S32K144 自身NorFlash读写,在NXP官方编译器S32 Design Studio for ARM Version 2018.R1(需要打补丁跟新到 RTM2.0版SDK)直接编译。该串口代码与官方库不冲突,可继续使用官方提供的便利工具,IO和Uart模块的可视化配置,并且实现Uart方便的中断接受,不丢失。从FIFO中直接提取数据,改善官方SDK库效读取率低,操作不方便等问题。
单片机源程序如下:
/* ###################################################################** Filename : main.c ** Processor : S32K14x ** Abstract : ** Main module. ** This module contains user's application code. ** Settings : ** Contents : ** No public methods ** ** ###################################################################*/ /* MODULE main */ /* Including necessary module. Cpu.h contains other modules needed for compiling.*/ #include "Cpu.h" /* User includes (#include below this line is not maintained by Processor Expert) */ #include "common.h" /*! \brief The main function for the project. \details The startup initialization sequence is the following: */ int main(void) { /* Write your local variable definition here */ /*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/ #ifdef PEX_RTOS_INIT PEX_RTOS_INIT(); /* Initialization of the selected RTOS. Macro is defined by the RTOS component. */ #endif /*** End of Processor Expert internal initialization. ***/ BoardInit(); UART_Text(); while(1){ OSIF_TimeDelay(1000); }; return 0; } /* END main */
复制代码
