【电子DIY】DIY行车记录仪为游戏机之主控软件开发(9)可测试行可维护性
代码见:https://github.com/qinyunti/py32f403-nes.git
一.前言
前面我们已经实现了大量的文件操作命令,spi,flash操作命令,处于可测试性可维护性考虑,我们再来实现任意mem地址的修改,内容导入导出,任务信息查看等功能。
二.任务查看
configUSE_TRACE_FACILITY中以下宏定义为1
#define configUSE_TRACE_FACILITY                1
shell_func.c中申明函数
static void psfunc(uint8_t* param);
g_shell_cmd_list_ast中添加命令行
  { (uint8_t*)"ps",    psfunc,    (uint8_t*)"ps"},
实现如下
  (void)param;
  uint32_t tasknum = uxTaskGetNumberOfTasks();
  if(tasknum > 0)
    TaskStatus_t * p_task_array = pvPortMalloc(sizeof(TaskStatus_t) * tasknum);
    if (NULL == p_task_array) {
        return;
                uint32_t *total_time;
    tasknum = uxTaskGetSystemState(p_task_array, tasknum, total_time);
                xprintf("name            id\tpri\tts\tsta\tsbase\t   smark\r\n");
    for (uint32_t i = 0; i < tasknum; i++) {
        TaskStatus_t * p_task = p_task_array + i;
        xprintf("%-16s%-8d%-8d%-8d%-8d%-8x%8d\r\n",p_task->pcTaskName,
                          p_task->xTaskNumber,
                          p_task->uxCurrentPriority,
                          p_task->ulRunTimeCounter,
        p_task->eCurrentState,
                         (uint32_t)(p_task->pxStackBase),
                          p_task->usStackHighWaterMark);
    vPortFree(p_task_array);
输入ps查看信息如下
224301rkk6tkrckxy1r9fz
三.任意内存读写
static void printmemfunc(uint8_t* param);
static void setmemfunc(uint8_t* param);
  { (uint8_t*)"printmem",     printmemfunc,     (uint8_t*)"printmem mode[hex/dec] addr[hex] len datasize[8/16/32] sig[1/0]"},
  { (uint8_t*)"setmem",       setmemfunc,       (uint8_t*)"setmem addr[hex] val[hex]"},
  uint32_t addr;
  uint32_t val;
  if(2 == sscanf((const char*)param, "%*s %x %x", &addr, &val))
    xprintf("setmem  %x %x\r\n",addr,val);
    if((addr % 4) ==0)
      *(volatile uint32_t*)addr = val;
      xprintf("%x\r\n",*(volatile uint32_t*)addr);
    else
      xprintf("addr must be mul of 4\r\n");
  uint32_t addr;
  uint32_t len;
  uint8_t mode[64];
  int datasize;
  uint8_t* tmp8_u;
  uint16_t* tmp16_u;
  uint32_t* tmp32_u;
  int8_t* tmp8_i;
  int16_t* tmp16_i;
  int32_t* tmp32_i;
  int sig;
  if(5 == sscanf((const char*)param, "%*s %s %x %d %d %d", mode, &addr, &len, &datasize, &sig))
    if(strncmp((const char*)mode,"hex", 3) == 0)
      if(datasize == 8)
        tmp8_u = (uint8_t*)addr;
        for(uint32_t i=0; i<len ;i++)
          if(i%16 == 0)
            xprintf("\r\n[%08x]:",addr+i*1);
          xprintf("%02x ",tmp8_u);
        xprintf("\r\n");
      else if(datasize == 16)
        tmp16_u = (uint16_t*)addr;
          if(i%16 == 0)
            xprintf("\r\n[%08x]:",addr+i*2);
          xprintf("%04x ",tmp16_u);
        xprintf("\r\n");
      else if(datasize == 32)
        tmp32_u = (uint32_t*)addr;
          if(i%16 == 0)
            xprintf("\r\n[%08x]:",addr+i*4);
          xprintf("%08x ",tmp32_u);
        xprintf("\r\n");
      else
        xprintf("datasize must be 8/16/32\r\n");
    else if(strncmp((const char*)mode,"dec", 3) == 0)
      if(datasize == 8)
        if(sig == 0)
            if(i%16 == 0)
              xprintf("\r\n");
            xprintf("%d ",tmp8_u);
          xprintf("\r\n");
        else
          tmp8_i = (int8_t*)addr;
            if(i%16 == 0)
              xprintf("\r\n");
            xprintf("%d ",tmp8_i);
          xprintf("\r\n");
        if(sig == 0)
            if(i%16 == 0)
              xprintf("\r\n");
            xprintf("%d ",tmp16_u);
          xprintf("\r\n");
        else
          tmp16_i = (int16_t*)addr;
            if(i%16 == 0)
              xprintf("\r\n");
            xprintf("%d ",tmp16_i);
          xprintf("\r\n");
        if(sig == 0)
            if(i%16 == 0)
              xprintf("\r\n");
            xprintf("%d ",tmp32_u);
          xprintf("\r\n");
        else
          tmp32_i = (int32_t*)addr;
            if(i%16 == 0)
              xprintf("\r\n");
            xprintf("%d ",tmp32_i);
          xprintf("\r\n");
      else
    else
      xprintf("mode must be [hex/dec]\r\n");
查看内存
printmem hex 8000000 16 32
16进制模式查看0x8000000处以32位为单位,16个数据。
224301yp6xdqldscx66ej1
写内存
setmem 20000000 11223344
往0x20000000地址处写16进制数据0x11 0x22 0x33 0x44
224301y38r3rfc8pcrtkwp
四.任意存储导入导出
static void rxmemfunc(uint8_t* param);
static void sxmemfunc(uint8_t* param);
  { (uint8_t*)"rxmem",        rxmemfunc,        (uint8_t*)"rxmem addr[hex] len"},
  { (uint8_t*)"sxmem",        sxmemfunc,        (uint8_t*)"sxmem addr[hex] len"},
实现如下
static uint32_t mem_read(uint32_t addr, uint8_t* buffer, uint32_t len)
  memcpy(buffer, (uint8_t*)addr, len);
  return len;
static uint32_t mem_write(uint32_t addr, uint8_t* buffer, uint32_t len)
  memcpy((uint8_t*)addr, buffer, len);
  return len;
  uint32_t addr;
  uint32_t len;
  int res = 0;
  if(2 == sscanf((const char*)param, "%*s %lx %ld", &addr, &len))
    xprintf("rxmem to 0x%x %d\r\n",addr,len);
    xmodem_cfg_st cfg=
        .buffer = rxtx_buf,
        .crccheck = 1,
        .getms = getms,
        .io_read = io_read,
        .io_read_flush = io_read_flush,
        .io_write = io_write,
        .start_timeout = 60,
        .packet_timeout = 1000,
        .ack_timeout = 1000,
        .mem_write = mem_write,
        .addr = addr,
        .totallen = len,
      xmodem_init_rx(&cfg);
      while((res = xmodem_rx()) == 0);
      xprintf("res:%d\r\n",res);
  uint32_t addr;
  uint32_t len;
  int res = 0;
    xprintf("sxmem to 0x%x %d\r\n",addr,len);
    xmodem_cfg_st cfg=
      .buffer = rxtx_buf,
      .plen = 1024,
      .getms = getms,
      .io_read = io_read,
      .ack_timeout = 5000,
      .mem_read = mem_read,
      .addr = addr,
      .totallen = len,
    xmodem_init_tx(&cfg);
    while((res = xmodem_tx()) == 0);
sxmem 8000000 393216
导出384kB程序
也可以导出20000000处的所有RAM的内容,所有外设的寄存器等,
导出后就可以在PC上进行仿真分析。
224301rdx9mzc2p5cdxco9
五.总结
实现完以上功能,我们的平台就具备很强的可调试,可维护,可测试性了。比如要读写任意寄存器,dump任意内存内容等等,非常方便。
