            *原型:void write_lcdbit(unsigned char bit)
            *功能:LCD送数
            *说明:LCD-HT1622 数据在高锁存
            *参数:bit
            *返回:无
              CLR_LCDWD;
              if(!bit)  CLR_LCDDATA;
              SET_LCDWD;     //数据在高锁存
              SET_LCDDATA;
            *原型:void write_lcdbyte(unsigned char addr,unsigned char data)
            *功能:LCD送数
            *说明:LCD-HT1622 命令:101 100100 0101
            *参数:addr 地址,data 数据
            *返回:无
            {//命令:101?
             //地址:000111
             //数据:0001
               unsigned char i;
                 CLR_LCDCS;
                write_lcdbit(1);
                write_lcdbit(0);
                write_lcdbit(1);
                for(i=0;i<6;i++)//送地址
                  write_lcdbit(addr&0x20);
                  addr<<=1;
               for(i=0;i<4;i++)//送数
                  write_lcdbit(data&0x01);
                  data>>=1;
               SET_LCDCS;
            *原型:void write_lcdcmd(unsigned char cmd)
            *功能:LCD送命令
            *说明:LCD-HT1622 命令:101 10010 0101
            *参数:unsigned char cmd
            *返回:无
              unsigned char i;
                 CLR_LCDCS;
                write_lcdbit(1);
                write_lcdbit(0);
                write_lcdbit(0);
                for(i=0;i<8;i++)
                  write_lcdbit(cmd&0x80);
                  cmd<<=1;
                 write_lcdbit(1);
               SET_LCDCS;
            *原型:void update_lcd(unsigned char *p,unsigned char length)
            *功能:将显示缓冲区数据写入LCD ,长度为length
            *说明:LCD-HT1622
            *参数:*p  指向显示缓冲区,length 显示缓冲区长度
            *返回:无
              unsigned char i,j;
                  CLR_LCDCS;
                  write_lcdbit(1);
                write_lcdbit(0);
                write_lcdbit(1);
                for(i=0;i<6;i++)
                  write_lcdbit(0);
                for(i=0;i<length;i++)
                  for(j=0;j<8;j++)
                    write_lcdbit((*p)&0x01);
                   (*p)>>=1;
                  p++;
                SET_LCDCS;
