实战使用寄存器实现LED灯的交互闪烁。
【资料准备】
一个下载工程模版:【兆易创新GD32H759I-EVAL开发板】3、Keil一步一步创建模版工程
【实现步骤】
1、解压后重命名文件夹:
2、打开工程。
3、宏定义GPIO、RCU的寄存器地址:
// 定义GPIOF时钟寄存器地址 AHB4 使能寄存器(RCU_AHB4EN)偏移 0x3C
// RCU 基地址:0x5802 4400
#define LU_RCU_AHB4EN (*(volatile uint32_t *)(uint32_t)(0x58024400+0x3C))
//定义GPIOA_CTL的地址:GPIOA基地址:0x5802 0000
#define LU_GPIOA_CTL (*(volatile uint32_t *)(uint32_t)0x58020000)
#define LU_GPIOA_OMODE (*(volatile uint32_t *)(uint32_t)0x58020004)
#define LU_GPIOA_OSPD (*(volatile uint32_t *)(uint32_t)0x58020008)
#define LU_GPIOA_OCTL (*(volatile uint32_t *)(uint32_t)0x58020014)
//GPIOF基地址:0x5802 0000
#define LU_GPIOF_CTL (*(volatile uint32_t *)(uint32_t)0x58021400)
#define LU_GPIOF_OMODE (*(volatile uint32_t *)(uint32_t)(0x58021400+0x04))
#define LU_GPIOF_OSPD (*(volatile uint32_t *)(uint32_t)(0x58021400+0x08))
#define LU_GPIOF_OCTL (*(volatile uint32_t *)(uint32_t)(0x58021400+0x14))
#define LU_GPIOF_ISTAT (*(volatile uint32_t *)(uint32_t)(0x58021400+0x10))
复制代码//定义LED1_ON\OFF
#define LED1_ON LU_GPIOF_OCTL |= (uint32_t)0x01<<10;
#define LED1_OFF LU_GPIOF_OCTL &= ~((uint32_t)0x01<<10);
#define LED2_ON LU_GPIOA_OCTL |= (uint32_t)0x01<<6;
#define LED2_OFF LU_GPIOA_OCTL &= ~((uint32_t)0x01<<6);
复制代码void led_io_init(void)
//使能时钟
LU_RCU_AHB4EN |= (uint32_t)0x01<<5; //使能GPIOF时钟 Led1 PF10
LU_RCU_AHB4EN |= (uint32_t)0x01<<0; //使能GPIOA时钟 Led2 PA6
//配置LED1 PF10
//先清除位,因为复位后该位为0b11
LU_GPIOF_CTL &= ~((uint32_t)0x03 <<(10*2));
LU_GPIOF_CTL |= ((uint32_t)0x01<<10*2); //置21:20为0x01输出模式
LU_GPIOF_OMODE &= ~(0x01<<10); //输出推挽模式
LU_GPIOF_OSPD &= ~((uint32_t)0x03 <<(10*2));
LU_GPIOF_OSPD &= ((uint32_t)0x01 <<(10*2)); //01:输出最大速度60M
//初始化输出低电平:
LU_GPIOA_OCTL &= ~((uint32_t)0x01<<10);
//先清除位,因为复位后该位为0b11
LU_GPIOA_CTL &= ~((uint32_t)0x03 <<(6*2));
LU_GPIOA_CTL |= ((uint32_t)0x01<<6*2); //置21:20为0x01输出模式
LU_GPIOA_OMODE &= ~(0x01<<10); //输出推挽模式
LU_GPIOA_OSPD &= ~((uint32_t)0x03 <<(6*2));
LU_GPIOA_OSPD &= ((uint32_t)0x01 <<(6*2)); //01:输出最大速度60M
//初始化输出低电平:
复制代码while(1) {
/* turn on LED1, turn off LED2 */
LED1_ON;
LED2_OFF;
delay_1ms(500);
/* turn on LED2 and LED1 */
LED2_ON;
LED1_ON;
delay_1ms(500);
/* turn off LED1 and LED2 */
LED2_OFF;
LED1_OFF;
delay_1ms(500);
复制代码由于开发板使用的IO有重用,所以需要把JP50、JP66跳到LED上才能成功演示:
演示视频如下:
