尽管ME32F103开发板提供了4位数码管的显示方式,但相对来讲其显示的信息量还相对有限,为此又给它添加了一种OLED屏的显示方式。
该显示屏是一款准双色的显示屏,共有2种颜色,即黄色和蓝色。该显示屏是以I2C接口的方式来工作,因此很节省引脚资源。
为驱动该显示屏工作,是使用图1所示的接口来连接显示屏。
图1 所用接口
其中:
PC6连接SCL
PC7连接SDA
将这2个引脚设置为输出口且置为高电平输出的函数为:
Void OLED_set(void)
PC6_INIT(PC6_GPIO);
PC7_INIT(PC7_GPIO);
PC_INIT_AS_OUTPUT(IO_PIN6);
PC_INIT_AS_OUTPUT(IO_PIN7);
OLED_SCLK_Set();
OLED_SDIN_Set();
复制代码为程序中输出高低电平的相应,特进行如下定义:
#define OLED_SCLK_Clr() GPIO_ResetPins(PC, IO_BIT_PIN6)
#define OLED_SCLK_Set() GPIO_SetPins(PC, IO_BIT_PIN6)
#define OLED_SDIN_Clr() GPIO_ResetPins(PC, IO_BIT_PIN7)
#define OLED_SDIN_Set() GPIO_SetPins(PC, IO_BIT_PIN7)
该OLED屏的初始化函数为:
void OLED_Init(void)
Write_IIC_Command(0xAE);
Write_IIC_Command(0x20);
Write_IIC_Command(0x10);
Write_IIC_Command(0xb0);
Write_IIC_Command(0xc8);
Write_IIC_Command(0x00);
Write_IIC_Command(0x40);
Write_IIC_Command(0x81);
Write_IIC_Command(0xdf);
Write_IIC_Command(0xa1);
Write_IIC_Command(0xa6);
Write_IIC_Command(0xa8);
Write_IIC_Command(0x3F);
Write_IIC_Command(0xa4);
Write_IIC_Command(0xd3);
Write_IIC_Command(0xd5);
Write_IIC_Command(0xf0);
Write_IIC_Command(0xd9);
Write_IIC_Command(0x22);
Write_IIC_Command(0xda);
Write_IIC_Command(0x12);
Write_IIC_Command(0xdb);
Write_IIC_Command(0x8d);
Write_IIC_Command(0x14);
Write_IIC_Command(0xaf);
复制代码该显示屏的清屏函数为:
void OLED_Clear(void)
uint8_t i,n;
for(i=0;i<8;i++)
OLED_WR_Byte (0xb0+i,OLED_CMD);
OLED_WR_Byte (0x00,OLED_CMD);
OLED_WR_Byte (0x10,OLED_CMD);
for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
复制代码该显示屏的字符串显示函数为:
void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t Char_Size)
unsigned char j=0;
while (chr[j]!='\0')
{ OLED_ShowChar(x,y,chr[j],Char_Size);
x+=8;
if(x>120){x=0;y+=2;}
j++;
复制代码该显示屏显示字符串的主程序为:
int main(void)
SYS_ExtOSC_EN();
SYS_PLL_Config(EXTERNAL_CLK,72000000);
SYS_SelectMainClkSrc(PLL_CLK);
SYS_SetAHBClkDivider (1);
SYS_SetAPBClkDivider (1);
OLED_set();
OLED_Init();
OLED_Clear();
OLED_ShowString(0,0,"ME32F103",16);
OLED_ShowString(0,2,"OLED TEST",16);
while(1);
复制代码经程序的编译与下载,其显示结果如图2所示,说明显示功能正常。
图2 显示效果
后续在添加数值显示功能的情况下,可与A/D数据采集功能相结合来实现温度检测功能。
