Forvehicle engineers, experiencing steering feel is essential for evaluation.Imagine being able to experience, evaluate and apply this steering feel muchearlier in the development phase and without a vehicle. With the MXsteerHiL you experience the real steering feel at anearly stage at your desk or in the lab and not – as usual – only in theprototype vehicle. The differences in steering feel can be measured andcalibrated with the MXsteerHiL. Especially in automated driving, the MXsteerHiLallows you to enter development with a high degree of maturity. Soundsunimaginable? It isn’t. Because that is our promise – backed by many years ofexpert knowledge – behind the MXsteerHiL. Convince yourself. Here are thepertinent reasons why you should use our system:
对于汽车工程师而言,亲自体验转向手感,对于评估来说是至关重要的。来设想一下,在开发阶段的更早期,一辆车也没有,就能体验、评估和采用这种转向手感。拥有MXsteerHiL,您就可以在办公桌或者实验室里,更早体验真实的转向手感,而不是通常情况下的原型车上。不同转向手感之间的差异,可以通过MXsteerHiL进行测量和标定。尤其针对自动驾驶,MXsteerHiL将帮助您实现高成熟度的开发。听起来不可思议?那可未必。MXdynamiX公司敢给予这样的承诺!这一切都源自于MXsteerHiL背后多年的专家知识。现在是时候说服您自己了,下面是您采用我们系统的五大确切理由:
First. A variety of professionaldirections benefit from this tool. The MXsteerHiL helps to achieve the perfect steeringfeel. For application engineers in particular, it is of great importance toalways have access to a test bench in order to be able to test new ideasimmediately and on the spot. For function developers too, the MXsteerHiL offersgreat opportunities not to “bypass” the customer, but to harmonize thedevelopment of the hardware with the desired experience in a concrete andtargeted way. This also makes it easy to tune the steering, not least for thedeveloper of ADAS/AD systems. Our own experience and that of our customers showa wide range of applications for operators of driving simulators. Especially insimulation, this steering force module is an enormous asset for testing,validating and calibrating steering systems. Simulators already in operationcan easily be extended with MXsteerHiL to make the simulation experience evenmore realistic.
第一大理由:MXsteerHiL给不同的专业方向都带来帮助,从而实现完美的转向手感。尤其对于应用工程师而言,能随时使用测试台架来第一时间当场测试自己的新想法,实在是太重要了。对于功能开发工程师来说也是如此,MXsteerHiL提供了很好的机会,不用“旁通”掉最终客户,而是用一种专注和目标导向的方式,将硬件开发和所希望实现的转向手感,进行和谐统一。这使得转向的调教变得轻松,不仅限于ADAS/AD系统的开发者。我们以及客户的经验都表明,驾驶模拟器的操控可以有非常大的应用范围。尤其是在仿真时,这个转向力的模块是个巨大的资产,可以用于测试、验证和标定转向系统。已经投入使用的驾驶模拟器,也可以通过MXsteerHiL来轻松扩展,让仿真体验变得更加真实。
Second. Through a modulardesign, you acquire a product that can be subsequently adapted for new steeringor vehicle projects, other priorities and state-of-the-art products, such assteer-by-wire. You can also convert MXsteerHiL into a static driving simulator or –if you already have a dynamic driving simulator – add a realistic vehicleenvironment as an add-on. They are so modular and flexible that you hardly needto switch between simulative measurement and feel. And on top of that, theysave valuable workshop or office space, as the MXsteerHiL can be disassembledinto the individual modules and stored in the office cupboard or workshop nicheto save space.
第二大理由:MXsteerHiL借助于模块化设计,后续可以适用于新的转向项目或者车辆项目,不同优先级的项目以及最新技术的产品开发(比如线控转向)。您可以把MXsteerHiL变成一个静态驾驶模拟器,或者加入到您已有的动态驾驶模拟器里提供真实的车辆环境。MXsteerHiL的模块化和灵活性,让您几乎不用在仿真测量和真实感受之间切换。最重要的是,它可以节省价值不菲的车间或者办公空间,因为MXsteerHiL可以拆卸成独立的模块,存放在办公室橱柜或者车间壁龛里来节省空间。
Third. It is hard toimagine a cheaper and more flawless representation of reality. Nocost-intensive prototype is required and there is no longer any need tostruggle with insufficiently good representation of the steering in simulationmodels. This not only saves money, but also time. Because you recognize realproblems in virtual development earlier than ever.
第三大理由:很难相信除MXsteerHiL之外,还能有更便宜和无瑕的对现实的展示。不需要高昂成本的原型车,也不需要纠结那些不能很好展现转向效果的仿真模型。MXsteerHiL不仅节省您的金钱,也能节省您的时间,因为您可以在虚拟开发的更早阶段就发现真正的问题。
Fourth. Ideal for use invehicle models, such as CarMaker, ASM or in-house models, because the MXsteerHiL is compatible with all commonreal-time computers. A significant advantage because the MXsteerHiL can beeasily integrated into the existing real-time simulation system.
第四大理由:适配于所有车辆模型和实时系统。不管是CarMaker,ASM,DYNA4还是内部开发的车辆动力学模型,MXsteerHiL都能完美适用,并且兼容市面上常用的实时系统。一个显著的优点就是,MXsteerHiL能够非常轻松地集成到您现有的实时仿真系统中。
Fifth. The mostconvincing argument might be the treasure trove of experience and knowledge inthe manufacturer’s field of application. Through our know-how we have managedto bring this feeling of driving pleasure from the road to the test bench andinto the simulator. The experience of MdynamiX in the fields of vehicledynamics and simulation as well as the close and long-standing cooperation withthe universities of Munich and Kempten and the major companies in theindustries are the basis of this high-performance mini-steering test bench.
第五大理由:最有说服力的理由就是,MdynmiX公司在转向应用领域所积累的经验和知识,这是MXsteerHiL的财富库。借助我们的know-how,我们成功地把驾驶乐趣的感受从道路带到了测试台架,并且嵌入到模拟器里。MdynamiX在车辆动力学和仿真领域的丰富经验,与Munich和Kempten大学、汽车行业各大整车厂和零部件厂商的长期紧密合作,这些都是提供MXsteerHiL这样的高性能迷您型转向测试台架的基础。
Our competent team will help you find theright configured solution. We support you from the initial consultation tobeyond the commissioning. We are in personal contact with you and take care ofyour individual needs and wishes so you get exactly what you need for yourdevelopment.
我们极富竞争力的团队,将帮助您找到合适的配置方案。我们将支持您从最终的咨询到最终的调试。我们将关注您的个性化需求,并且希望您真正得到您的转向开发所需要的一切。
