SLVU2.8-4
SLVU2.8-8
The SLVU2.8 series has been designed to protect Ethernet line. Its low capacitance makes it compatible with Gigabit Ethernet. SLVU2.8-4 is designed to be compatible with Gigabiit Ethernet and Gigabit PoE by using two SO-8 packages and can be used on 10/100 Mbps Ethernet by using a single device. SLVU2.8-8 is designed to be compatible with Gigabiit Ethernet and Gigabit PoE by using a single SO-8 package. Surge capability is compatible with IEC 61000-4-5 class 2 (1 kV, 42 Ω, 24 A).
低电容瞬变二极管集成阵列应用千兆以太网保护
SLVU2.8SOT-23
SLVU2.8-4SO-8
SLVU2.8-8SO-8
Low voltage unit for Gigabit Ethernet protection
SLVU2.8-4适用于保护低压CMOS设备不受ESD和雷击感应电压瞬变的危害。每个低压TVS都有一个与之串联的补偿二极管,可为受保护的线路提供低负载电容。根据IEC61000-4-2标准,该稳定结构可以在±30kV(接触放电)条件下安全地吸收反复性ESD冲击,每个结构都可以在极低的箝位电压下安全地耗散24A(IEC61000-4-5,tP=8/20μs)的波形浪涌电流。
功能与特色 :
· ESD,IEC61000-4-2,±30kV(触点),±30kV(空气)
· EFT,IEC61000-4-4,40A (5/50ns)
· 雷击,IEC61000-4-5,24A(8/20?s)
· 每条线路的电容低至3.8pF
· 2.8V下的低泄漏电流为1μA(值)
· SOIC-8引脚配置允许使用简易的直通型布局
应用 :
· 10/100/1000以太网
· 局域网/广域网设备
· 开关系统
· 台式电脑、服务器和笔记本电脑
· 模拟输入
· 基站
SLVU2.8 SLVU2.8-4 SLVU2.8-8
产品特点:
Peak pulse current : IPP= 30 A 8/20 μs
Low capacitance : Ctyp= 1.5 pF
Stand-off voltage : VR= 2.8 V
Low leakage current : IRmax= 0.2 μA
ECOPACK®2 compliant component
IEC 61000-4-5 (1kV 42 Ω 24 A) compliant at Tj= 150 °C
Complies with the following standards
IEC 61000-4-2 level 4
15 kV (air discharge)
8 kV (contact discharge)
IEC 61000-4-4 level 4
± 2 kV - 40 A (5/50 ns)
IEC 61000-4-5 level 2
± 1 kV - 42 Ω
应用领域
10/100/1000 Ethernet equipment
WAN/LAN equipment
Switching systems
Desktops, servers, and notebooks
Analog inputs
Base stations
常州鼎先电子有限公司 13775299578邢先生 电话:0519-88171671 常州市钟楼区西林街道华林路139-1号
SLVU2.8-4 24A.pdf
(2.3 MB, 下载次数: 0)
暂无评论,快来抢沙发吧
