/*============================================================================* * LOGIC CORE: OV5640初始化寄存器表(RGB模式专用) * MODULE NAME: ov5640_init_table_rgb() * COMPANY: 武汉芯路恒科技有限公司 * http://xiaomeige.taobao.com * author: 小梅哥 * Website: www.corecourse.cn * REVISION HISTORY: * * Revision: 1.0 04/10/2019 * Description: Initial Release. * * FUNCTIONAL DESCRIPTION: ===========================================================================*/ module ov5640_init_table_rgb( addr, clk, q ); parameter DATA_WIDTH=24; parameter ADDR_WIDTH=8; parameter IMAGE_WIDTH = 16'd640; parameter IMAGE_HEIGHT = 16'd480; parameter IMAGE_FLIP = 8'h40; parameter IMAGE_MIRROR = 4'h7; input clk; input [(ADDR_WIDTH-1):0] addr; output reg [(DATA_WIDTH-1):0] q; // Declare the ROM variable reg [DATA_WIDTH-1:0] rom[2**ADDR_WIDTH-1:0]; initial begin rom[0 ] = 24'h3103_11; // system clock from pad, bit[1] rom[1 ] = 24'h3008_82; // software reset, bit[7] rom[2 ] = 24'h3008_42; // software power down, bit[6] rom[3 ] = 24'h3103_03; // system clock from PLL, bit[1] rom[4 ] = 24'h3017_ff; // FREX, Vsync, HREF, PCLK, D[9:6] output enable rom[5 ] = 24'h3018_ff; // D[5:0], GPIO[1:0] output enable rom[6 ] = 24'h3034_1a; // MIPI 10-bit rom[7 ] = 24'h3037_13; // PLL root divider, bit[4], PLL pre-divider, bit[3:0] rom[8 ] = 24'h3108_01; // PCLK root divider, bit[5:4], SCLK2x root divider, bit[3:2] rom[9 ] = 24'h3630_36; // SCLK root divider, bit[1:0] rom[10] = 24'h3631_0e; rom[11] = 24'h3632_e2; rom[12] = 24'h3633_12; rom[13] = 24'h3621_e0; rom[14] = 24'h3704_a0; rom[15] = 24'h3703_5a; rom[16] = 24'h3715_78; rom[17] = 24'h3717_01; rom[18] = 24'h370b_60; rom[19] = 24'h3705_1a; rom[20] = 24'h3905_02; rom[21] = 24'h3906_10; rom[22] = 24'h3901_0a; rom[23] = 24'h3731_12; rom[24] = 24'h3600_08; // VCM control rom[25] = 24'h3601_33; // VCM control rom[26] = 24'h302d_60; // system control rom[27] = 24'h3620_52; rom[28] = 24'h371b_20; rom[29] = 24'h471c_50; rom[30] = 24'h3a13_43; // pre-gain = 1.047x rom[31] = 24'h3a18_00; // gain ceiling rom[32] = 24'h3a19_f8; // gain ceiling = 15.5x rom[33] = 24'h3635_13; rom[34] = 24'h3636_03; rom[35] = 24'h3634_40; rom[36] = 24'h3622_01; // 50/60Hz detection 50/60Hz 灯光条纹过滤 rom[37] = 24'h3c01_34; // Band auto, bit[7] rom[38] = 24'h3c04_28; // threshold low sum rom[39] = 24'h3c05_98; // threshold high sum rom[40] = 24'h3c06_00; // light meter 1 threshold[15:8] rom[41] = 24'h3c07_08; // light meter 1 threshold[7:0] rom[42] = 24'h3c08_00; // light meter 2 threshold[15:8] rom[43] = 24'h3c09_1c; // light meter 2 threshold[7:0] rom[44] = 24'h3c0a_9c; // sample number[15:8] rom[45] = 24'h3c0b_40; // sample number[7:0] rom[46] = 24'h3810_00; // Timing Hoffset[11:8] rom[47] = 24'h3811_10; // Timing Hoffset[7:0] rom[48] = 24'h3812_00; // Timing Voffset[10:8] rom[49] = 24'h3708_64; rom[50] = 24'h4001_02; // BLC start from line 2 rom[51] = 24'h4005_1a; // BLC always update rom[52] = 24'h3000_00; // enable blocks rom[53] = 24'h3004_ff; // enable clocks rom[54] = 24'h300e_58; // MIPI power down, DVP enable rom[55] = 24'h302e_00; rom[56] = 24'h4300_61; // RGB565 //h4300_6f(千兆网模式)-------------------------------------------------------- rom[57] = 24'h501f_01; // RGB565 rom[58] = 24'h440e_00; rom[59] = 24'h5000_a7; // Lenc on, raw gamma on, BPC on, WPC on, CIP on // AEC target 自动曝光控制 rom[60] = 24'h3a0f_30; // stable range in high rom[61] = 24'h3a10_28; // stable range in low rom[62] = 24'h3a1b_30; // stable range out high rom[63] = 24'h3a1e_26; // stable range out low rom[64] = 24'h3a11_60; // fast zone high rom[65] = 24'h3a1f_14; // fast zone low // Lens correction for ? 镜头补偿 rom[66 ] = 24'h5800_23; rom[67 ] = 24'h5801_14; rom[68 ] = 24'h5802_0f; rom[69 ] = 24'h5803_0f; rom[70 ] = 24'h5804_12; rom[71 ] = 24'h5805_26; rom[72 ] = 24'h5806_0c; rom[73 ] = 24'h5807_08; rom[74 ] = 24'h5808_05; rom[75 ] = 24'h5809_05; rom[76 ] = 24'h580a_08; rom[77 ] = 24'h580b_0d; rom[78 ] = 24'h580c_08; rom[79 ] = 24'h580d_03; rom[80 ] = 24'h580e_00; rom[81 ] = 24'h580f_00; rom[82 ] = 24'h5810_03; rom[83 ] = 24'h5811_09; rom[84 ] = 24'h5812_07; rom[85 ] = 24'h5813_03; rom[86 ] = 24'h5814_00; rom[87 ] = 24'h5815_01; rom[88 ] = 24'h5816_03; rom[89 ] = 24'h5817_08; rom[90 ] = 24'h5818_0d; rom[91 ] = 24'h5819_08; rom[92 ] = 24'h581a_05; rom[93 ] = 24'h581b_06; rom[94 ] = 24'h581c_08; rom[95 ] = 24'h581d_0e; rom[96 ] = 24'h581e_29; rom[97 ] = 24'h581f_17; rom[98 ] = 24'h5820_11; rom[99 ] = 24'h5821_11; rom[100] = 24'h5822_15; rom[101] = 24'h5823_28; rom[102] = 24'h5824_46; rom[103] = 24'h5825_26; rom[104] = 24'h5826_08; rom[105] = 24'h5827_26; rom[106] = 24'h5828_64; rom[107] = 24'h5829_26; rom[108] = 24'h582a_24; rom[109] = 24'h582b_22; rom[110] = 24'h582c_24; rom[111] = 24'h582d_24; rom[112] = 24'h582e_06; rom[113] = 24'h582f_22; rom[114] = 24'h5830_40; rom[115] = 24'h5831_42; rom[116] = 24'h5832_24; rom[117] = 24'h5833_26; rom[118] = 24'h5834_24; rom[119] = 24'h5835_22; rom[120] = 24'h5836_22; rom[121] = 24'h5837_26; rom[122] = 24'h5838_44; rom[123] = 24'h5839_24; rom[124] = 24'h583a_26; rom[125] = 24'h583b_28; rom[126] = 24'h583c_42; rom[127] = 24'h583d_ce; // lenc BR offset // AWB 自动白平衡 rom[128] = 24'h5180_ff; // AWB B block rom[129] = 24'h5181_f2; // AWB control rom[130] = 24'h5182_00; // [7:4] max local counter, [3:0] max fast counter rom[131] = 24'h5183_14; // AWB advanced rom[132] = 24'h5184_25; rom[133] = 24'h5185_24; rom[134] = 24'h5186_09; rom[135] = 24'h5187_09; rom[136] = 24'h5188_09; rom[137] = 24'h5189_75; rom[138] = 24'h518a_54; rom[139] = 24'h518b_e0; rom[140] = 24'h518c_b2; rom[141] = 24'h518d_42; rom[142] = 24'h518e_3d; rom[143] = 24'h518f_56; rom[144] = 24'h5190_46; rom[145] = 24'h5191_f8; // AWB top limit rom[146] = 24'h5192_04; // AWB bottom limit rom[147] = 24'h5193_70; // red limit rom[148] = 24'h5194_f0; // green limit rom[149] = 24'h5195_f0; // blue limit rom[150] = 24'h5196_03; // AWB control rom[151] = 24'h5197_01; // local limit rom[152] = 24'h5198_04; rom[153] = 24'h5199_12; rom[154] = 24'h519a_04; rom[155] = 24'h519b_00; rom[156] = 24'h519c_06; rom[157] = 24'h519d_82; rom[158] = 24'h519e_38; // AWB control // Gamma 伽玛曲线 rom[159] = 24'h5480_01; // Gamma bias plus on, bit[0] rom[160] = 24'h5481_08; rom[161] = 24'h5482_14; rom[162] = 24'h5483_28; rom[163] = 24'h5484_51; rom[164] = 24'h5485_65; rom[165] = 24'h5486_71; rom[166] = 24'h5487_7d; rom[167] = 24'h5488_87; rom[168] = 24'h5489_91; rom[169] = 24'h548a_9a; rom[170] = 24'h548b_aa; rom[171] = 24'h548c_b8; rom[172] = 24'h548d_cd; rom[173] = 24'h548e_dd; rom[174] = 24'h548f_ea; rom[175] = 24'h5490_1d; // color matrix 色彩矩阵 rom[176] = 24'h5381_1e; // CMX1 for Y rom[177] = 24'h5382_5b; // CMX2 for Y rom[178] = 24'h5383_08; // CMX3 for Y rom[179] = 24'h5384_0a; // CMX4 for U rom[180] = 24'h5385_7e; // CMX5 for U rom[181] = 24'h5386_88; // CMX6 for U rom[182] = 24'h5387_7c; // CMX7 for V rom[183] = 24'h5388_6c; // CMX8 for V rom[184] = 24'h5389_10; // CMX9 for V rom[185] = 24'h538a_01; // sign[9] rom[186] = 24'h538b_98; // sign[8:1] // UV adjust UV 色彩饱和度调整 rom[187] = 24'h5580_06; // saturation on, bit[1] rom[188] = 24'h5583_40; rom[189] = 24'h5584_10; rom[190] = 24'h5589_10; rom[191] = 24'h558a_00; rom[192] = 24'h558b_f8; rom[193] = 24'h501d_40; // enable manual offset of contrast // CIP 锐化和降噪 rom[194] = 24'h5300_08; // CIP sharpen MT threshold 1 rom[195] = 24'h5301_30; // CIP sharpen MT threshold 2 rom[196] = 24'h5302_10; // CIP sharpen MT offset 1 rom[197] = 24'h5303_00; // CIP sharpen MT offset 2 rom[198] = 24'h5304_08; // CIP DNS threshold 1 rom[199] = 24'h5305_30; // CIP DNS threshold 2 rom[200] = 24'h5306_08; // CIP DNS offset 1 rom[201] = 24'h5307_16; // CIP DNS offset 2 rom[202] = 24'h5309_08; // CIP sharpen TH threshold 1 rom[203] = 24'h530a_30; // CIP sharpen TH threshold 2 rom[204] = 24'h530b_04; // CIP sharpen TH offset 1 rom[205] = 24'h530c_06; // CIP sharpen TH offset 2 rom[206] = 24'h5025_00; rom[207] = 24'h3008_02; // wake up from standby, bit[6] // 12824'h720, 30fps // input clock 24Mhz, PCLK 42Mhz rom[208] = 24'h3035_21; // PLL 21:30fps 41:15fps 81:7.5fps rom[209] = 24'h3036_69; // PLL rom[210] = 24'h3c07_07; // lightmeter 1 threshold[7:0] rom[211] = {16'h3820, IMAGE_FLIP}; // flip rom[212] = {20'h38210, IMAGE_MIRROR}; // no mirror rom[213] = 24'h3814_31; // timing X inc rom[214] = 24'h3815_31; // timing Y inc rom[215] = 24'h3800_00; // HS rom[216] = 24'h3801_00; // HS rom[217] = 24'h3802_00; // VS rom[218] = 24'h3803_fa; // VS rom[219] = 24'h3804_0a; // HW SET_OV5640 + HE} rom[220] = 24'h3805_3f; // HW SET_OV5640 + HE} rom[221] = 24'h3806_06; // VH SET_OV5640 + VE} rom[222] = 24'h3807_a9; // VH SET_OV5640 + VE} rom[223] = {16'h3808, IMAGE_WIDTH[15:8]}; // DVPHO (<1280>500) (<640>280)IMAGE_WIDTH rom[224] = {16'h3809, IMAGE_WIDTH[ 7:0]}; // DVPHO rom[225] = {16'h380a, IMAGE_HEIGHT[15:8]}; // DVPVO (<720>2d0) (<480>1e0)IMAGE_HEIGHT rom[226] = {16'h380b, IMAGE_HEIGHT[ 7:0]}; // DVPHO rom[227] = 24'h380c_07; // HTS rom[228] = 24'h380d_64; // HTS rom[229] = 24'h380e_02; // VTS rom[230] = 24'h380f_e4; // VTS rom[231] = 24'h3813_04; // timing V offset rom[232] = 24'h3618_00; rom[233] = 24'h3612_29; rom[234] = 24'h3709_52; rom[235] = 24'h370c_03; rom[236] = 24'h3a02_02; // 60Hz max exposure rom[237] = 24'h3a03_e0; // 60Hz max exposure rom[238] = 24'h3a14_02; // 50Hz max exposure rom[239] = 24'h3a15_e0; // 50Hz max exposure rom[240] = 24'h4004_02; // BLC line number rom[241] = 24'h3002_1c; // reset JFIFO, SFIFO, JPG rom[242] = 24'h3006_c3; // disable clock of JPEG2x, JPEG rom[243] = 24'h4713_03; // JPEG mode 3 rom[244] = 24'h4407_04; // Quantization scale rom[245] = 24'h460b_37; rom[246] = 24'h460c_20; rom[247] = 24'h4837_16; // MIPI global timing rom[248] = 24'h3824_04; // PCLK manual divider rom[249] = 24'h5001_83; // SDE on, CMX on, AWB on rom[250] = 24'h3503_00; // AEC/AGC on rom[251] = 24'h4740_20; // VS 1 end always @ (posedge clk) begin q <= rom[addr]; end endmodule
复制代码
