用 RPi3 运行了一下 OpenSSL 自带的速度测试,结果如下:
  OpenSSL 1.0.1t  3 May 2016
  built on: Sun Jun  5 04:40:58 2016
  options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) blowfish(ptr)
  compiler: gcc -I. -I.. -I../include  -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -DTERMIO -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -Wl,-z,relro -Wa,--noexecstack -Wall -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DAES_ASM -DGHASH_ASM
  The 'numbers' are in 1000s of bytes per second processed.
  type             16 bytes     64 bytes    256 bytes   1024 bytes   8192 bytes
md2                  0.00         0.00         0.00         0.00         0.00
mdc2                 0.00         0.00         0.00         0.00         0.00
md4               9795.82k    35752.58k    99817.73k   180638.04k   236838.91k
md5               7560.42k    26784.47k    74369.28k   133779.46k   174626.13k
hmac(md5)         7688.43k    26809.92k    74479.02k   133875.71k   174732.63k
sha1              7809.49k    24084.16k    53898.15k    78617.60k    90841.09k
rmd160            6879.44k    20474.11k    44320.09k    62478.68k    70950.91k
rc4              79596.22k    91260.46k    95840.34k    97059.84k    97391.96k
des cbc          18581.16k    20445.74k    21020.50k    21168.47k    21211.82k
des ede3          7361.25k     7669.65k     7757.31k     7779.67k     7785.13k
idea cbc             0.00         0.00         0.00         0.00         0.00
seed cbc         23227.13k    25510.27k    26237.01k    26402.47k    26451.97k
rc2 cbc          16615.92k    17779.67k    18144.43k    18223.79k    18229.93k
rc5-32/12 cbc        0.00         0.00         0.00         0.00         0.00
blowfish cbc     31986.51k    36090.58k    37283.24k    37624.49k    37726.89k
cast cbc         26678.90k    30774.91k    32116.22k    32470.36k    32571.39k
aes-128 cbc      41119.87k    46444.71k    48183.72k    48501.08k    48507.56k
aes-192 cbc      35801.51k    39766.85k    41021.53k    41247.74k    41306.79k
aes-256 cbc      32219.57k    35404.74k    36383.06k    36558.17k    36620.97k
camellia-128 cbc    29244.58k    33262.85k    34626.30k    34987.69k    35089.07k
camellia-192 cbc    23867.74k    26480.02k    27340.37k    27564.71k    27628.89k
camellia-256 cbc    23829.02k    26480.00k    27340.71k    27564.71k    27628.89k
sha256           10870.99k    27084.27k    48914.35k    61409.62k    66338.82k
sha512            3537.39k    14084.33k    20592.21k    28181.16k    31599.27k
whirlpool         1390.52k     2874.33k     4655.96k     5518.34k     5832.70k
aes-128 ige      35881.22k    42684.39k    45071.36k    45730.82k    45888.85k
aes-192 ige      31737.56k    36984.36k    38766.85k    39242.07k    39365.29k
aes-256 ige      28906.22k    33196.63k    34592.60k    34989.40k    35078.14k
ghash            42804.59k    48161.77k    50088.70k    50594.13k    50735.79k
                sign    verify    sign/s verify/s  rsa  512 bits 0.000776s 0.000067s   1288.3  14928.7
rsa 1024 bits 0.003946s 0.000199s    253.4   5013.4
rsa 2048 bits 0.025138s 0.000708s     39.8   1413.1
rsa 4096 bits 0.172931s 0.002698s      5.8    370.6
                sign    verify    sign/s verify/s  dsa  512 bits 0.000687s 0.000740s   1455.2   1351.6
dsa 1024 bits 0.001945s 0.002230s    514.2    448.4
dsa 2048 bits 0.006807s 0.007976s    146.9    125.4
                            sign    verify    sign/s verify/s   160 bit ecdsa (secp160r1)   0.0005s   0.0019s   2044.1    538.0
192 bit ecdsa (nistp192)   0.0006s   0.0025s   1631.9    399.1
224 bit ecdsa (nistp224)   0.0008s   0.0033s   1301.0    307.4
256 bit ecdsa (nistp256)   0.0010s   0.0044s   1042.4    229.6
384 bit ecdsa (nistp384)   0.0021s   0.0105s    487.7     95.5
521 bit ecdsa (nistp521)   0.0041s   0.0221s    244.8     45.2
163 bit ecdsa (nistk163)   0.0016s   0.0068s    633.9    147.9
233 bit ecdsa (nistk233)   0.0033s   0.0127s    300.7     78.8
283 bit ecdsa (nistk283)   0.0051s   0.0234s    196.6     42.8
409 bit ecdsa (nistk409)   0.0138s   0.0532s     72.7     18.8
571 bit ecdsa (nistk571)   0.0330s   0.1241s     30.3      8.1
163 bit ecdsa (nistb163)   0.0016s   0.0073s    637.4    136.7
233 bit ecdsa (nistb233)   0.0033s   0.0141s    302.8     71.1
283 bit ecdsa (nistb283)   0.0051s   0.0261s    195.4     38.3
409 bit ecdsa (nistb409)   0.0138s   0.0608s     72.4     16.4
571 bit ecdsa (nistb571)   0.0330s   0.1428s     30.3      7.0
                              op      op/s
160 bit ecdh (secp160r1)   0.0016s    629.2
192 bit ecdh (nistp192)   0.0021s    475.7
224 bit ecdh (nistp224)   0.0028s    350.9
256 bit ecdh (nistp256)   0.0036s    278.0
384 bit ecdh (nistp384)   0.0087s    115.2
521 bit ecdh (nistp521)   0.0186s     53.8
163 bit ecdh (nistk163)   0.0033s    302.3
233 bit ecdh (nistk233)   0.0062s    160.1
283 bit ecdh (nistk283)   0.0116s     86.3
409 bit ecdh (nistk409)   0.0264s     37.8
571 bit ecdh (nistk571)   0.0619s     16.2
163 bit ecdh (nistb163)   0.0036s    277.7
233 bit ecdh (nistb233)   0.0069s    145.8
283 bit ecdh (nistb283)   0.0129s     77.2
409 bit ecdh (nistb409)   0.0302s     33.1
571 bit ecdh (nistb571)   0.0711s     14.1
  这个结果与elinux.org针对此前版本Pi的测试结果相比,已经有了数量级的提升。当然与 x86 相比还有距离。我在若干年前的 Core2 系列的 T6700 上运行了同样的测试(Ubuntu 系统),得到如下结果:
  OpenSSL 1.0.1f 6 Jan 2014
built on: Mon May  2 16:53:18 UTC 2016
options:bn(64,64) rc4(16x,int) des(idx,cisc,16,int) aes(partial) blowfish(idx)
compiler: cc -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -m64 -DL_ENDIAN -DTERMIO -g -O2 -fstack-protector --param=ssp-buffer-size=4 -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -Wl,-Bsymbolic-functions -Wl,-z,relro -Wa,--noexecstack -Wall -DMD32_REG_T=int -DOPENSSL_IA32_SSE2 -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_MONT5 -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DMD5_ASM -DAES_ASM -DVPAES_ASM -DBSAES_ASM -DWHIRLPOOL_ASM -DGHASH_ASM
md4              48268.28k   150163.94k   362062.44k   549839.91k   646990.88k
md5              35666.09k   106668.63k   242385.28k   355862.56k   411523.46k
hmac(md5)        26447.70k    85679.33k   211473.33k   336846.88k   408587.72k
sha1             37939.04k   107192.58k   229484.95k   321413.19k   365554.16k
rmd160           24909.55k    60307.65k   111847.95k   141809.17k   154398.51k
rc4             189484.70k   305580.82k   355119.32k   371357.04k   372187.11k
des cbc          43420.45k    45014.02k    45551.02k    45111.51k    45343.83k
des ede3         16747.00k    17329.95k    17421.79k    17445.93k    17401.13k
seed cbc         47317.00k    48909.10k    49460.59k    49285.16k    49358.90k
rc2 cbc          21931.40k    22349.06k    22500.91k    22436.40k    22684.04k
blowfish cbc     74512.23k    79975.90k    81205.29k    81795.58k    81964.73k
cast cbc         71014.61k    77245.85k    78006.43k    78206.69k    78296.51k
aes-128 cbc      66731.52k    72357.75k    74361.88k   155478.59k   158728.96k
aes-192 cbc      56562.79k    60617.47k    61896.75k   132451.12k   133273.94k
aes-256 cbc      48786.44k    52074.47k    52883.59k   113208.20k   114146.45k
camellia-128 cbc    62848.46k    93167.45k   105857.21k   109411.99k   110804.39k
camellia-192 cbc    53379.26k    71797.96k    78682.33k    81116.71k    81601.73k
camellia-256 cbc    51971.81k    71605.14k    78708.93k    80735.27k    81665.66k
sha256           29443.97k    64104.38k   109337.77k   133225.84k   142733.88k
sha512           23202.21k    91714.63k   140732.16k   197079.11k   224267.72k
whirlpool        18494.59k    39534.42k    65681.58k    76647.95k    68388.03k
aes-128 ige      67564.18k    70331.17k    70053.71k    70720.47k    70851.15k
aes-192 ige      57027.17k    58884.57k    59061.79k    59394.76k    59356.26k
aes-256 ige      49199.09k    50868.54k    50682.93k    51129.66k    51095.54k
ghash           162318.13k   235443.74k   265612.37k   276384.15k   278754.18k
rsa  512 bits 0.000137s 0.000009s   7302.7 106627.1
rsa 1024 bits 0.000453s 0.000025s   2206.3  39296.2
rsa 2048 bits 0.002934s 0.000088s    340.8  11374.9
rsa 4096 bits 0.021522s 0.000326s     46.5   3068.3
dsa  512 bits 0.000106s 0.000111s   9474.2   9016.8
dsa 1024 bits 0.000263s 0.000304s   3802.9   3288.1
dsa 2048 bits 0.000862s 0.001058s   1160.2    945.5
160 bit ecdsa (secp160r1)   0.0001s   0.0004s   8750.3   2282.1
192 bit ecdsa (nistp192)   0.0001s   0.0005s   7208.2   1871.1
224 bit ecdsa (nistp224)   0.0001s   0.0003s   7512.7   3208.2
256 bit ecdsa (nistp256)   0.0002s   0.0005s   4982.0   1948.3
384 bit ecdsa (nistp384)   0.0004s   0.0020s   2385.1    512.4
521 bit ecdsa (nistp521)   0.0008s   0.0020s   1178.9    505.2
163 bit ecdsa (nistk163)   0.0003s   0.0015s   3099.5    663.9
233 bit ecdsa (nistk233)   0.0006s   0.0020s   1614.4    500.1
283 bit ecdsa (nistk283)   0.0010s   0.0044s   1018.5    225.9
409 bit ecdsa (nistk409)   0.0023s   0.0096s    426.1    104.4
571 bit ecdsa (nistk571)   0.0052s   0.0203s    193.8     49.3
163 bit ecdsa (nistb163)   0.0003s   0.0016s   3091.0    628.5
233 bit ecdsa (nistb233)   0.0006s   0.0021s   1606.7    477.1
283 bit ecdsa (nistb283)   0.0010s   0.0048s   1017.3    209.0
409 bit ecdsa (nistb409)   0.0024s   0.0107s    423.7     93.4
571 bit ecdsa (nistb571)   0.0052s   0.0233s    194.1     43.0
                              op      op/s
160 bit ecdh (secp160r1)   0.0004s   2709.2
192 bit ecdh (nistp192)   0.0004s   2323.3
224 bit ecdh (nistp224)   0.0002s   4669.5
256 bit ecdh (nistp256)   0.0004s   2709.4
384 bit ecdh (nistp384)   0.0017s    605.6
521 bit ecdh (nistp521)   0.0014s    694.0
163 bit ecdh (nistk163)   0.0007s   1358.1
233 bit ecdh (nistk233)   0.0010s   1010.8
283 bit ecdh (nistk283)   0.0021s    474.0
409 bit ecdh (nistk409)   0.0047s    213.7
571 bit ecdh (nistk571)   0.0100s     99.9
163 bit ecdh (nistb163)   0.0008s   1298.7
233 bit ecdh (nistb233)   0.0011s    925.2
283 bit ecdh (nistb283)   0.0024s    423.7
409 bit ecdh (nistb409)   0.0052s    193.6
571 bit ecdh (nistb571)   0.0115s     87.2
  可见,差距跑分差距明显,但是二者编译优化的差别也很明显。在 x86 上用了 SSE2 优化,而在 RPi3 上并无类似的优化,操作系统也是 32b 的。所以跑分的差距一部分来自硬件性能上的差距,另一部分应该来自于软件层面的优化工作。
