在智能交通系统日新月异的今天,无线通信技术已经成为连接车辆、基础设施和行人的桥梁。KCT7526AT,作为一款专为IEEE 802.11p DSRC(专用短程通信)和C-V2X(蜂窝车联网通信)应用及系统设计的射频前端集成电路(RF Front-End IC),凭借其无与伦比的性能、高可靠性和紧凑的设计,正在引领车联网通信的新潮流。
With the rapid development of intelligent transportation systems, wireless communication technology has become a bridge connecting vehicles, infrastructure and pedestrians. The KCT7526AT, an RF Front-End IC designed for IEEE 802.11p DSRC (Dedicated Short Range Communications) and C-V2X (Cellular Vehicle-connected Communications) applications and systems, offers unmatched performance, high reliability and compact design. It is leading the new trend of vehicle networking communication.
C-V2X,作为车联网通信技术的未来之星,旨在通过蜂窝网络实现车辆与周围环境的无缝连接。KCT7526AT全面支持C-V2X,使得车辆能够实时交换信息,从而提高交通效率、增强道路安全性,并推动驾驶的智能化发展。无论是车辆间的协同驾驶、车辆与基础设施的智能交互,还是车辆与行人之间的安全警示,KCT7526AT都能提供稳定、高效的通信支持。
C-V2X, the future star of vehicle-connected communication technology, aims to seamlessly connect vehicles with their surroundings through cellular networks. The KCT7526AT fully supports C-V2X, enabling vehicles to exchange information in real time to improve traffic efficiency, enhance road safety, and drive smarter. Whether it is collaborative driving between vehicles, intelligent interaction between vehicles and infrastructure, or safety alerts between vehicles and pedestrians, the KCT7526AT provides stable and efficient communication support
考虑到汽车电子设备的特殊工作环境,KCT7526AT被设计为能够在-40至105°C的宽温度范围内稳定运行。这一设计确保了KCT7526AT能够在极端天气条件下保持出色的性能,为车联网应用提供可靠的通信支持。无论是在炎热的夏季还是寒冷的冬季,KCT7526AT都能确保通信的稳定性和可靠性。
Taking into account the special operating environment of automotive electronics, the KCT7526AT is designed to operate stably over a wide temperature range of -40 to 105°C. This design ensures that the KCT7526AT performs well in extreme weather conditions and provides reliable communication support for connected vehicle applications. Whether in hot summer or cold winter, the KCT7526AT ensures communication stability and reliability.
产品规格详解:
Detailed explanation of product specifications
全面支持IEEE 802.11p DSRC和C-V2X:KCT7526AT全面支持两大车联网通信协议,为车辆提供全方位的通信支持。
Full support for IEEE 802.11p DSRC and C-V2X: KCT7526AT fully supports both vehicle networking communication protocols, providing a full range of communication support for vehicles.
全匹配输入输出:KCT7526AT采用了全匹配的输入输出设计,确保了信号在传输过程中的完整性和稳定性。
Fully matched input/output: The KCT7526AT uses a fully matched input/output design to ensure the integrity and stability of the signal during transmission.
集成功率检测器:为了方便用户对发射功率进行监测和控制,KCT7526AT集成了功率检测器功能。用户可以实时监测发射功率的变化,并根据需要进行调整。
Integrated power detector: In order to facilitate the user to monitor and control the transmitted power, the KCT7526AT integrates the power detector function. Users can monitor the transmission power changes in real time and make adjustments as needed.
额定电压5V:KCT7526AT的额定电压为5V,兼容多种汽车电子电源系统,无需额外的电压转换电路。
Rated voltage 5V: The KCT7526AT has a rated voltage of 5V and is compatible with a variety of automotive electronic power systems without the need for additional voltage conversion circuits.
小型化封装:KCT7526AT采用了QFN16L封装形式,尺寸仅为3.0mm x 3.0mm x 0.55mm。这一小型化设计使得KCT7526AT能够轻松应用于各种紧凑的空间中,为车联网应用提供了更多的设计灵活性。
Compact package: The KCT7526AT comes in the form of a QFN16L package with a size of only 3.0mm x 3.0mm x 0.55mm. This miniaturized design allows the KCT7526AT to easily be used in a variety of compact Spaces, providing additional design flexibility for connected vehicle applications.
ESD保护:为了防止静电放电(ESD)对电路造成损害,KCT7526AT在所有引脚上都集成了ESD保护电路。这一设计提高了电路的抗静电能力,降低了因静电放电而导致的故障率。
ESD protection: To prevent electrostatic discharge (ESD) from causing damage to the circuit, the KCT7526AT has integrated ESD protection circuits on all pins. This design improves the antistatic ability of the circuit and reduces the failure rate caused by electrostatic discharge.
RoHS和REACH合规:KCT7526AT的制造过程符合RoHS(限制使用有害物质指令)和REACH(化学品注册、评估、许可和限制)标准,对环境和人体健康无害。
RoHS and REACH compliance: The manufacturing process of KCT7526AT complies with RoHS (Restriction of Use of Hazardous Substances Directive) and REACH (Registration, Evaluation, Authorization and Restriction of Chemicals) standards and is not harmful to the environment and human health.
