前言
前面我们实现了串口驱动,为了更方便的进行交互,我们来移植一个轻量级的标准输入输出库。
参考公众号文章
https://mp.weixin.qq.com/s/y4MHV3cd4T0b51L5M4J5Xg
实现
添加如下文件
234628xj74k986b48tkk0k
Xprintf.c如下
/  Universal String Handler for Console Input and Output
/ Copyright (C) 2021, ChaN, all right reserved.
/ xprintf module is an open source software. Redistribution and use of
/ xprintf module in source and binary forms, with or without modification,
/ are permitted provided that the following condition is met:
/ 1. Redistributions of source code must retain the above copyright notice,
/    this condition and the following disclaimer.
/ This software is provided by the copyright holder and contributors "AS IS"
/ and any warranties related to this software are DISCLAIMED.
/ The copyright owner or contributors be NOT LIABLE for any damages caused
/ by use of this software.
#include "xprintf.h"
#define SZB_OUTPUT        32
#if XF_USE_OUTPUT
#include <stdarg.h>
void (*xfunc_output)(int);        /* Pointer to the default output device */
static char *strptr;                /* Pointer to the output memory (used by xsprintf) */
#if XF_USE_FP
/* Floating point output                        */
#include <math.h>
static int ilog10 (double n)        /* Calculate log10(n) in integer output */
        int rv = 0;
        while (n >= 10) {        /* Decimate digit in right shift */
                if (n >= 100000) {
                        n /= 100000; rv += 5;
                } else {
                        n /= 10; rv++;
        while (n < 1) {                /* Decimate digit in left shift */
                if (n < 0.00001) {
                        n *= 100000; rv -= 5;
                } else {
                        n *= 10; rv--;
        return rv;
static double i10x (int n)        /* Calculate 10^n */
        double rv = 1;
        while (n > 0) {                /* Left shift */
                if (n >= 5) {
                        rv *= 100000; n -= 5;
                } else {
                        rv *= 10; n--;
        while (n < 0) {                /* Right shift */
                if (n <= -5) {
                        rv /= 100000; n += 5;
                } else {
                        rv /= 10; n++;
        return rv;
static void ftoa (
        char* buf,        /* Buffer to output the generated string */
        double val,        /* Real number to output */
        int prec,        /* Number of fractinal digits */
        char fmt        /* Notation */
        int d;
        int e = 0, m = 0;
        char sign = 0;
        double w;
        const char *er = 0;
        if (isnan(val)) {                        /* Not a number? */
                er = "NaN";
        } else {
                if (prec < 0) prec = 6;        /* Default precision (6 fractional digits) */
                if (val < 0) {                        /* Nagative value? */
                        val = -val; sign = '-';
                } else {
                        sign = '+';
                if (isinf(val)) {                /* Infinite? */
                        er = "INF";
                } else {
                        if (fmt == 'f') {        /* Decimal notation? */
                                val += i10x(-prec) / 2;        /* Round (nearest) */
                                m = ilog10(val);
                                if (m < 0) m = 0;
                                if (m + prec + 3 >= SZB_OUTPUT) er = "OV";        /* Buffer overflow? */
                        } else {                        /* E notation */
                                if (val != 0) {                /* Not a true zero? */
                                        val += i10x(ilog10(val) - prec) / 2;        /* Round (nearest) */
                                        e = ilog10(val);
                                        if (e > 99 || prec + 6 >= SZB_OUTPUT) {        /* Buffer overflow or E > +99? */
                                                er = "OV";
                                        } else {
                                                if (e < -99) e = -99;
                                                val /= i10x(e);        /* Normalize */
                if (!er) {        /* Not error condition */
                        if (sign == '-') *buf++ = sign;        /* Add a - if negative value */
                        do {                                /* Put decimal number */
                                w = i10x(m);                                /* Snip the highest digit d */
                                d = val / w; val -= d * w;
                                if (m == -1) *buf++ = XF_DPC;        /* Insert a decimal separarot if get into fractional part */
                                *buf++ = '0' + d;                        /* Put the digit */
                        } while (--m >= -prec);                        /* Output all digits specified by prec */
                        if (fmt != 'f') {        /* Put exponent if needed */
                                *buf++ = fmt;
                                if (e < 0) {
                                        e = -e; *buf++ = '-';
                                } else {
                                        *buf++ = '+';
                                *buf++ = '0' + e / 10;
                                *buf++ = '0' + e % 10;
        if (er) {        /* Error condition? */
                if (sign) *buf++ = sign;                /* Add sign if needed */
                do *buf++ = *er++; while (*er);        /* Put error symbol */
        *buf = 0;        /* Term */
#endif        /* XF_USE_FLOAT */
/* Put a character                              */
void xputc (
        int chr                                /* Character to be output */
        xfputc(xfunc_output, chr);        /* Output it to the default output device */
void xfputc (                        /* Put a character to the specified device */
        void(*func)(int),        /* Pointer to the output function (null:strptr) */
        if (XF_CRLF && chr == '\n') xfputc(func, '\r');        /* CR -> CRLF */
        if (func) {
                func(chr);                /* Write a character to the output device */
        } else if (strptr) {
                 *strptr++ = chr;        /* Write a character to the memory */
/* Put a null-terminated string                 */
void xputs (                        /* Put a string to the default device */
        const char* str                /* Pointer to the string */
        xfputs(xfunc_output, str);
void xfputs (                        /* Put a string to the specified device */
        void(*func)(int),        /* Pointer to the output function */
        while (*str) {                        /* Put the string */
                xfputc(func, *str++);
/* Formatted string output                      */
/*  xprintf("%d", 1234);                        "1234"
    xprintf("%6d,%3d%%", -200, 5);        "  -200,  5%"
    xprintf("%-6u", 100);                        "100   "
    xprintf("%ld", 12345678);                "12345678"
    xprintf("%llu", 0x100000000);        "4294967296"        <XF_USE_LLI>
    xprintf("%lld", -1LL);                        "-1"                        <XF_USE_LLI>
    xprintf("%04x", 0xA3);                        "00a3"
    xprintf("%08lX", 0x123ABC);                "00123ABC"
    xprintf("%016b", 0x550F);                "0101010100001111"
    xprintf("%*d", 6, 100);                        "   100"
    xprintf("%s", "String");                "String"
    xprintf("%5s", "abc");                        "  abc"
    xprintf("%-5s", "abc");                        "abc  "
    xprintf("%-5s", "abcdefg");                "abcdefg"
    xprintf("%-5.5s", "abcdefg");        "abcde"
    xprintf("%-.5s", "abcdefg");        "abcde"
    xprintf("%-5.5s", "abc");                "abc  "
    xprintf("%c", 'a');                                "a"
    xprintf("%12f", 10.0);                        "   10.000000"        <XF_USE_FP>
    xprintf("%.4E", 123.45678);                "1.2346E+02"        <XF_USE_FP>
static void xvfprintf (
        const char*        fmt,        /* Pointer to the format string */
        va_list arp                        /* Pointer to arguments */
        unsigned int r, i, j, w, f;
        int n, prec;
        char str[SZB_OUTPUT], c, d, *p, pad;
#if XF_USE_LLI
        long long v;
        unsigned long long uv;
#else
        long v;
        unsigned long uv;
#endif
        for (;;) {
                c = *fmt++;                                        /* Get a format character */
                if (!c) break;                                /* End of format? */
                if (c != '%') {                                /* Pass it through if not a % sequense */
                        xfputc(func, c); continue;
                f = w = 0;                                         /* Clear parms */
                pad = ' '; prec = -1;
                c = *fmt++;                                        /* Get first char of the sequense */
                if (c == '0') {                                /* Flag: left '0' padded */
                        pad = '0'; c = *fmt++;
                } else {
                        if (c == '-') {                        /* Flag: left justified */
                                f = 2; c = *fmt++;
                if (c == '*') {                                /* Minimum width from an argument */
                        n = va_arg(arp, int);
                        if (n < 0) {                        /* Flag: left justified */
                                n = 0 - n; f = 2;
                        w = n; c = *fmt++;
                } else {
                        while (c >= '0' && c <= '9') {        /* Minimum width */
                                w = w * 10 + c - '0';
                                c = *fmt++;
                if (c == '.') {                                /* Precision */
                        c = *fmt++;
                        if (c == '*') {                                /* Precision from an argument */
                                prec = va_arg(arp, int);
                                c = *fmt++;
                        } else {
                                prec = 0;
                                        prec = prec * 10 + c - '0';
                                        c = *fmt++;
                if (c == 'l') {                /* Prefix: Size is long */
                        f |= 4; c = *fmt++;
#if XF_USE_LLI
                        if (c == 'l') {        /* Prefix: Size is long long */
                                f |= 8; c = *fmt++;
#endif
                switch (c) {                                /* Type is... */
                case 'b':                                        /* Unsigned binary */
                        r = 2; break;
                case 'o':                                        /* Unsigned octal */
                        r = 8; break;
                case 'd':                                        /* Signed decimal */
                case 'u':                                        /* Unsigned decimal */
                        r = 10; break;
                case 'x':                                        /* Hexdecimal (lower case) */
                case 'X':                                        /* Hexdecimal (upper case) */
                        r = 16; break;
                case 'c':                                        /* A character */
                        xfputc(func, (char)va_arg(arp, int)); continue;
                case 's':                                        /* String */
                        p = va_arg(arp, char*);                /* Get a pointer argument */
                        if (!p) p = "";                                /* Null ptr generates a null string */
                        j = strlen(p);
                        if (prec >= 0 && j > (unsigned int)prec) j = prec;        /* Limited length of string body */
                        for ( ; !(f & 2) && j < w; j++) xfputc(func, pad);        /* Left pads */
                        while (*p && prec--) xfputc(func, *p++);/* String body */
                        while (j++ < w) xfputc(func, ' ');                /* Right pads */
                        continue;
#if XF_USE_FP
                case 'f':                                        /* Float (decimal) */
                case 'e':                                        /* Float (e) */
                case 'E':                                        /* Float (E) */
                        ftoa(p = str, va_arg(arp, double), prec, c);        /* Make fp string */
                        for (j = strlen(p); !(f & 2) && j < w; j++) xfputc(func, pad);        /* Left pads */
                        while (*p) xfputc(func, *p++);                /* Value */
                        continue;
#endif
                default:                                        /* Unknown type (passthrough) */
                /* Get an integer argument and put it in numeral */
#if XF_USE_LLI
                if (f & 8) {        /* long long argument? */
                        v = (long long)va_arg(arp, long long);
                } else {
                        if (f & 4) {        /* long argument? */
                                v = (c == 'd') ? (long long)va_arg(arp, long) : (long long)va_arg(arp, unsigned long);
                        } else {                /* int/short/char argument */
                                v = (c == 'd') ? (long long)va_arg(arp, int) : (long long)va_arg(arp, unsigned int);
#else
                        v = (long)va_arg(arp, long);
                        v = (c == 'd') ? (long)va_arg(arp, int) : (long)va_arg(arp, unsigned int);
#endif
                if (c == 'd' && v < 0) {        /* Negative value? */
                        v = 0 - v; f |= 1;
                i = 0; uv = v;
                do {        /* Make an integer number string */
                        d = (char)(uv % r); uv /= r;
                        if (d > 9) d += (c == 'x') ? 0x27 : 0x07;
                        str[i++] = d + '0';
                } while (uv != 0 && i < sizeof str);
                if (f & 1) str[i++] = '-';                                        /* Sign */
                for (j = i; !(f & 2) && j < w; j++) xfputc(func, pad);        /* Left pads */
                do xfputc(func, str[--i]); while (i != 0);        /* Value */
void xprintf (                        /* Put a formatted string to the default device */
        ...                                        /* Optional arguments */
        va_list arp;
        va_start(arp, fmt);
        xvfprintf(xfunc_output, fmt, arp);
        va_end(arp);
void xfprintf (                        /* Put a formatted string to the specified device */
        va_list arp;
        va_start(arp, fmt);
        xvfprintf(func, fmt, arp);
        va_end(arp);
void xsprintf (                        /* Put a formatted string to the memory */
        char* buff,                        /* Pointer to the output buffer */
        va_list arp;
        strptr = buff;                /* Enable destination for memory */
        va_start(arp, fmt);
        xvfprintf(0, fmt, arp);
        va_end(arp);
        *strptr = 0;                /* Terminate output string */
        strptr = 0;                        /* Disable destination for memory */
#if XF_USE_DUMP
/* Dump a line of binary dump                   */
void put_dump (
        const void* buff,                /* Pointer to the array to be dumped */
        unsigned long addr,                /* Heading address value */
        int len,                                /* Number of items to be dumped */
        size_t width                        /* Size of buff[0] (1, 2 or 4) */
        int i;
        const unsigned char *bp;
        const unsigned short *sp;
        const unsigned long *lp;
        xprintf("%08lX ", addr);                /* address */
        switch (width) {
        case sizeof (char):
                bp = buff;
                for (i = 0; i < len; i++) {                /* Hexdecimal dump in (char) */
                        xprintf(" %02X", bp);
                xputs("  ");
                for (i = 0; i < len; i++) {                /* ASCII dump */
                        xputc((unsigned char)((bp >= ' ' && bp <= '~') ? bp : '.'));
                break;
        case sizeof (short):
                sp = buff;
                do {                                                        /* Hexdecimal dump in (short) */
                        xprintf(" %04X", *sp++);
                } while (--len);
                break;
        case sizeof (long):
                lp = buff;
                        xprintf(" %08lX", *lp++);
                } while (--len);
                break;
        xputc('\n');
#endif        /* XF_USE_DUMP */
#endif        /* XF_USE_OUTPUT */
#if XF_USE_INPUT
int (*xfunc_input)(void);        /* Pointer to the default input stream */
/* Get a line from the input                    */
int xgets (                        /* 0:End of stream, 1:A line arrived */
        char* buff,                /* Pointer to the buffer */
        int len                        /* Buffer length */
        int c, i;
        if (!xfunc_input) return 0;        /* No input function is specified */
        i = 0;
        for (;;) {
                c = xfunc_input();                        /* Get a char from the incoming stream */
                if (c < 0 || c == '\r') break;        /* End of stream or CR? */
                if (c == '\b' && i) {                /* BS? */
                        i--;
                        if (XF_INPUT_ECHO) xputc(c);
                        continue;
                if (c >= ' ' && i < len - 1) {        /* Visible chars? */
                        buff[i++] = c;
        if (XF_INPUT_ECHO) {
                xputc('\r');
                xputc('\n');
        buff = 0;        /* Terminate with a \0 */
        return (int)(c == '\r');
/* Get a value of integer string                */
/*        "123 -5   0x3ff 0b1111 0377  w "
            ^                           1st call returns 123 and next ptr
               ^                        2nd call returns -5 and next ptr
                   ^                3rd call returns 1023 and next ptr
                          ^         4th call returns 15 and next ptr
                               ^    5th call returns 255 and next ptr
                                  ^ 6th call fails and returns 0
int xatoi (                        /* 0:Failed, 1:Successful */
        char **str,                /* Pointer to pointer to the string */
        long *res                /* Pointer to the valiable to store the value */
        unsigned long val;
        unsigned char c, r, s = 0;
        *res = 0;
        while ((c = **str) == ' ') (*str)++;        /* Skip leading spaces */
        if (c == '-') {                /* negative? */
                s = 1;
                c = *(++(*str));
        if (c == '0') {
                c = *(++(*str));
                switch (c) {
                case 'x':                /* hexdecimal */
                        r = 16; c = *(++(*str));
                        break;
                case 'b':                /* binary */
                        r = 2; c = *(++(*str));
                        break;
                default:
                        if (c <= ' ') return 1;        /* single zero */
                        if (c < '0' || c > '9') return 0;        /* invalid char */
                        r = 8;                /* octal */
        } else {
                if (c < '0' || c > '9') return 0;        /* EOL or invalid char */
                r = 10;                        /* decimal */
        val = 0;
        while (c > ' ') {
                if (c >= 'a') c -= 0x20;
                c -= '0';
                if (c >= 17) {
                        c -= 7;
                        if (c <= 9) return 0;        /* invalid char */
                if (c >= r) return 0;                /* invalid char for current radix */
                val = val * r + c;
                c = *(++(*str));
        if (s) val = 0 - val;                        /* apply sign if needed */
        *res = val;
        return 1;
#if XF_USE_FP
/* Get a value of the real number string        */
/* Float version of xatoi
int xatof (                        /* 0:Failed, 1:Successful */
        double *res                /* Pointer to the valiable to store the value */
        double val;
        int s, f, e;
        unsigned char c;
        *res = 0;
        s = f = 0;
        if (c == '-') {                        /* Negative? */
                c = *(++(*str)); s = 1;
        } else if (c == '+') {        /* Positive? */
                c = *(++(*str));
        if (c == XF_DPC) {                /* Leading dp? */
                f = -1;                         /* Start at fractional part */
                c = *(++(*str));
        if (c <= ' ') return 0;        /* Wrong termination? */
        val = 0;
        while (c > ' ') {                /* Get a value of decimal */
                if (c == XF_DPC) {        /* Embedded dp? */
                        if (f < 0) return 0;        /* Wrong dp? */
                        f = -1;                        /* Enter fractional part */
                } else {
                        if (c < '0' || c > '9') break;        /* End of decimal? */
                        c -= '0';
                        if (f == 0) {        /* In integer part */
                                val = val * 10 + c;
                        } else {                /* In fractional part */
                                val += i10x(f--) * c;
                c = *(++(*str));
        if (c > ' ') {        /* It may be an exponent */
                if (c != 'e' && c != 'E') return 0;        /* Wrong character? */
                c = *(++(*str));
                if (c == '-') {
                        c = *(++(*str)); s |= 2;        /* Negative exponent */
                        c = *(++(*str));                        /* Positive exponent */
                e = 0;
                while (c > ' ') {                /* Get value of exponent */
                        c -= '0';
                        if (c > 9) return 0;        /* Not a numeral? */
                        e = e * 10 + c;
                        c = *(++(*str));
                val *= i10x((s & 2) ? -e : e);        /* Apply exponent */
        if (s & 1) val = -val;        /* Negate sign if needed */
        *res = val;
        return 1;
#endif /* XF_USE_FP */
#endif /* XF_USE_INPUT */
Xprintf.h如下
/* Universal string handler for user console interface  (C)ChaN, 2021     */
#ifndef XPRINTF_DEF
#define XPRINTF_DEF
#include <string.h>
#ifdef __cplusplus
extern "C" {
#endif
#define XF_USE_OUTPUT        1        /* 1: Enable output functions */
#define        XF_CRLF                        1        /* 1: Convert \n ==> \r\n in the output char */
#define        XF_USE_DUMP                1        /* 1: Enable put_dump function */
#define        XF_USE_LLI                1        /* 1: Enable long long integer in size prefix ll */
#define        XF_USE_FP                1        /* 1: Enable support for floating point in type e and f */
#define XF_DPC                        '.'        /* Decimal separator for floating point */
#define XF_USE_INPUT        1        /* 1: Enable input functions */
#define        XF_INPUT_ECHO        0        /* 1: Echo back input chars in xgets function */
#if defined(__GNUC__) && __GNUC__ >= 10
#pragma GCC diagnostic ignored "-Wcast-function-type"
#endif
#if XF_USE_OUTPUT
#define xdev_out(func) xfunc_output = (void(*)(int))(func)
extern void (*xfunc_output)(int);
void xputc (int chr);
void xfputc (void (*func)(int), int chr);
void xputs (const char* str);
void xfputs (void (*func)(int), const char* str);
void xprintf (const char* fmt, ...);
void xsprintf (char* buff, const char* fmt, ...);
void xfprintf (void (*func)(int), const char* fmt, ...);
void put_dump (const void* buff, unsigned long addr, int len, size_t width);
#endif
#if XF_USE_INPUT
#define xdev_in(func) xfunc_input = (int(*)(void))(func)
extern int (*xfunc_input)(void);
int xgets (char* buff, int len);
int xatoi (char** str, long* res);
int xatof (char** str, double* res);
#endif
#ifdef __cplusplus
#endif
#endif
测试
Main.c中
适配接口
static void xprintf_out_port(int ch)
uint8_t val = ch;
uart_send(0,&val,1);
static int xprintf_in_port(void)
uint32_t len;
uint8_t val;
do
len = uart_read(0,&val,1);
}while(len == 0);
return val;
初始化指定接口
xdev_out(xprintf_out_port);
xdev_in(xprintf_in_port);
测试代码
static void xprintf_test(void)
    xprintf("%d\r\n", 1234);             /* "1234" */
    xprintf("%6d,%3d%%\r\n", -200, 5);   /* "  -200,  5%" */
    xprintf("%-6u\r\n", 100);            /* "100   " */
    xprintf("%ld\r\n", 12345678);        /* "12345678" */
    xprintf("%llu\r\n", 0x100000000);    /* "4294967296"   <XF_USE_LLI> */
    xprintf("%lld\r\n", -1LL);           /* "-1"           <XF_USE_LLI> */
    xprintf("%04x\r\n", 0xA3);           /* "00a3" */
    xprintf("%08lX\r\n", 0x123ABC);      /* "00123ABC" */
    xprintf("%016b\r\n", 0x550F);        /* "0101010100001111" */
    xprintf("%*d\r\n", 6, 100);          /* "   100" */
    xprintf("%s\r\n", "abcdefg");        /* "abcdefg" */
    xprintf("%5s\r\n", "abc");           /* "  abc" */
    xprintf("%-5s\r\n", "abc");          /* "abc  " */
    xprintf("%.5s\r\n", "abcdefg");      /* "abcde" */
    xprintf("%-5.2s\r\n", "abcdefg");    /* "ab   " */
    xprintf("%c\r\n", 'a');              /* "a" */
    xprintf("%12f\r\n", 10.0);           /* "   10.000000" <XF_USE_FP> */
    xprintf("%.4E\r\n", 123.45678);      /* "1.2346E+02"   <XF_USE_FP> */
打印如下
234628e8qxpprx3wn28pow
总结
以上移植了xprintf可以方便的进行输入输出,打印调试信息等,为后面开发做准备。
