keil创建新项目时,提示是否添加启动文件
一般情况下,需要选择“是”。当然,也可以选择不加。那么,这个启动文件的作用是什么?什么情况下需要加,什么情况下可以不加?
今天我们就来详细了解一下这个启动文件的内容,看明白这个内容后,我们就会有种恍然大悟的感觉:“哦,原来是这样啊!”
以下时启动代码原文第一段
$NOMOD51;------------------------------------------------------------------------------ ; This file is part of the C51 Compiler package ; Copyright (c) 1988-2005 Keil Elektronik GmbH and Keil Software, Inc. ; Version 8.01 ; ; *** <<< Use Configuration Wizard in Context Menu >>> *** ;------------------------------------------------------------------------------ ; STARTUP.A51: This code is executed after processor reset. ; ; To translate this file use A51 with the following invocation: ; ; A51 STARTUP.A51 ; ; To link the modified STARTUP.OBJ file to your application use the following ; Lx51 invocation: ; ; Lx51 your object file list, STARTUP.OBJ controls ; ;------------------------------------------------------------------------------ ; ; User-defined <h> Power-On Initialization of Memory ; ; With the following EQU statements the initialization of memory ; at processor reset can be defined: ; ; <o> IDATALEN: IDATA memory size <0x0-0x100> ; <i> Note: The absolute start-address of IDATA memory is always 0 ; <i> The IDATA space overlaps physically the DATA and BIT areas. IDATALEN EQU 80H ; ; <o> XDATASTART: XDATA memory start address <0x0-0xFFFF> ; <i> The absolute start address of XDATA memory XDATASTART EQU 0 ; ; <o> XDATALEN: XDATA memory size <0x0-0xFFFF> ; <i> The length of XDATA memory in bytes. XDATALEN EQU 0 ; ; <o> PDATASTART: PDATA memory start address <0x0-0xFFFF> ; <i> The absolute start address of PDATA memory PDATASTART EQU 0H ; ; <o> PDATALEN: PDATA memory size <0x0-0xFF> ; <i> The length of PDATA memory in bytes. PDATALEN EQU 0H ; ;</h>
复制代码------------------------------------------------------------------------------
这个文件是C51编译器包的一部分版权所有(c) 1988-2005 Keil Elektronik GmbH和Keil Software, Inc。
版本8.01
*** <<使用上下文菜单中的配置向导>>> ***
STARTUP.A51里面的代码在处理器复位后执行。用下面的命令行语句调用A51进行编译产生目标文件
A51 STARTUP.A51
用下面的命令行语句调用BL51连接器把STARTUP.OBJ目标文件连接到程序代码中 Lx51 invocation:
Lx51调用------------------------------------------------------------------------------
Lx51 调用目标文件列表, 由STARTUP.OBJ 目标文件控制用户自定义上电后需要初始化的储存区域(初始化RAM区的数据)
在处理器复位时通过下列EQU伪指令来初始化内存(RAM单元)
IDATALEN:IDATA存储区的大小<0-256>,可以根据自己的选择修改
IDATA绝对的起始地址总是0
IDATA区涵盖DATA和BIT区(DATA区(直接寻址区)以及 BIT区 (位寻址区)),;至少要保证与C51编译器运行库有关的存储器的空间进行0初始化
注意:在51系列中data,idata,xdata,pdata的区别:
data:固定指前面0x00-0x7f的128个RAM。
idata:固定指前面0x00-0xff的256个RAM,其中前128和data的128完全相同,只是因为访问的方式不同。
xdata:外部扩展RAM,一般指外部0x0000-0xffff空间。
pdata:外部扩展RAM的低256个字节。
需用0进行初始化的IDATA存储器空间的字节数,IDATALEN 只是一个标号(与IDATA不一样哦),EQU只是做宏一样的替换,类似于C语言中的#define uint (unsigned int),以上的代码使得程序以后在碰到IDATALEN时替换成80H。IDATALEN可以定义为你自己喜欢的名字如MyDataLen等。之所以用IDATALEN,一是为了好记,二是为了表明和IDATA有关。
XDATA存储区的起始地址 <0x0-0xFFFF>
XDATA内存的绝对起始地址。
XDATA存储器空间的绝对起始地址为0,
XDATA空间的大小
XDATA空间的长度以字节为单位
说明xdata的字节数清0,该值默认为0
PDATA空间的大小
PDATA存储器的空间的绝对起始地址
需用0进行初始化的PDATA存储器的空间字节数
各种常数名及其含义
我们继续来看看51单片机的启动代码里面都有哪些东西。
下面先列出51单片机启动代码第二部分的原文。
原文
;------------------------------------------------------------------------------; ;<h> Reentrant Stack Initialization ; ; The following EQU statements define the stack pointer for reentrant ; functions and initialized it: ; ; <h> Stack Space for reentrant functions in the SMALL model. ; <q> IBPSTACK: Enable SMALL model reentrant stack ; <i> Stack space for reentrant functions in the SMALL model. IBPSTACK EQU 0 ; set to 1 if small reentrant is used. ; <o> IBPSTACKTOP: End address of SMALL model stack <0x0-0xFF> ; <i> Set the top of the stack to the highest location. IBPSTACKTOP EQU 0xFF +1 ; default 0FFH+1 ; </h> ; ; <h> Stack Space for reentrant functions in the LARGE model. ; <q> XBPSTACK: Enable LARGE model reentrant stack ; <i> Stack space for reentrant functions in the LARGE model. XBPSTACK EQU 0 ; set to 1 if large reentrant is used. ; <o> XBPSTACKTOP: End address of LARGE model stack <0x0-0xFFFF> ; <i> Set the top of the stack to the highest location. XBPSTACKTOP EQU 0xFFFF +1 ; default 0FFFFH+1 ; </h> ; ; <h> Stack Space for reentrant functions in the COMPACT model. ; <q> PBPSTACK: Enable COMPACT model reentrant stack ; <i> Stack space for reentrant functions in the COMPACT model. PBPSTACK EQU 0 ; set to 1 if compact reentrant is used. ; ; <o> PBPSTACKTOP: End address of COMPACT model stack <0x0-0xFFFF> ; <i> Set the top of the stack to the highest location. PBPSTACKTOP EQU 0xFF +1 ; default 0FFH+1 ; </h> ;</h>
复制代码翻译再入函数模拟初始化;
以下用EQU指令定义了再入函数模拟堆栈指针的初始化;
使用SMALL存储器模式时再入函数的堆栈空间;
IBPSTACK EQU 0 ; 使用SMALL存储器模式再入函数时将其设置成1;
IBPSTACKTOP EQU 0FFH+1 ; 将堆栈顶设置为最高地址+1;
使用LARGE存储器模式时再入函数的堆栈空间;
XBPSTACK EQU 0 ; 使用LARGE存储器模式再入函数时将其设置成1;
XBPSTACKTOP EQU 0FFFFH+1; 将堆栈顶设置为最高地址+1;
使用COMPACT存储器模式时再入函数的堆栈空间;
PBPSTACK EQU 0 ; 使用COMPACT存储器模式再入函数时将其设置成1;
PBPSTACKTOP EQU 0FFFFH+1; 将堆栈顶设置为最高地址+1.
划重点这里提到了SMALL,LARGE,COMPACT三种模式。这三种模式究竟有什么含义呢?我们下面就来了解一下。
不同内存模式下的堆栈。Keil 编译器中有三种模式设置。这是由51处理器繁多的寻址模式导致的,不同的寻址模式有不同的效率。
small模式在small模式中,所有默认变量均装入单片机内部的RAM中,51单片机默认内部RAM只有128B;52单片机默认256B。该模式下的优点是访问速度快,缺点是空间有限。
compact模式在compact模式中,所有默认变量均位于单片机的256B RAM中,和在small模式中使用关键字 pdata来定义数据变量的效果一样,在该模式下程序总变量空间不能超过256B。
large模式在large模式中,所有默认变量可放在多达64KB的RAM中,包括内部RAM和外部RAM,这和使用关键字xdata 来定义变量的效果一样。
Small:变量存储在内部ram里。
Compact:变量存储在外部ram里,,使用页8位间接寻址。
Large:变量存储在外部Ram里,使用16位间接寻址。
我们一般使用Small来存储变量,就是说单片机优先把变量存储在内部ram里,如果内部ram不够了,才会存到外部去。Compact的方式要自己通过程序来指定页的高位地址,编程比较复杂,如果外部ram很少,只有256个字节,那么对该256个字节的读取就比较快。
如果超过256字节,那么要不断地进行切换的话,就比较麻烦。Compact模式适用于比较少的外部ram的情况。Large模式,是指变量会优先分配到外部ram里,3种存储方式都支持内部256字节和外部64k字节的ram。区别是变量的优先(或默认)存储在哪里的区别。除非你不想把变量存储在内部ram,才使用后面的Compact,Large模式。因为变量存储在内部ram里,运算速度比存储在外部ram要快的多,大部分的应用都是选择Small的模式。
来源:老马识途单片机
