CE65H110DNDl系列650v、110mΩ氮化镓(GaN)FET是常关器件。
Corenergy GaN FET通过更低的栅极电荷、更快的开关速度和更低的动态导通电阻提供了更好的效率,与传统的硅(Si)器件相比具有显著的优势。
Description
The CE65H110DNDl Series 650v, 110mΩgallium nitride(GaN) FETs are normally-offdevices.
Corenergy GaN FETs offer better efficiencythrough lower gate charge,faster switchingspeeds,and lower dynamic on-resistance,delivering significant advantages over traditionalsilicon (Si) devices.
Corenergyis a leading-edge wide band gapsupplier with world-class innovation .
Application
Adapter
Renewable energy
eTelecom and data-com
Servo motors
Industrial
Automotive
General Features
Easy to drive-compatible with standard gate drivers
Low conduction and switching losses
RoHS compliant and Halogen-free
Benefits
Increased efficiency through fast switching
Increased power density
Reduced system size and weight
系统描述/System Description
应⽤氮化镓 CE65H110DNDI 设计 20V16.5A 330W 笔电适配器
应⽤拓扑结构为 PFC+LLC
平均效率可达:94.75%
最⾼效率:95.70%
保护功能:输出过压保护;输出过流保护;输⼊⽋压保护 ;短路保护
输出电压调整率:±5%
线性电压调整率:±3%
额定功率:330W
环境温度:40℃
外壳尺⼨:L*W*H/163.2*77.2*30.5mm
