更低导通电阻,更低计生电容,更高临界击穿场强,更高热传性能,[size=16.6667px]欢迎来电咨询。电话/微信:13538284956,谢谢!
[size=16.6667px]
ABSOLUTE MAXIMUM RATINGS(TC=25°Cunless otherwise noted)
Parameter
Symbol
Rating
Unit
TO-247
Drain-Source Voltage
VDSS
1200
V
Continuous Drain Current
TC = 25°C,VGS=18V
ID
60
A
Single Pulse Avalanche Energy
L=10mH
EAS
460
mJ
L=10mH
IAS
9.6
A
Pulsed Drain Current
IDM
240
A
Recommend Gate Source Voltage(Static)
VGS,op
-3/+18
V
Maximum Gate Source  Voltage(AC (f > 1Hz))
VGS,max
-5/+22
V
Power Dissipation
TC =25°C
PD
271.7
W
Soldering Temperature
TL
260
°C
Operating Junction and  Storage Temperature Range
TJ,TSTG
150,-55~150
°C
Thermal Resistance,  Junction to Case
RθJC
0.46
°C / W
ELECTRICALCHARACTERISTICS(TJ=25℃,unless otherwise Noted)
Parameter
Symbol
Test Condition
Min.
Typ.
Max.
Unit
OFF CHARACTERISTICS
Drain-Source Breakdown Voltage
BVDSS
VGS=0V, ID=250µA
1200
V
Zero Gate Voltage Drain Current
IDSS
VDS=1200V, VGS=0V
10
uA
Gate-Body Leakage Current, Forward
IGSS
VGS=18V,VDS = 0V
250
nA
ON CHARACTERISTICS
Gate Threshold Voltage
VGS(TH)
VDS=10V, ID=5mA
1.5
3.0
V
Drain-Source On-State Resistance
RDS(ON)
VGS=20V, ID=30A
36
43
mΩ
VGS=18V, ID=30A
40
48
VGS=15V, ID=30A
50
60
VGS=18V, ID=30A, TJ=150℃
80
DYNAMIC PARAMETERS
Input Capacitance
CISS
VDS=25V,VGS=0V, f=1MHz,VAC=25mV
2400
pF
Output Capacitance
COSS
120
pF
Reverse Transfer Capacitance
CRSS
18
pF
SWITCHING PARAMETERS
Total Gate Charge(Note2)
QG
VDD =800V, VGS =-3/+18 V, ID=30A
170
nC
Gate Source Charge
QGS
10
nC
Gate Drain Charge
QGD
48
nC
Gate plateau voltage
Vpl
2.6
V
Turn-ON Delay Time
tD(ON)
VDS=800V, ID=30A, VGS = -3/+18 V ,RG=25Ω
45
ns
Turn-ON Rise Time
tR
119
ns
Turn-OFF Delay Time
tD(OFF)
123
ns
Turn-OFF Fall-Time
tF
145
ns
Internal Gate Resistance
RG(int.)
f =1MHz, VAC=25mV
2.4
SOURCE-  DRAIN DIODE RATINGS AND CHARACTERISTICS
Drain-Source Diode Forward Voltage
VSD
IS=30A, VGS=-3V
4.6
V
Continuous Diode Forward Current
IS
VGS = -3V
60
A
Reverse  Recovery Time
trr
VGS = -3/+18V,IF = 60A, VDS=400V,
di/dt =500A /μs
62
ns
Reverse  Recovery Charge
Qrr
298
nC
Peak  Reverse Recovery Current
Irrm
10
A
