开发平台:MDK
下载器:板载jlink
开发板:FPB-RA4E1
目地:使用开发板点亮OLED,并从左向右移动。
下面开始
1、连接原理图:
2、位号图
3、Fsp配置
4.相关代码:
显示主代码:
fsp_err_t err;
/* TODO: add your own code here */
OLED_Init();
OLED_ShowStr(0, 0,(uint8_t *) "RA4e1", 2);
OLED_HorizontalShift(2000);
OLED_ShowStr(0, 15,(uint8_t *) "RA4e1", 2);
err = R_RTC_Open(&g_rtc0_ctrl, &g_rtc0_cfg);
/* Handle any errors. This function should be defined by the user. */
assert(FSP_SUCCESS == err);
/* R_RTC_CalendarTimeSet must be called at least once to start the RTC */
R_RTC_CalendarTimeSet(&g_rtc0_ctrl, &set_time);
/* Set the periodic interrupt rate to 1 second */
R_RTC_PeriodicIrqRateSet(&g_rtc0_ctrl, RTC_PERIODIC_IRQ_SELECT_1_SECOND);
OLED_RefreshRAM();
填充:
<span style="white-space: normal;"><span style="white-space:pre"> </span>for(uint16_t m = 0; m < displayHeight/8; m++)</span>
<span style="white-space: normal;"><span style="white-space:pre"> </span>{</span>
<span style="white-space: normal;"><span style="white-space:pre"> </span>for(uint16_t n = 0; n < displayWidth; n++)</span>
<span style="white-space: normal;"><span style="white-space:pre"> </span>WriteDat(OLED_RAM[m][n]);</span>
<span style="white-space: normal;"><span style="white-space:pre"> </span>}</span>
复制代码5、显示照片:
/4
