https://www.igorslab.de/en/what- ... x-3080-andrtx-3090/
简单来说:近期随着玩家和测试人员开始测试 RTX 3080/3090 不少人遇到不稳定和超频能力受限问题,最终发现这个与显卡背面芯片使用的 SP-CAP 电容数目负相关,凡是使用了 6 颗 SP-CAP 的显卡例如下图中的索泰 Trinity,超频能力和稳定性都是垫底:
2020-9-26 10:01 上传
创始版 FE 使用了4 颗松下 POSCAPs ,2 组MLCC:
2020-9-26 10:00 上传
NV的官方设计图只说了 AIB 可以选择使用10颗 MLCC(陶瓷贴片电容)或者使用1颗 SP-CAP (聚合物铝电容)来构成一组(一共6组) :
2020-9-26 09:58 上传
结果使用 6 颗 SP-CAP 的做法导致了上诉黑屏,超频不能的问题,这事在网上发酵了半天,又有大 V 跟进提供更多确认信息,包括 JayzTwoCents :
https://www.youtube.com/watch?v=x6bUUEEe-X8&t=1026s
他拆解了七彩虹,技嘉,EVGA XC3,只有 EVGA XC3 使用了 5 颗,其余都是 6 颗。
以及著名 Mod 玩家 buildzoid,经过他提醒,POSCAPS 是松下的注册商标,图中应该是SP-CAP:另外他也提到,所有的非公版设计都要经过 Nvidia 认证,所以你能买到的卡理论上来说 Nvidia 都是同意了的,所以这样说的话,Nvidia 应该背有主要设计责任,以及可能是三星芯片质量问题导致这个问题在批量供货后才被发现。
https://www.youtube.com/watch?v=GPFKS8jNNh0
如果只是大 V 和玩家开始猜忌显然不够分量,而事情的高潮却来自于 EVGA 的全球产品总裁 Jacob Freeman,他在10分钟前通过 EVGA 论坛 发帖正式确认了这点:
帖子中专门提到 EVGA XC3 按照标准规格设计使用了 5 颗,而 FTW3 为超频设计,使用了 4 颗,他们在批量测试时花了一周时间才发现这个问题,这也是超频版 FTW3 上市延迟的原因。
Hi all,
Recently there has been some discussion about the EVGA GeForce RTX 3080 series.
During our mass production QC testing we discovered a full 6 POSCAPs solution cannot pass the real world applications testing. It took almost a week of R&D effort to find the cause and reduce the POSCAPs to 4 and add 20 MLCC caps prior to shipping production boards, this is why the EVGA GeForce RTX 3080 FTW3 series was delayed at launch. There were no 6 POSCAP production EVGA GeForce RTX 3080 FTW3 boards shipped.
But, due to the time crunch, some of the reviewers were sent a pre-production version with 6 POSCAP’s, we are working with those reviewers directly to replace their boards with production versions.
EVGA GeForce RTX 3080 XC3 series with 5 POSCAPs + 10 MLCC solution is matched with the XC3 spec without issues.
Also note that we have updated the product pictures at EVGA.com to reflect the production components that shipped to gamers and enthusiasts since day 1 of product launch.
Once you receive the card you can compare for yourself, EVGA stands behind its products!
Thanks
EVGA
Asus Tuf,0 颗:
而其他板卡,多多少少使用了 5 到 6 个 SP-CAP,目前已知的有七彩虹,Zotac 和技嘉使用的 6 颗SP-CAP 电容
七彩虹,6 颗 SP-CAP:
影驰金属大师,5 颗(及格,但是仔细看这电容的扭曲程度,像是手工加焊的...):
微星 Game Trio X,5 颗(及格):
目前尚不知 ASUS Tuf 送测的板卡没有使用一颗 SP-CAP 究竟是运气还是提早发现了问题,从而避免了翻车,但是从目前部分商品公布的图片来看,零售版也可能使用了 6 颗 SP-CAP ,欢迎已经入手的买家提供更多信息(图片来自美蛋):
2020-9-26 10:15 上传
igorslab 的说法是至少在 6 月各个厂就收到设计图纸,但是谁用心测试了,谁没用心,这次事件就是面很好的镜子。
- Nvidia 创始版 FE 用了 4 个,说明 Nvidia 非常清楚他们在做什么,哪怕是留够余地,他们自己也没有用 6 颗方案。
- MSI,影驰,耕升,映众都用了 5 个,说明他们也是测试了,发现 6 个不靠谱,有趣的是 MSI 和同德的 3090 用了4个,说明他们不仅测试了,而且知道越高端的卡,SP-CAP 越少越好,但是 MSI 的相对高端的魔龙和万图师居然也是使用5个,这就挺奇怪了。
- EVGA 的 FTW3 和 3090 版 XC3 都用了4个,XC3 用了5个,但是其余的是也是主要爆料人,他们应该是测试得很认真,至少和 MSI 做出了殊途同归的设计选择。
- 华硕跟 EVGA 一样,出厂前进行了测试(见后面更新截图),确定是 MLCC 更能提升超频性,所以零售版全部是 MLCC。
- 技嘉,七彩虹,索泰明显是 QC 问题,这几位作为出货量很大的 AIB,居然没有察觉出问题。尤其是七彩虹,面向高端的 Advanced 正面供电都是认真补满了19相,搞了3个 8pin,却在背面电容上翻车。
这次 RTX 30系 很多AIB 都用上了背板和GPU底座镂空设计,所以很多买家直接就能从外观上看到板卡GPU(滤波)电容用料如何,也为选购带来一定的方便。
接下来应该就是等 NV 搞个 BIOS 修复,还是各家 AIB 修改设计或者当鸵鸟了。
更新:
根据部分网友的讨论,例如 SilentGrace , 粉肠 和 reddit 使用 SP-CAP 还是 MLCC 并不是成本,而是效果,两种电容都有自己最佳工作环境和支持的频率,最佳的方式可能是搭配 MLCC 和 SP-CAP。
SilentGrace: 一般情况下POSCAP一颗的价格是比10颗MLCC要贵的!POSCAP的综合性能在大多数情况下也绝对优于mlcc,但是在特殊情况下,比如1~2G左右的超高频下,POSCAP的性能可能会差于MLCC,我看到还有人说焊接成本,这个就更搞笑了,上机焊接的成本绝对都一样。目前看来可能MLCC和POSCAP搭配使用应该会效果最好。我查了一下最新的售价,SPcap 330UF/6.3V的售价是4元一颗,而22uf的0805 6.3v的mlcc售价大概是0.12元一颗,这还是去年开始大涨价后的mlcc价格。
粉肠 : MLCC并没有SP CAP值钱,而且这两个料都有自己擅长的工作场景,NV给的设计规范里面是可以选MLCC和SP CAP的,NV验证的时候也没发现什么问题,但是批量后才陆陆续续说跑高于2.03G的时候遇到CTW,AIC厂商虽然有QC上的责任,但源头还是在NV那里。
还有一个重要的原因,NV在发布前不给AIC任何跑性能测试的驱动(是的,你没看错),也没法验证windwos下的超频能力,只有在modos里面扫,AIC诟病了这个问题很久,NV一意孤行,谁叫人家牛逼呗
可见 ASUS 确实是出厂前测试了的,并且证实零售版全部是 MLCC
2020-9-27 10:12 上传
更新,楼主又看了一圈视频和开箱,大致总结了一下,欢迎网友们补充:
到目前为止(9/26/2020)
官图展示 | 送测版 | 零售版 | |
Nvidia FE RTX 3080/3090 | 遮挡 | 4颗 POSCAPs | 4颗 |
ASUS Tuf 3080/3090 | 6颗 | 0颗 | 0颗 |
ASUS ROG strix 3080/3090 | 0颗 | 0颗 | 0颗 |
七彩虹 Colorful iGame RTX 3080 Advanced | 遮挡 | 6颗 SP-CAP | 未知 |
EVGA XC3 3090 | 4颗 | 4颗 POSCAP | 4颗 |
EVGA XC3 3080 | 5颗 | 5颗 POSCAP | 5颗 |
EVGA FTW3 3080/3090 | 4颗 | 4颗 POSCAP | 4颗 |
Gigabyte 3080 Eagle/Gaming OC | 遮挡 | 6颗 SP-CAP | 6颗 |
Gigabyte 3090 Eagle/Gaming OC | 遮挡 | 未知 | 未知 |
GALAX GeForce RTX 3080 金属大师 | 遮挡 | 5颗 | 未知 |
MSI GAMING X TRIO 魔龙 3080 | 遮挡 | 5颗 | 未知 |
MSI GAMING X TRIO 魔龙 3090 | 遮挡 | 4颗 | 未知 |
MSI VENTUS 3X 万图师 3080 | 6颗 | 5颗 | 未知 |
Zotac 3080 Trinity | 6颗 | 6颗 | 6颗 |
本文来源:
https://www.chiphell.com/forum.php?mod=viewthread&tid=2262785&extra=page%3D1&mobile=2
