在通常的情况下,我们所所用的显示器件多是数码管、液晶屏、OLED屏及TFT屏。但在公共场合要显示信息,就要有较大尺寸以便观察。
通常多使用半板来拼接成较大的广告牌,这里使用的是一款P4.75的红色点阵板,其显示分辨率为16*64像素点。
图1 点阵屏外观
该点阵屏采用的接口方式为HUB08,各引脚的名称如图2所示。
图2 HUB08接口
该点阵屏与开发板的连接关系为:
A---PB4
B---PB5
C---PA6
D---PB7
R1 ---PC2
OE ---PC3
LAT ---PC1
CLK---PC0
所用引脚输出高低电平的语句定义为:
#define LA_high gpio_set_level(GPIO_PB4, 1) // A
#define LA_low gpio_set_level(GPIO_PB4, 0)
#define LB_high gpio_set_level(GPIO_PB5, 1) // B
#define LB_low gpio_set_level(GPIO_PB5, 0)
#define LC_high gpio_set_level(GPIO_PB6, 1) // C
#define LC_low gpio_set_level(GPIO_PB6, 0)
#define LD_high gpio_set_level(GPIO_PB7, 1) // D
#define LD_low gpio_set_level(GPIO_PB7, 0)
#define LR1_high gpio_set_level(GPIO_PC2, 1) // R1
#define LR1_low gpio_set_level(GPIO_PC2, 0)
#define CLK_high gpio_set_level(GPIO_PC0, 1) // CLK
#define CLK_low gpio_set_level(GPIO_PC0, 0)
#define LEN_high gpio_set_level(GPIO_PC3, 1) // CS
#define LEN_low gpio_set_level(GPIO_PC3, 0)
#define LSTB_high gpio_set_level(GPIO_PC1, 1) // STB
#define LSTB_low gpio_set_level(GPIO_PC1, 0)
所用引脚的初始化函数为:
void gpio_init (void){ gpio_function_en(GPIO_PB4); gpio_output_en(GPIO_PB4); gpio_function_en(GPIO_PB5); gpio_output_en(GPIO_PB5); gpio_function_en(GPIO_PB6); gpio_output_en(GPIO_PB6); gpio_function_en(GPIO_PB7); gpio_output_en(GPIO_PB7); gpio_function_en(GPIO_PC0); gpio_output_en(GPIO_PC0); gpio_function_en(GPIO_PC1); gpio_output_en(GPIO_PC1); gpio_function_en(GPIO_PC2); gpio_output_en(GPIO_PC2); gpio_function_en(GPIO_PC3); gpio_output_en(GPIO_PC3); }
复制代码1. 电子时钟为实现数字符号的显示,以字模提取软件所构建的字库存储结构为:
uint8_t S[]={0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,/*"0",0*/ 0x00,0x00,0x00,0x08,0x0E,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x3E,0x00,0x00,/*"1",1*/ 0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x20,0x20,0x10,0x08,0x04,0x42,0x7E,0x00,0x00,/*"2",2*/ ... 0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,/*":",10*/ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"-",11*/ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, };
复制代码点阵板发送数据的函数为:
voidOutByte (u16 dat){ u8 i=0 ; for(i=0;i<16;i++) { CLK_low; if(dat&0x0001) { LR1_high; } else { LR1_low; } dat=dat>>1; delay_us(10); CLK_high; delay_us(10); } }
复制代码输出行地址的函数为:
voidSeleRow(uint8_t Nd){ uint8_t N; N=Nd; N=N%16; if(N&0x01) LA_high; else LA_low; if (N&0x02) LB_high; else LB_low; if (N&0x04) LC_high; else LC_low; if (N&0x08) LD_high; else LD_low; }
复制代码发送多列数据的函数为:
voidDisCol (u16 lenght){ u16 dat; uint8_t ml=0; while(lenght--) { dat=(S[sj[ml+1]*16+ScanRow]<<8)+S[sj[ml]*16+ScanRow]; OutByte (dat); ml=ml+2; } }
复制代码实现显示输出的函数为:
voidDisplay_B(void){ DisCol_B(4); LEN_high; LSTB_high; LSTB_low; SeleRow(ScanRow); LEN_low; ScanRow++; if(ScanRow>15) ScanRow=0; }
复制代码由于Telink B91没有专用的RTC计时器,故要在显示刷新中实现计时处理,只能通过计算显示的耗时来推算出一个秒计时器来替代RTC的作用。实现图2所示的计时效果,其主程序为:
int main (void){ unsignedint i=0,h=8,m=30,s=0; sys_init(LDO_1P4_LDO_1P8, VBAT_MAX_VALUE_GREATER_THAN_3V6); user_read_flash_value_calib(); CCLK_24M_HCLK_24M_PCLK_24M; user_init(); delay_ms(1000); ScanRow=0; gpio_init (void) delay_ms(100); while (1) { for(i=0;i<500;i++) { Display (); } s=s+1; if(s==60) { s=0; m=m+1; } sj[6]=s/10; sj[7]=s%10; if(m==60) { m=0; h=h+1; } sj[3]=m/10; sj[4]=m%10; if(h==60) { h=0; } sj[0]=h/10; sj[1]=h%10; } return 0; }
复制代码
图2 电子时钟
2. 汉字显示为实现汉字的显示,以字模提取软件所构建的字库存储结构为:
uint8_t V[]={//远上寒山石径斜白云生处有人家... 0x00,0x00,0xF8,0x23,0x00,0x10,0x00,0x10,0x00,0x00,0xFC,0x07,0x20,0xF1,0x20,0x11, 0x20,0x11,0x20,0x11,0x24,0x11,0x24,0x12,0x24,0x12,0x1C,0x14,0x00,0x28,0xFE,0x47,// 0 0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0xF8,0x03,0x00,0x02, 0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0x00,0x02,0xFE,0xFF,0x00,0x00, ... };
复制代码点阵板发送数据的函数为:
voidOutByte(uint16_t dat){ uint8_t i=0 ; for(i=0;i<16;i++) { CLK_low; delay_us(10); if(dat&0x8000) { LR1_high; } else { LR1_low; } dat=dat<<1; delay_us(10); CLK_high; } }
复制代码发送多列数据的函数为:
voidDisCol (uint16_t lenght){ uint16_t dat; uint8_t m=8; m=mm; while(lenght--) { dat=(V[m*32+ScanRow*2+1]<<8)+V[m*32+ScanRow*2]; OutByte(dat); m=m+1; } }
复制代码实现显示输出的函数为:
voidDisplay (void){ DisCol (4); LEN_high; LSTB_high; LSTB_low; SeleRow(ScanRow); LEN_low; ScanRow++; if(ScanRow>15) ScanRow=0; }
复制代码受显示板显示规格的限制,要显示一首唐诗,必须通过分屏显示来完成,或通过屏幕滚动的方式来实现。这里采用的是多屏显示的方式,其实现图3所示效果的主程序为:
int main (void){ unsignedint i=0; sys_init(LDO_1P4_LDO_1P8, VBAT_MAX_VALUE_GREATER_THAN_3V6); user_read_flash_value_calib(); CCLK_24M_HCLK_24M_PCLK_24M; user_init(); delay_ms(100); ScanRow=0; delay_ms(100); while (1) { for(i=0;i<1500;i++) { Display (); } mm=(mm+4)%32; } return 0; }
复制代码
图3 汉字显示效果
