write_Max7219(0x0c, 0x01); Write_Max7219(0x0f, 0x00); }
复制代码为了进行显示,所配置的字库结构为:
unsignedchar disp1[38][8]={ {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0 {0x10,0x30,0x50,0x10,0x10,0x10,0x10,0x10},//1 {0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2 ... {0x8,0x14,0x22,0x3E,0x22,0x22,0x22,0x22},//A {0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C,0x0},//B {0x3C,0x40,0x40,0x40,0x40,0x40,0x3C,0x0},//C ... {0x8,0x7F,0x49,0x49,0x7F,0x8,0x8,0x8},//中 {0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE},//国 };
复制代码实现点阵模块显示测试的主程序为:
intmain (void){ unsignedchar i,j; sys_init(LDO_1P4_LDO_1P8, VBAT_MAX_VALUE_GREATER_THAN_3V6); user_read_flash_value_calib(); CCLK_24M_HCLK_24M_PCLK_24M; user_init(); Init_MAX7219(); while(1) { for(j=0;j<38;j++) { for(i=1;i<9;i++) Write_Max7219(i,disp1[j][i-1]); delay_ms(1000); } } return 0; }
复制代码经程序的编译与下载,其显示效果如图1至图3所示。
图1显示数字
图2 显示字符
图3显示汉字
