Micro-LED生产线,具备2-6英寸第三代半导体产业技术的中试能力。供应0.73寸Micro-LED模组,自研生产,可接受客制化欢迎联系,电话/微信:13538284956,杨生。
Screen Diagonal 0.73inch
FWHM(nm) 30±5nm
Pixel Pitch(um) 12.5umx12.5um
LED chip size(um) 9.5umx9.5um
LED Gap space(um) 3umx3um
Resolution 1300X720
Active Area(mm X mm) 16.25x9(0.73inch)
Driver Panel Size(mm X mm) 17x9.95(0.78inch)
Gray Levels 15
Gray Level control PWM
frame Rate(Hz) 60HZ
Max Panel Current(mA) 110mA
LED Voltage drop(V) 3
Max Power Input(mW) 350mW
Working Current density(A/cm2) 70A/cm2
Backplane Driving mode Digital
Max.Luminance ≥200万 nits
显示比例 16:9
更多>本企业其它产品
