PL83251,36V,2.4A 降压DC-DC转换器
233
发表于 2023-6-7 16:34:25
36V,2.4A Monolithic Step-Down Switching Regulator1、Features
2.4A continuous output current capability
6.5V to 36V wide operating input range with 33V input Over Voltage Protection
Integrated 36V, 108mΩ high side and 36V, 102mΩ low side power MOSFET switches
Up to 95% efficiency
Internally fixed 3A constant current control
Programmable Soft-Start limits the inrush current at turn-on
Stable with Low ESR Ceramic Output Capacitors
Fixed 500KHz Switching Frequency
Input Under-Voltage Lockout. Output Over-VoltageProtection
Over-Temperature Protection
Thermally Enhanced ESOP-8 Package
| 2、Applications
3、Description
The PL83251 is a monolithic 36V, 2.4A step-down switching regulator with CC/CV control loop. PL83251 integrates a high efficiency synchronous step-down switching regulator, which includes a 36V 108mΩ high side and a 36V, 102mΩ low side MOSFETs to provide 2.4A continuous load current over a 6.5V to 36V wide operating input voltage. Peak current mode control provides fast transient responses and cycle-by-cycle current limiting.Programmable soft-start prevents inrush current at power-up. The supply current drops below 1μA in shutdown mode. |
4、Typical Application Schematic & Efficiency | 5、Pin Configuration and Functions |
原厂代理,更多详情请咨询 深圳市芯美力科技有限公司 黄先生:19928739245(微同) QQ:541777848
