【瑞萨RA6E1】 +LED点灯
1 GPIO配置
默认打开了SCL 要将他Disabled
GPIO配置
2 实验代码
* main() is generated by the RA Configuration editor and is used to generate threads if an RTOS is used. This function
* is called by main() when no RTOS is used.
void hal_entry(void)
/* TODO: add your own code here */
R_IOPORT_Open (&g_ioport_ctrl, g_ioport.p_cfg);
while(1)
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_01_PIN_00, BSP_IO_LEVEL_LOW);
R_BSP_SoftwareDelay(1, BSP_DELAY_UNITS_SECONDS);
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_01_PIN_02, BSP_IO_LEVEL_HIGH);
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_01_PIN_00, BSP_IO_LEVEL_HIGH);
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_01_PIN_02, BSP_IO_LEVEL_LOW);
#if BSP_TZ_SECURE_BUILD
/* Enter non-secure code */
R_BSP_NonSecureEnter();
#endif
复制代码
朋友们 g_ioport_ctrl是个啥东西干啥用的
3实验现象
