原厂料号 | 品牌 | DC | 品类 | 描述 |
HMC540LP3E | Analog Devices / Hittite | 131107 | 集成电路IC | 4Bit 1dBStep 15dB 5.5GHz 16-Pin LFCSP EP T/R |
PC28F00AM29EWHA | Micron | 1639 | 集成电路IC | FLASH - NOR Memory IC 1Gb (128M x 8, 64M x 16) Parallel 100ns 64-FBGA (11x13) |
ICL7660SIBAZ | Renesas | 1214 | 集成电路IC | Switching Regulator IC Fixed -Vin, 2Vin 1 Output 45mA 8-SOIC (0.154", 3.90mm Width) |
LT1076IT#06PBF | ADI | 1418 | 集成电路IC | Buck, Boost, Flyback Switching Regulator IC 2.5V 1 Output 2A (Switch) TO-220-5 |
SGA-6389Z | RFMD/Sirenza | 1421 | 放大器 | SGA6389Z高性能的SiGe HBT MMIC放大器 |
1P503AS | ANAREN | 1237 | 耦合器 | RF Directional Coupler General Purpose 1.7GHz ~ 2GHz 30W 4-SMD, No Lead |
600F2R4BT250T | ATC | 1448 | 电容 | Cap. 2.4pF 0805 Ceramic NPO/COG 250V SM |
LT1763CDE#TRPBF | Linear | 1513 | 集成电路IC | Linear Voltage Regulator IC 1 Output 500mA |
GVA-84+ | MINI CIRCUITS | 1449 | 射频放大器 | 射频放大器 SMT Gain Block, DC - 7000 MHz, 50 ohms |
PIC24FJ256GA106-E/PT | Microchip | 1117 | 集成电路IC | PIC PIC® 24F Microcontroller IC 16-Bit 32MHz 256KB (85.5K x 24) FLASH 64-TQFP (10x10) |
PE43701MLI-Z | Peregrine Semiconductor Corp. | 1615 | 集成电路IC | RF Attenuators 0dB ~ 31.75dB 9kHz ~ 6GHz 50 Ohms 32-VFQFN Exposed Pad |
MT29F8G16ADBDAH4-IT | Micron | 1248 | 集成电路IC | FLASH - NAND Memory IC 8Gb (512M x 16) Parallel 63-VFBGA (9x11) |
MBRD640CTT4G | Onsemi | 1407 | 二极管 | DIODE ARRAY SCHOTTKY 40V 3A DPAK |
HSMP-4820-TR1G | Avago | 1349 | 二极管 | RF Diode PIN - Single 50V 1A SOT-23-3 |
AT32UC3C1256C-AU | Atmel | 130106 | 集成电路IC | AVR AVR®32 UC3 C Microcontroller IC 32-Bit 66MHz 256KB (256K x 8) FLASH 100-TQFP (14x14) |
TC1121COA-G | Microchip | 1234 | 集成电路IC | IC REG CHARGE PUMP INV 8SOIC |
MAX4649EKA+T | MAXIM | 1647 | 集成电路IC | 1 Circuit IC Switch 2:1 45Ohm SOT-23-8 |
STPS340S | ST | 1440 | 二极管 | DIODE SCHOTTKY 40V 3A SMC |
SGA-7489Z | RFMD/Sirenza | 1502 | 射频放大器 | RF Amplifier DC-3GHz SSG 18.5dB NF 3.3dB SiGe |
MTEDCAE002SAJ-1M2 | Micron | 151214 | 集成电路IC | MODULE FLASH NAND SLC 2GB |
TC1121EOA | Microchip | 1148 | 集成电路IC | IC REG CHARGE PUMP INV 8SOIC |
LTC1844ES5-1.8#TRPBF | Linear | 130618 | 集成电路IC | Linear Voltage Regulator IC 1 Output 150mA TSOT-23-5 |
AT25512N-SH | Atmel | 1522 | 集成电路IC | EEPROM Memory IC 512Kb (64K x 8) 20MHz 8-SOIC |
TPS54140DGQR | TI | 1731 | 集成电路IC | IC REG BUCK ADJ 1.5A 10MSOP |
MMG3005NT1 | NXP | 12+ | 集成电路IC | 放大器 |
有兴趣的老板可以下载【爱电子APP】或者加我微信,微信号glen9088(备面包社区)
