1. 板:board
  2. 印制板:printed board
  3. 印制电路:printed circuit
  4. 印制线路:printed wiring
  5. 印制线路板:printed wiring board(PWB)
  6. 印制板电路:printed circuit board (PCB)
  7. 印制接点:printed contact
  8. 印制组件:printed component
  9. 印制板装配:printed board assembly
  10. 单面印制板:single-sided printed board(SSB)
  11. 双面印制板:double-sided printed board(DSB)
  12. 多层印制板:mulitlayer printed board(MLB)
  13. 多层印制电路板:mulitlayer printed circuit board
  14. 多层印制线路板:mulitlayer prited wiring board
  15. 刚性印制板:rigid printed board
  16. 刚性单面印制板:rigid single-sided printed borad
  17. 刚性双面印制印制板装配:printed board assembly
  18. 刚性多层印制板:rigid multilayer printed board
  19. 挠性多层印制板:flexible multilayer printed board
  20. 挠性印制板:flexible printed board
  21. 挠性单面印制板:flexible single-sided printed board
  22. 挠性双面印制板:flexible double-sided printed board
  23. 挠性印制电路:flexible printed circuit (FPC)
  24. 挠性印制线路:flexible printed wiring
  25. 刚性印制板:flex-rigid printed board, rigid-flex printed board
  26. 刚性双面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed
  27. 刚性多层印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board
  28. 齐平印制板:flush printed board
  29. 金属芯印制板:metal core printed board
  30. 金属基印制板:metal base printed board
  31. 多重布线印制板:mulit-wiring printed board
  32. 陶瓷印制板:ceramic substrate printed board
  33. 导电胶印制板:electroconductive paste printed board
  34. 模塑电路板:molded circuit board
  35. 模压印制板:stamped printed wiring board
  36. 顺序层压多层印制板:sequentially-laminated mulitlayer
  37. 散线印制板:discrete wiring board
  38. 微线印制板:micro wire board
  39. 积层印制板:buile-up printed board
  40. 积层多层印制板:build-up mulitlayer printed board (BUM)
  41. 积层挠印制板:build-up flexible printed board
  42. 表面层合电路板:surface laminar circuit (SLC)
  43. 埋入凸块连印制板:B2it printed board
  44. 多层膜基板:multi-layered film substrate(MFS)
  45. 层间全内导通多层印制板:ALIVH multilayer printed board
  46. 载芯片板:chip on board (COB)
  47. 埋电阻板:buried resistance board
  48. 母板:mother board
  49. 子板:daughter board
  50. 背板:backplane
  51. 裸板:bare board
  52. 键盘板夹心板:copper-invar-copper board
  53. 动态挠性板:dynamic flex board
  54. 静态挠性板:static flex board
  55. 可断拼板:break-away planel
  56. 电缆:cable
  57. 挠性扁平电缆:flexible flat cable (FFC)
  58. 薄膜开关:membrane switch
  59. 混合电路:hybrid circuit
  60. 厚膜:thick film
  61. 厚膜电路:thick film circuit
  62. 薄膜:thin film
  63. 薄膜混合电路:thin film hybrid circuit
  64. 互连:interconnection
  65. 导线:conductor trace line
  66. 齐平导线:flush conductor
  67. 传输线:transmission line
  68. 跨交:crossover
  69. 板边插头:edge-board contact
  70. 增强板:stiffener
  71. 基底:substrate
  72. 基板面:real estate
  73. 导线面:conductor side
  74. 组件面:component side
  75. 焊接面:solder side
  76. 印制:printing
  77. 网格:grid
  78. 图形:pattern
  79. 导电图形:conductive pattern
  80. 非导电图形:non-conductive pattern
  81. 字符:legend
  82. 标志:mark
