注意:在使用前请先确认跳线帽安装是否正确。(开发板出厂前已经按照默认状态安装了跳线帽,貌似J6/J5插错了。需要将跳线帽从J6换到J5)如图红色小框为跳线帽。
1.用2个micro USB连接线连接电脑的USB端口到板子的CN1和CN2口,电脑会识别到设备并自动安装驱动程序,请耐心等待几分钟…
或手动下载:
https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
https://toshiba-semicon-storage.com/cn/product/microcomputer/ev1.html
安装之后结果如图:
CN1为调试接口,CN2为silabs传输接口。
2.本次试用离线环境,毕竟我的网速并不咋滴。
你可以去https://os.mbed.com/teams/Thundersoft/code/?page=2下载Demon程序或者
去http://toshiba.semicon-storage.c ... rocomputer/ev1.html下载TMPM3Hy_v1.2.0软件包。
本次使用东芝官网TMPM3Hy_v1.2.0软件包。
TMPM3Hy_v1.2.0其目录如下:
+---Libraries
| +---CMSIS : CMSIS Core files
| | | system_TMPM3Hy.c
| | | system_TMPM3Hy.h
| | | TMPM3HL.h
| | | TMPM3HM.h
| | | TMPM3HN.h
| | | TMPM3HN_L.h
| | | TMPM3HP.h
| | | TMPM3HQ.h
| | | TMPM3Hy.h
| | \---startup
| | +---arm : startup files for KEIL
| | | startup_TMPM3HL.s
| | | startup_TMPM3HM.s
| | | startup_TMPM3HN.s
| | | startup_TMPM3HN_L.s
| | | startup_TMPM3HP.s
| | | startup_TMPM3HQ.s
| | \---iar : startup files for EWARM
| | startup_TMPM3HL.s
| | startup_TMPM3HM.s
| | startup_TMPM3HN.s
| | startup_TMPM3HN_L.s
| | startup_TMPM3HP.s
| | startup_TMPM3HQ.s
| +---Doc
| | | index.html.lnk
| | \---html : Doxygen of Peripheral driver
| +劅Periph_driver
| +---inc : Header file of Peripheral driver
| \---src : Source file of Peripheral driver
+---Project
| \---Examples
| +---ADC : Analog to Digital Converter sample project
| +---BSP : Board Support Package
| +---CGRST : Clock Control and Operation Mode sample project
| +---CRC : CRC sample project
| +---DNF : Digital Noise filter Circuit sample project
| +---FC : Flash Memory control sample project
| +---GPIO : Input/Output Ports sample project
| +---I2C : I2C Interface sample project
| +---LVD : Voltage Detection Circuit sample project
| +---OFD : Oscillation Frequency Detector sample project
| +---RMC : Remote Control Signal Preprocessor sample project
| +---RPAR : RAM Parity sample project
| +---RTC : Real Time Clock sample project
| +---T32A : 32-bit Timer Event Counter sample project
| +---TRM : Trimming Circuit sample project
| +---TSPI : Serial Peripheral Interface sample project
| +---UART : Asynchronous Serial Communication Circuit and DMA Controller sample project
\---SVD : System view description files.
3.Keil MDK-ARM环境打开软件,需要增加东芝芯片包,自动下载,或者手动装载
下载之后,打开例程UART_Echo.uvprojx。
设置确定芯片和配置。
点击确定,确定之后,编译下载,或者将BIN文件复制到TT_M3HQ磁盘里。
4.按复位键S1,打开串口软件,发送任意命令。
附件就不上传了,毕竟用的手机的流量。
