金鉴提供页岩样品氩离子抛光、切割服务(离子抛光法CP)+高分辨率场发射扫描电镜SEM观察。金鉴实验室氩离子抛光(CP法抛光)制样,可以获得平滑的截面,而不会对样品造成机械损害。以下为案例展示。
平面刻蚀抛光功能
左图为离子研磨前,右图为研磨后,通过离子研磨可以去除机械研磨抛光对样品产生的应力损伤,从右图中可以清楚看到两种不同铜的结构
平面刻蚀抛光功能
通过控制平面研磨时间,可以获得更多样品的细节信息
Package FA
Results of experiment
SEM Parameter:
Accelerating Voltage: 1KV Magnification: 600X Imaging Mode: back-scattered electron
Package:FA ,Cooling Stage
SEM Parameter:
Accelerating Voltage: 1KV Magnification: 2,500X Imaging Mode: back-scattered electron
SEM Parameter:
Accelerating Voltage: 1KV Magnification: 5,000X Imaging Mode: back-scattered electron
SEM Parameter:
Accelerating Voltage: 1KV Magnification: 10,000X Imaging Mode: back-scattered electron
Package:FA;Cooling Stage
PCB Board:Cooling Stage
Die package application
Results
High Mag
PCB with OSP layer
Low Mag
PCB with OSP layer
High Mag
TSV
Central TSV
Center TSV near middle of length
Low K Material
分立器件
High Mag
High Mag
Cu wire with Pdcoating
2.5D Interposer
GatanResults Polished Width at ROI ~ 1000um
High Mag
BSE Image “Left Via”
         SE Image Region 9                BSE Image Region #9
BSE Image Region #10
BSE Image “Right Via”
金属镀层
镀锌钢板
镀锌钢板-High Mag
