焊上芯片,通上12V电源,按一下按复位按键,红灯闪一下,亮绿灯,解锁恢复成功,拆下芯片测试,解锁没成功,就亮红灯
能解锁的芯片列表
Full list below:1kB: AT90s1200, Attiny11, Attiny12, Attiny13/A, Attiny15 2kB: Attiny2313/A, Attiny24/A, Attiny26, Attiny261/A, Attiny28, AT90s2333, Attiny22, Attiny25, AT90s2313, AT90s2323, AT90s2343 4kB: Atmega48, Atmega48P/A, Attiny461/A, Attiny43U, Attiny4313, Attiny44/A, Attiny48, AT90s4433, AT90s4414, AT90s4434, Attiny45 8kB: Atmega8515, Atmega8535, Atmega8, Atmega88, Atmega88P/A, AT90pwm1, AT90pwm2, AT90pwm2B, AT90pwm3, AT90pwm3B, AT90pwm81, AT90usb82, Attiny861/A, Attiny87, Attiny88, Attiny85, AT90s8515, AT90s8535 16kB: Atmega16/A, Atmega16U2, Atmega16U4, Atmega16M1, Atmega161, Atmega162, Atmega163, Atmega164, Atmega164P/A, Atmega165/P/A/PA, Atmega168, Atmega168P/A, Atmega169/P/A/PA, Attiny167, AT90pwm216, AT90pwm316, AT90usb162 32kB: Atmega32/A, Atmega32C1, Atmega323/A, Atmega32U2, Atmega32U4, Atmega32U6, Atmega32M1, Atmega324, Atmega324P/A, Atmega325, Atmega3250, Atmega325P, Atmega3250P, Atmega328, Atmega328P, Atmega329, Atmega3290, Atmega329P, Atmega3290P, AT90can32 64kB: Atmega64/A, Atmega64C1, Atmega64M1, Atmega649, Atmega6490, Atmega640, Atmega644, Atmega644P/A, Atmega645, Atmega6450, AT90usb646, AT90usb647, AT90can64 128kB: Atmega103, Atmega128/A, Atmega1280, Atmega1281, Atmega1284, Atmega1284P, AT90usb1286, AT90usb1287, AT90can128 256kB: Atmega2560, Atmega2561
复制代码
统一回复一下 这个版本据说是波兰大神写的 所列型号据大神所列都能解锁 我手头没有那么多型号没能一一实验 说实验型号有ATmega 8 8a 8L 48 64A 128A 32 6楼8楼所言我反驳一下 有些不能解锁是因为程序或者熔丝设置了禁止读的功能 用USB-ttl接到串口调试助手 波特率4800就看到信息了 这时要短接擦除端子方可 整个程序也擦除了 估计波兰大神是不想万一还要保留程序以防意外擦除。还有好多技巧有待慢慢研究
