#include<reg52.h>
#define DataPort P0
#include <intrins.h>
sbit LATCH1=P2^2;
sbit LATCH2=P2^3;//                 位锁存
sbit LED=P2^0;
unsigned int b;
unsigned char num=12;
unsigned char code dofly_DuanMa[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};// 显示段码值0~9
unsigned char code dofly_WeiMa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//分别对应相应的数码管点亮,即位码
unsigned char TempData[8]; //存储显示值的全局变量
//unsigned char kjh[3]={0,1,1};
void Delay(unsigned int t); //函数声明
void Display(unsigned char FirstBit,unsigned char Num);
void TIM2Inital(void)
  RCAP2H = (65536-60000)/256;//
  RCAP2L = (65536-60000)%256;
  ET2=1;                     //打开定时器中断
  EA=1;                      //打开总中断
  TR2=1;                     //打开定时器开关
main()
unsigned int j,jj=1;
//if( TempData[1]==0x5b)
TIM2Inital();
P1=0XFE;
while(1)
           j++; if(j==100)
                  j=0;
                  if(num>0) num--;
                   else     {num=10;
                   P1=_crol_(P1,1);
                   while(P1==0xf7)
                   {P1=0XFE; }
           TempData[0]=dofly_DuanMa[num/10];//
           TempData[1]=dofly_DuanMa[num%10];
           Display(1,2);
while(--t);
      unsigned char i;
          for(i=0;i<Num;i++)
           DataPort=0;   //清空数据,防止有交替重影
       LATCH1=1;     //段锁存
       LATCH1=0;
       DataPort=dofly_WeiMa[i+FirstBit]; //取位码
       LATCH2=1;     //位锁存
       LATCH2=0;
       DataPort=TempData[i]; //取显示数据,段码
       LATCH1=1;     //段锁存
       LATCH1=0;
           Delay(10); //
void TIM2(void) interrupt 5 using 1
    RCAP2H = (65536-100)/256;//
  RCAP2L = (65536-100)%256;
  b++;
  if(b>=60000)
  {b=0x00;
     TF2=0;
  }                    if(num<=3)LED=~ LED;
                //指示灯反相
