以下是对给定代码的逐行注释:
```c
* @file    main.c
* @brief   main C file
* @date    16 Feb. 2023
* @author  AE Team
* @note
*          Change Logs:
*          Date            Author          Notes
*          16 Feb. 2023    Lisq            the first version
* Copyright (C) Shanghai Eastsoft Microelectronics Co. Ltd. All rights reserved.
* SPDX-License-Identifier: Apache-2.0
* Licensed under the Apache License, Version 2.0 (the License); you may
* not use this file except in compliance with the License.
* You may obtain a copy of the License at
* www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an AS IS BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
/* Includes ------------------------------------------------------------------ */
#include "main.h"
/* Private Macros ------------------------------------------------------------ */
/* Private Variables --------------------------------------------------------- */
/* Public Variables ---------------------------------------------------------- */
/* Private Constants --------------------------------------------------------- */
/* Private function prototypes ----------------------------------------------- */
/* Private Function ---------------------------------------------------------- */
/** @addtogroup Projects_Examples_ALD
/** @addtogroup Examples
  * @brief  初始化USART模块的引脚。
  * @retval None
static void gpio_init(void)
    ald_gpio_init_t gpio_init;
    /* 初始化gpio_init结构体 */
    memset(&gpio_init, 0x0, sizeof(gpio_init));
    /* 初始化LED引脚 */
    gpio_init.mode  = ALD_GPIO_MODE_OUTPUT; // 设置模式为输出
    gpio_init.od    = ALD_GPIO_PUSH_PULL;   // 设置OD为推挽模式
    gpio_init.pupd  = ALD_GPIO_FLOATING;       // 设置PUPD为浮空输入
    gpio_init.odrv  = ALD_GPIO_OUT_DRIVE_NORMAL; // 设置驱动强度为正常
    gpio_init.flt   = ALD_GPIO_FILTER_DISABLE; // 禁用滤波器
    gpio_init.type  = ALD_GPIO_TYPE_CMOS;     // 设置类型为CMOS
    gpio_init.func  = ALD_GPIO_FUNC_1;        // 设置功能为通用功能1
    ald_gpio_init(LED_PORT, LED_PIN, &gpio_init); // 初始化LED引脚
    /* 再次初始化gpio_init结构体 */
    /* 初始化KEY引脚 */
    gpio_init.mode  = ALD_GPIO_MODE_INPUT; // 设置模式为输入
    gpio_init.pupd  = ALD_GPIO_PUSH_DOWN; // 设置PUPD为下拉输入
    ald_gpio_init(KEY_PORT, KEY_PIN, &gpio_init); // 初始化KEY引脚
    return;
  * @brief: 主程序入口点。
  * @param: None
  * @retval: None
int main(void)
    /* 初始化ALD系统时钟管理单元(CMU) */
    ald_cmu_init();
    /* 配置系统时钟 */
    ald_cmu_pll_config(ALD_CMU_PLL_INPUT_HOSC8M, ALD_CMU_PLL_OUTPUT_72M); // 配置PLL输入和输出频率
    ald_cmu_clock_config(ALD_CMU_CLOCK_PLL, 72000000); // 设置系统时钟为72MHz
    /* 使能所有外设时钟 */
    ald_cmu_perh_clock_config(ALD_CMU_PERH_ALL, ENABLE);
    /* 初始化引脚 */
    gpio_init();
    while (1)
        /* 如果按键按下,点亮LED */
        if (ald_gpio_read_pin(KEY_PORT, KEY_PIN))
            ald_gpio_write_pin(LED_PORT, LED_PIN, 1); // 写入高电平,点亮LED
        else
            ald_gpio_write_pin(LED_PORT, LED_PIN, 0); // 写入低电平,熄灭LED
/************* (C) COPYRIGHT Eastsoft Microelectronics *****END OF FILE****/
