1、先晒下拿到板子图片
2、搭建工程,
硬件:主要是使用板的CH340串口与芯片的PA2和PA3相连
2.1、开发环境使用Keil 5.31版本,下载器使用ULINK2
2.2、工程文件说明,如图
搭建工程详细步骤就不说了,不懂百度以下,一大堆,嘿嘿,工程如下图
3、串口驱动源文件与头文件
** Header:bsp_uart.c
** File describtion:
** Author:pandy
** Date:2024-10-20
#include "Bsp_uart.h"
//中断服务函数
void UART1_IRQHandler(void)
if ( UART1 -> LSR_b.RDR )
if( ( UART1 -> LSR_b.THRE ) )
UART1 -> THR = UART1 -> RBR;
//串口初始化
void UART1_Init(void)
//init UART pin
PA2_INIT( PA2_UART1_TX );
PA3_INIT( PA3_UART1_RX );
//initial UART1
UART_Open( UART1, UART_BAUD_RATE,UART_NO_PARITY, UART_TRIGGER_LEVEL_1_BYTE, UART_ONE_STOP_BIT );
UART_EnableInt( UART1, UART_RX_INT );//使能接受中断
NVIC_EnableIRQ( UART1_IRQn );
retarget_uart = UART1;
复制代码#ifndef __BSP_UART__H_
#define __BSP_UART__H_
#include "me32f103_uart.h"
#include "me32f103_gpio.h"
#include "me32f103_ioconfig.h"
#define UART_BAUD_RATE 115200
extern UART0_Type * retarget_uart;
extern void UART1_Init(void);
#endif
复制代码4、定时器的源文件与头文件
#ifndef __BSP_TIME__H_
#define __BSP_TIME__H_
#include "me32f103_timer.h"
#define TIME_IS_1MS 1000
typedef struct{
uint32_t time_10ms_cnt;
uint32_t time_1s_cnt;
}timeContrl;
extern timeContrl TimeIs;
extern void TIME0_Init(void);
extern void delay_ms( uint32_t cnt);
#endif
复制代码#ifndef __BSP_TIME__H_
typedef struct{
}timeContrl;
#endif
复制代码5、main文件
** Header: main.c
** File describtion: Experiment with ADC and UART.
** Author:pandy
** Date:2024-10-20
**Thanks to Mesilicon and the mbb.eet community for sponsoring
the ME32F103 Demokit for my use and support.
#include "main.h"
void system_init(void)
SYSCON->CLKBYPASSEN =0x3; //CPU work at 30MHz
SystemCoreClockUpdate();
delay_ms(500);
UART1_Init();
TIME0_Init();
void logMessages(void)
printf("pandy\n");
printf("2024-10-20\n");
printf("Thanks to mbb.eet!\n");
printf("Welcome to ME32F103 Demokit!\n");
//主函数
int main(void)
system_init();
logMessages();
while(1)
delay_ms(500);
复制代码#ifndef __MAIN__H_
#define __MAIN__H_
#include "me32f103.h"
#include "stdio.h"
#include "me32f103_sys.h"
#include "Bsp_time.h"
#endif
复制代码上调试完成的效果如下图:
由于时间比较匆忙,今天UART分享到这来啦!!后续还得把开发板的排针焊上去才好调其它功能!
