QCN9074 802.11ax 4x4 2.4GHz wifi6
QCN9074 11ax 4x4 MU-MIMO 2.4G M.2
DR9074-2.4G(PN01.1)
https://www.wallystech.com/Network_Card/DR9074-2.4G-PN01.1-Wifi-6-Qualcomm-QCN9074-Single-Band-2.4-GHz-4T4R-M.2-E-Key-Interface-802.11ax.html
Wallys Communications (SuZhou) Co., Ltd., http://www.wallystech.com,which is a professional supplier specializing in product design, manufacturing and offering superior OEM/ODM/JDM services in wireless communications. As a specialized manufacturer and exporter for these products in China,We sincerely hope to establish business relations with your esteemed corporation.
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/IPQ9074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:sales3@wallystech.com
Do you like our WiFi modules and want to test samples ? No problem ! Please contact us and provide your project description!
We suply wireless Wi-Fi data and 4G 5G LTE modules worldwide. There is no continent, where we would not have a satisfied customer! Yes, we have already supplied our Wi-Fi modules in Antarctica! You can find our modules, for example, in wind turbines, drones, ships, aircraft, both civil, acrobatic and military… on land, on water and in the air. NASA has also ordered samples, so the next goal is to get them into the outer Space!
Features
■ Qualcomm Atheros QCN9074
■ 2.4GHz, max 23dBm per chain, up to 1147Mbps
■ Single Band 2.4GHz 4x4 WiFi 6 (802.11ax
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
Absolute Maximum Rating |
Parameter | Rating | Unit |
Operating Temperature Range | -20 to 70 | ºC |
Storage Temperature Range | -40 to 90 | ºC |
Operating Humidity Range | 5 to +95 (non-condensing) | % |
Storage Humidity Range | 0 to +90 (non-condensing) | % |
Hardware Specifications |
Symbol | Parameter |
Chipset | Qualcomm Atheros QCN9074 |
WLAN Host Interface | PCI Express 3.0 Interface |
System Memory | 2Mbit serial I²C bus EEPROM |
Standard Operating Voltage | 5V |
Operating Systems | QSDK |
Host Interface | M.2 E Key |
Antenna Cable / Port | 4 x MMCX Connectors,4T4R |
Frequency Range | 2.412GHz-2.472GHz |
Data Rates for WALN | 2.4GHz, max 23dBm per chain, up to 4949Mbps |
Channel Spectrum Widths for WLAN | Support 20/40MHz at 2.4GHz |
Modulation Techniques | OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM |
Temperature Range | Operating: -20°C to 70°C, Storage: -40°C to 90°C |
Humidity | Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing) |
Certification | TBD |
Power Consumption | TBD |
Reference Design | PN01.1 |
Dimensions (WxHxD) | 57mm x 63mm x 6mm |
