/*****************************I2C.c 文件程序源代码*******************************/
(此处省略,可参考之前章节的代码)
/***************************keyboard.c 文件程序源代码****************************/
(此处省略,可参考之前章节的代码)
/*****************************main.c 文件程序源代码******************************/
- #include <reg52.h>
- unsigned char code SinWave[] = { //正弦波波表
- 127, 152, 176, 198, 217, 233, 245, 252,
- 255, 252, 245, 233, 217, 198, 176, 152,
- 127, 102, 78, 56, 37, 21, 9, 2,
- 0, 2, 9, 21, 37, 56, 78, 102
- unsigned char code TriWave[] = { //三角波波表
- 0, 16, 32, 48, 64, 80, 96, 112,
- 128, 144, 160, 176, 192, 208, 224, 240,
- 255, 240, 224, 208, 192, 176, 160, 144,
- 128, 112, 96, 80, 64, 48, 32, 16
- unsigned char code SawWave[] = { //锯齿波表
- 0, 8, 16, 24, 32, 40, 48, 56,
- 64, 72, 80, 88, 96, 104, 112, 120,
- 128, 136, 144, 152, 160, 168, 176, 184,
- 192, 200, 208, 216, 224, 232, 240, 248
- unsigned char code *pWave; //波表指针
- unsigned char T0RH = 0; //T0 重载值的高字节
- unsigned char T0RL = 0; //T0 重载值的低字节
- unsigned char T1RH = 1; //T1 重载值的高字节
- unsigned char T1RL = 1; //T1 重载值的低字节
- void ConfigTimer0(unsigned int ms);
- void SetWaveFreq(unsigned char freq);
- extern void KeyScan();
- extern void KeyDriver();
- extern void I2CStart();
- extern void I2CStop();
- extern bit I2CWrite(unsigned char dat);
- void main(){
- EA = 1; //开总中断
- ConfigTimer0(1); //配置 T0 定时 1ms
- pWave = SinWave; //默认正弦波
- SetWaveFreq(10); //默认频率 10Hz
- while (1){
- KeyDriver(); //调用按键驱动
- /* 按键动作函数,根据键码执行相应的操作,keycode-按键键码 */
- void KeyAction(unsigned char keycode){
- static unsigned char i = 0;
- if (keycode == 0x26){ //向上键,切换波形
- //在 3 种波形间循环切换
- if (i == 0){
- i = 1;
- pWave = TriWave;
- }else if (i == 1){
- i = 2;
- pWave = SawWave;
- }else{
- i = 0;
- pWave = SinWave;
- /* 设置 DAC 输出值,val-设定值 */
- void SetDACOut(unsigned char val){
- I2CStart();
- if (!I2CWrite(0x48<<1)){ //寻址 PCF8591,如未应答,则停止操作并返回
- I2CStop();
- return;
- I2CWrite(0x40); //写入控制字节
- I2CWrite(val); //写入 DA 值
- I2CStop();
- /* 设置输出波形的频率,freq-设定频率 */
- void SetWaveFreq(unsigned char freq){
- unsigned long tmp;
- tmp = (11059200/12) / (freq*32); //定时器计数频率,是波形频率的 32 倍
- tmp = 65536 - tmp; //计算定时器重载值
- tmp = tmp + 33; //修正中断响应延时造成的误差
- T1RH = (unsigned char)(tmp>>8); //定时器重载值拆分为高低字节
- T1RL = (unsigned char)tmp;
- TMOD &= 0x0F; //清零 T1 的控制位
- TMOD |= 0x10; //配置 T1 为模式 1
- TH1 = T1RH; //加载 T1 重载值
- TL1 = T1RL;
- ET1 = 1; //使能 T1 中断
- PT1 = 1; //设置为高优先级
- TR1 = 1; //启动 T1
- /* 配置并启动 T0,ms-T0 定时时间 */
- void ConfigTimer0(unsigned int ms){
- unsigned long tmp; //临时变量
- tmp = 11059200 / 12; //定时器计数频率
- tmp = (tmp * ms) / 1000; //计算所需的计数值
- tmp = tmp + 28;//补偿中断响应延时造成的误差
- T0RH = (unsigned char)(tmp>>8); //定时器重载值拆分为高低字节
- T0RL = (unsigned char)tmp;
- TMOD &= 0xF0; //清零 T0 的控制位
- TMOD |= 0x01; //配置 T0 为模式 1
- TH0 = T0RH; //加载 T0 重载值
- TL0 = T0RL;
- ET0 = 1; //使能 T0 中断
- TR0 = 1; //启动 T0
- /* T0 中断服务函数,执行按键扫描 */
- void InterruptTimer0() interrupt 1{
- TH0 = T0RH; //重新加载重载值
- TL0 = T0RL;
- KeyScan(); //按键扫描
- /* T1 中断服务函数,执行波形输出 */
- void InterruptTimer1() interrupt 3{
- TH1 = T1RH; //重新加载重载值
- TL1 = T1RL;
- //循环输出波表中的数据
- SetDACOut(pWave);
- i++;
- if (i >= 32){
- i = 0;
- i++;
这个程序可以通过“向上”按键来实现波形输出切换,波形输出的定时刷新由定时器 T1定时来完成,改变 T1 的定时周期即可改变波形的输出频率。D/A 输出没有办法接到显示界面,所以我们用示波器抓出来波形给大家看一下,如图 17-11、图 17-12、图 17-13 所示。
图 17-11 D/A 输出正弦波形
图 17-12 D/A 输出三角波形
图 17-13 D/A 输出锯齿波形
这几张图可以直观的看到我们程序输出的波形。细心的同学会发现我们波形上有很多小锯齿,没有平滑的连起来。这是因为我们 DA 最多只能输出 0~Vref 之间的 256 个离散的电压值,而不是连续的任意值,所以每个离散值都会持续一定的时间,然后跳变到下一个离散值,于是就呈现出了波形上的这种锯齿。在实际开发中,我们只需要在 DA 后级加一级低通滤波电路,就可以让带锯齿的波形变得平滑起来。
