在ME32G030开发板上,缺少必要的显示器件,为此为其配置了一个I2C接口的OLED屏来进行信息的显示。
该显示屏为准双色显示屏,其分辨率为126*64像素点,显示屏与开发板的连接关系为:
SCLK---PC1
SDIN---PC2
为在驱动OLED屏的同时来掌握GPIO口的使用,特采用模拟的方式来实现。
为便于控制高低电平的输出,对这两个引脚的输出语句定义如下:
#define OLED_SCLK_Clr() PC->CLR_b.CLR1=1
#define OLED_SCLK_Set() PC->SET_b.SET1=1
#define OLED_SDIN_Clr() PC->CLR_b.CLR2=1
#define OLED_SDIN_Set() PC->SET_b.SET2=1
实现I2C字节数据发送的函数为:
<pre>void Write_IIC_Byte(unsigned char IIC_Byte)
unsigned char i;
unsigned char m,da;
da=IIC_Byte;
OLED_SCLK_Clr();
for(i=0;i<8;i++)
m=da;
m=m&0x80;
if(m==0x80)
OLED_SDIN_Set();
else
OLED_SDIN_Clr();
da=da<<1;
OLED_SCLK_Set();
OLED_SCLK_Clr();
}</pre>
复制代码实现屏幕清除的函数为:
<pre>void OLED_Clear(void)
uint8_t i,n;
for(i=0;i<8;i++)
OLED_WR_Byte (0xb0+i,OLED_CMD);
OLED_WR_Byte (0x00,OLED_CMD);
OLED_WR_Byte (0x10,OLED_CMD);
for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
}</pre>
复制代码实现字符显示的函数为:
<pre>void OLED_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size)
unsigned char c=0,i=0;
c=chr-' ';
if(x>Max_Column-1)
x=0;
y=y+2;
if(Char_Size ==16)
OLED_Set_Pos(x,y);
for(i=0;i<8;i++)
OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
OLED_Set_Pos(x,y+1);
for(i=0;i<8;i++)
OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
else
OLED_Set_Pos(x,y);
for(i=0;i<6;i++)
OLED_WR_Byte(F6x8[c][i],OLED_DATA);
}</pre>
复制代码实现字符串显示的函数为:
<pre>void OLED_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t Char_Size)
unsigned char j=0;
while (chr[j]!='\0')
OLED_ShowChar(x,y,chr[j],Char_Size);
x+=8;
if(x>120)
x=0;
y+=2;
j++;
}</pre>
复制代码对OLED屏的初始化函数为:
<pre>void OLED_Init(void)
Write_IIC_Command(0xAE);
Write_IIC_Command(0x20);
Write_IIC_Command(0x10);
Write_IIC_Command(0xb0);
Write_IIC_Command(0xc8);
Write_IIC_Command(0x00);
Write_IIC_Command(0x40);
Write_IIC_Command(0x81);
Write_IIC_Command(0xdf);
Write_IIC_Command(0xa1);
Write_IIC_Command(0xa6);
Write_IIC_Command(0xa8);
Write_IIC_Command(0x3F);
Write_IIC_Command(0xa4);
Write_IIC_Command(0xd3);
Write_IIC_Command(0xd5);
Write_IIC_Command(0xf0);
Write_IIC_Command(0xd9);
Write_IIC_Command(0x22);
Write_IIC_Command(0xda);
Write_IIC_Command(0x12);
Write_IIC_Command(0xdb);
Write_IIC_Command(0x8d);
Write_IIC_Command(0x14);
Write_IIC_Command(0xaf);
}</pre>
复制代码实现测试的主程序为:
<pre>int main(void)
PB12_INIT(PB12_GPIO);
PB->DIR_b.DIR12 = 0x1;
PC1_INIT(PC1_GPIO);
PC2_INIT(PC2_GPIO);
PC->DIR_b.DIR1 = 0x1;
PC->DIR_b.DIR2 = 0x1;
OLED_Init();
OLED_Clear();
OLED_ShowString(0,0,"ME32G030 ",16);
OLED_ShowString(0,2,"OLED TEST",16);
while(1);
}</pre>
复制代码经程序的编译与下载,其测试的显示效果如下图所示,说明显示驱动有效!
显示效果图
在后续的测评中,将尽可能地发挥该显示屏的显示作用。
