1 Features
| 2 Applications
3 Description PL8312 is a monolithic 36V, 1.2A step-down switching regulator. PL8312 integrates a 36V 250mΩ high side and a 36V, 140mΩ low side MOSFETs to provide 1.2A continuous load current over a 4.5V to 36V wide operating input voltage with 33V input over voltage protection. Peak current mode control provides fast transient responses and cycle-by-cycle current limiting. PL8312 has configurable line drop compensation, configurable charging current limit. CC/CV mode control provides a smooth transition between constant current charging and constant voltage charging stages. Built-in soft-start prevents inrush current at power-up. |
4 Typical Application Schematic | 5 Pin Configuration and Functions |
输入电压 范围(V) | 最高工作 电流(A) | 产品型号 | 频率(kHz) | 软启动 | 功率管 内置/外置 | CC/CV | 补偿 | 控制结构 | 封装 |
4.5-32 | 1.0 | PL8312 | 500 | 内置Internal | 内置Internal | CC/CV | 内置Internal | 峰值电流 | SOP8 |
原厂代理,更多详情请咨询 深圳市芯美力科技有限公司 黄先生:19928739245(微同) QQ:541777848
