这段代码早前也曾曝光。各位来审判一下。
2011 年的时候,@程序员的那些事在微博转过雷军在 1994 年写的一段完整的汇编代码。后来雷军在转发上条微博时还补充说:「这个程序第一个版本是我 1989 年写的,怀念当初写程序的快乐时光。」
; RI.ASM Revision2.12[ July12,1994]
Revision equ'V2.12 '
; RAMinit Release2.0
; Copyright (c)1989-1994by Yellow Rose Software Co.
; Written by Mr. Leijun
; Function:
; Press HotKey to remove all TSR program afterthisprogram
; Removed Softwares by RI:
; SPDOS v6.0F, WPS v3.0F
; Game Busters III, IV
; NETX ( Novell3.11)
; PC-CACHE
; Norton Cache
; Microsoft SmartDrv
; SideKick1.56A
; MOUSE Driver
; Crazy (Monochrome simulate CGA program)
; RAMBIOS v2.0
;386MAX Version6.01
; No cancel softwares:
; Windows3.1MSD
; No removed TSR softwares:
; MS-DOS fastopen
; Buffers, Files ... (QEMM6.0)
; QCache (386MAX6.01)
COMMENT
V2.04Use mouse driver software reset function to initiation mouse
2/17/1993by Mr. Lei and Mr. Feng
V2.05RI cannot work in Windows DOS prompt
3/9/1993by Mr. Lei
V2.061.When XMS cannot allocate1K memory, RI halts.
2.RI repeat deallocates EMS memory.
V2.07HotKey Setup Error
4/25/1993by Mr. Lei
V2.08KB Buffer
V2.101.Release high memoryblocks(EMM386 QEMM386 S-ICE386MAX)
2. RI copies flag
V2.12 1. Exists a critical error in Init 8259 procedure
2. Save [40:F0--FF] user data area
dosseg
.model tiny
.code
locals @@
org 100h
Start: jmp Main
org 103h
True equ 1
False equ 0
MaxHandles equ 100h
INT3 macro
out 0ffh,al
endm
; HotKey Status Test Var
;76543210417418496
; . . x . x . . . Left Alt is pressed82
; x . . . x . . . Right Alt is pressed88
; . . . x . x . . Left Ctrl is pressed41
; . x . . . x . . Right Ctrl is pressed44
; . . . . . . x . Left Shift is pressed2
; . . . . . . . x Right Shift is pressed1
LeftAlt equ00101000b
RightAlt equ10001000b
LeftCtrl equ00010100b
RightCtrl equ01000100b
LeftShift equ00000010b
RightShift equ00000001b
HotKey db LeftCtrl or RightCtrl
DataBegin dw0
NextDataSeg dw0ffffh
oldInt2F_addr dw0,0
XMS_control dw0,0
Handle_begin dw0
cvtOfs dw0; DOS3.0equ0and above DOS4.0is1
org104h
db0dh
db Revision
db ??date
db26
org114h
tsrLength dw0
MachineID db0FCh ; IBM PC/AT
AuxHotKey db0;2Dh ;'X'Scan Code
AuxHotKeyName db'X$ '
Power db True
Flag db'!'
Kbd102 db0
NoFlag db0
StopFlag db1
DosEnv dw0
WorkSeg dw0
PrevDataSeg dw0
Copies db'1'
old_8259 db0;21h port
db0; a1h port
Status dw0
XMSbit equ00000001b
EMSbit equ00000010b
SKbit equ10000000b
GoINT1C: db0eah
oldInt1C_addr dw0,0
newINT1C:
test cs:Status, SKbit
jnz GoINT1C
cmp cs:StopFlag,0
jz @@0
; Mr. Lei2/8/1993
; Problem:ifWPS quit and reenter, old RI cann't control keyboard. ;
push ds
push ax
xor ax, ax
mov ds, ax
mov ax, ds:[94]
cmp ax, offset NewInt9
pop ax
pop ds
jnz GoINT1C
mov cs:StopFlag,0
@@0: push ax
push ds
push es
xor ax, ax
mov ds, ax
mov es, ds:[94+2]
cmp word ptr es:[101h],'IE';'LEI'
jz @@1
cli
mov cs:StopFlag,1
mov ax, ds:[94]
mov cs:oldINT9_addr2, ax
mov ax, ds:[94+2]
mov cs:oldINT9_addr2[2], ax
mov ds:[94], offset newINT9_2
mov ds:[94+2], cs
sti
@@1: pop es
pop ds
pop ax
jmp GoINT1C
; INT2F Func
; AX = C0D7h Return RI segment in AX
; AX = C0D8h Removes all TSR programs after RI
; AX = C0D9h Removes all TSR programs include RI
; AX = C0DAh Removes all RI copies
newINT2F:
cmp ax,0c0d7h ; LEI Hanzi GB Code
jnz @@1
push cs
pop ax
iret
@@1: cmp ax,0c0d7h+1
jnz @@2
jmp KeepSelf
@@2: cmp ax,0c0d7h+2
jnz @@3
jmp NoKeepSelf
@@3: cmp ax,0c0d7h+3
jnz @@9
mov cs:NextDataSeg,-1
mov cs:Copies,'1'
jmp NoKeepSelf
@@9: jmp dword ptr cs:oldInt2F_addr
CallInt9:
ret
newINT9_2:
mov cs:NoFlag,1
pushf
db9ah ; call far ptr oldint9_addr
oldInt9_Addr2 dw0,0
jmp newINT9_proc
newINT9:
pushf
oldInt9_Addr dw0,0cmp cs:NoFlag,0
jz newINT9_proc
mov cs:NoFlag,0
iret
newINT9_proc:
cmp cs:Flag,'!'; busy ?
jnz @@0
iret
@@0:
mov cs:Flag,'!';setbusy flag
push ax ; cmp hot key
push bx
push es
mov ax,40h
mov es,ax
cmp cs:AuxHotKey,0
jz @@_1
mov bx, es:[1ah]
cmp bx, es:[1ch]
jz @@10
push bx
mov bl, es:[bx+1]
cmp bl, cs:AuxHotKey
pop bx
jnz @@10
@@_1:
mov ah,es:[17h] ; test CTRL SHIFT ALT
mov al,cs:HotKey
push ax
and ax,0f0fh
cmp al,ah
pop ax
jnz @@10cmp cs:Kbd102, True
jnz @@1
shr al,1
shr al,1
shr al,1
shr al,1
push ax
mov ah, es:[18h]
and ax,303h
cmp al, ah
pop ax
jnz @@10
mov ah, es:[96h]
shr ax,1
shr ax,1
and ax,303h
cmp al, ah
jnz @@10cmp cs:AuxHotKey,0
jz @@_3
inc bx
inc bx
cmp bx,3eh
jb @@_2
mov bx,1eh
@@_2:
mov es:[1ah], bx
@@_3:
call IsWinDos
or ax, ax
jz @@1
call Beep
@@10:
sti
pop es
pop bx
pop ax
mov cs:Flag,' '; no busy
iret
@@1: ; OK
pop es
pop bx
pop ax
KeepSelf:
call RemoveTSR
push es
mov es,cs:WorkSeg
mov dx,es:tsrLength
mov di,dx
mov al,0h ; Aug24,1993
mov cx,100h
rep stosb
pop es
int27h
NoKeepSelf:
mov ax,0e07h
int10h
mov cs:clsStr,47h ; Color (White in Red)
call RemoveTSR
dec cs:Copies
call RestoreSelfIntVec
push es
cmp cs:PrevDataSeg,0
jz @@1
mov es, cs:PrevDataSeg
mov es:NextDataSeg,-1
@@1: pop es
mov ax,4c00h
int21h
IsWinDOS:
mov ax,1600h
int2fh
cmp al,01h
jz @@9cmp al,0ffh
jz @@9; Windows/386Version2.X
cmp al,00h
jz @@1cmp al,80h
jnz @@9; Windows3in enhanced mode
; Version number in AL/AH
@@1:
mov ax,4680h
int2fh
cmp al,80h
jnz @@9
xor ax, ax
jmp @@10
@@9: mov ax,1
@@10: ret
RestoreSelfIntVec:
cmp Copies,'0'
jz @@0
ret
@@0:
cli
push cs
pop ds
xor ax, ax
mov es, ax
mov si, offset oldInt9_Addr
mov di,94
movsw
movsw
mov si, offset oldInt2F_Addr
mov di,2Fh4
movsw
movsw
mov si, offset oldInt1C_Addr
mov di,1Ch4
movsw
movsw
sti
ret
; ------------- KERNEL PROGRAM ----------------------------------------------
RemoveTSR:
pop ax
cli ; Setstack
mov sp, cs
mov ss, sp
mov sp,100h
sti
push ax
cmp cs:Power, True
jnz @@1
call Init8259
@@1:
push cs
pop ds
@@_0:
mov ax,ds:NextDataSeg
cmp ax,-1
jz @@_1
mov cs:PrevDataSeg, ds
mov ds, ax
jmp @@_0
@@_1: mov si,ds:DataBegin
mov cs:WorkSeg, ds
lodsw
cmp ax,'XX'
jz @@_2
call Beep
ret
@@_2:
call RestoreEnvStr
call RestoreMCB ; restore current mcb
call CloseFiles
call RestorePort
call RestoreLEDs
call RestoreVecList ; Restore vectorslist
call RestoreFloppyParam
cmp cs:Power, True
jnz @@2
call RestoreCVTchain ; Restore cvt chain
call RestoreMemoryManager
@@2:
call RestoreBiosData
call Enable8259
mov ah,1int16h
call RestoreClockSpeed
call CloseSpeaker
call ResetDisk
call UpdateTime
call ClosePRN
mov bx,cs:WorkSeg
mov ah,50h
int21h ; Set PSP segment
mov ax,3int10h ; Set display mode
call InitPRN
call InitMouse
mov al, cs:Copies
cmp al,'1'
ja @@_sh1
mov cs:ShowCopies,''
jmp @@_sh2
@@_sh1: mov cs:ShowCopies, al
@@_sh2:
mov si, offset clsStr
call ColorPrintStr
mov cs:Flag, '' ; no busy
cmp Copies, '1'
jnz @@_end
mov cs:StopFlag,0
@@_end:
call ClearKB_buffer
ret
Beep:
mov ax,0e07h
int10h
ret
ClearKB_Buffer:
push es
push bx
mov bx,0040h
mov es, bx
cli
mov bx, es:[1ah]
mov es:[1ch], bx
sti
pop bx
pop es
ret
Init8259:
; cmp cs:Copies,'1'
; jz @@1
; ret
@@1:
cmp cs:MachineID,0fch
ja @@pc_xt
@@AT:
mov bx,870h ;
mov al,0;
out0F1h,al ;
jcxz $+2
jcxz $+2
mov al,11h ; ICW1
out0A0h,al
jcxz $+2
jcxz $+2
out20h,al
jcxz $+2
jcxz $+2
mov al,bl ; ICW2
out0A1h,al
jcxz $+2
jcxz $+2
mov al,bh
out21h,al
jcxz $+2
jcxz $+2
mov al,2; ICW3
out0A1h,al
jcxz $+2
jcxz $+2
mov al,4
out21h,al
jcxz $+2
jcxz $+2
mov al,1; ICW4
out0A1h,al
jcxz $+2
jcxz $+2
out21h,al
jcxz $+2
jcxz $+2
mov al,0FFh ; OCW1
out0A1h,al
jcxz $+2
jcxz $+2
out21h,al
ret
@@PC_XT:
mov al,13h ; ICW1
out20h,al
jcxz $+2
jcxz $+2
mov al,8; ICW2
out21h,al
jcxz $+2
jcxz $+2
mov al,9; ICW4
out21h,al
jcxz $+2
jcxz $+2
mov al,0FFh ; OCW1
out21h,al
ret
Enable8259:
mov ax, word ptr cs:old_8259
out021h,al
jcxz $+2
jcxz $+2
mov al,ah
out0a1h,al ; DEC PC Bus Mouse
ret ; July1994by Mr. Lei
RestoreBiosData:
lodsw
cmp ax,'--'
jz @@1
call Beep
ret
@@1: push es
push di
mov di,40h
mov es, di
mov di,10h
movsw
mov di,0a8h ; [40h:a8h]
movsw
movsw
mov di,49h
mov cx,1dh
rep movsb
mov di,0f0h ; User data
mov cx,8
rep movsw
pop di
pop es
ret
RestoreMCB:
push ds
push es
lodsw ;'MZ'
@@0: lodsw
cmp ax,'MM'
jz @@1
mov es,ax
xor di,di
movsb
movsw
movsw
inc ax
mov bx, ds
cmp ax, bx
jz @@10
mov byte ptr es:[8],0; Aug24,1993
@@10: cmp byte ptr es:[0],'Z'
jnz @@0
mov byte ptr es:[10h],0
jmp @@0
@@1:
pop es
pop ds
ret
CloseFiles:
mov ax,5; Begin handle
push ds
push si
mov cx,15; Max handle
sub cx, ax
inc cx
mov bx, ax
@@1: push bx
push cx
mov ah,3eh
int21h
pop cx
pop bx
inc bx
loop @@1
pop si
pop ds
ret
RestorePort:
mov di,40h ; restore port
mov es, di
xor di, di
mov cx,8
rep movsw
ret
RestoreLEDs:
lodsb
and al,11110000b; LED status
mov ah, es:[17h]
and ah,00001111b
or ah, al
and ah,0f0h ; Clear CTRL ALT SHIFT
mov es:[17h], ah
ret
RestoreEnvStr:
lodsw
push si
push di
push ds
push es
mov es, cs:DosEnv
mov ds, ax
xor si, si
mov di, si
@@0: lodsb
or al, al
jnz @@1cmp byte ptr ds:[si],0
jz @@2
@@1: stosb
jmp @@0
@@2: stosb
stosb
pop es
pop ds
pop di
pop si
ret
RestoreVecList:
xor ax,ax
mov di,ax
mov es,ax
mov cx,100h
@@0: lodsw
xchg dx, ax
lodsw
cmp dx,'EL'
jnz @@1cmp al,'I'
jnz @@1
sub cl, ah
push cx
mov cl, ah
mov ax, es:[di-4]
mov dx, es:[di-2]
@@a: stosw
xchg ax, dx
stosw
xchg ax, dx
loop @@a
pop cx
or cx, cx
jz @@9
jmp @@0
@@1:
xchg ax, dx
stosw
xchg ax, dx
stosw
loop @@0
@@9:
ret
RestoreFloppyParam: ; Mr. Lei2/10/1992
push es
push ax
xor ax, ax
mov es, ax
mov byte ptr es:[525h],2
pop ax
pop es
ret
RestoreCVTchain:
lodsw
cmp ax,'VC'
jz @@_0
call Beep
ret
@@_0:
push ax
push cx
push es
lodsw ; DPB
mov di, ax
lodsw
mov es, ax
@@1: lodsb
inc di
stosb
add di, cs:cvtOfs
add di,10h
movsw
movsw
les di, es:[di+2]
cmp di,-1
jnz @@1
lodsw ; DCB
mov di, ax
lodsw
mov es, ax
xor ax, ax
dec ax
stosw
lodsw ; Device Driver Chain
mov di, ax
lodsw
mov es, ax
xor cx, cx
@@9: push di
mov cl,5
rep movsw
pop di
les di, es:[di]
mov ax, di
inc ax
jnz @@9
pop es
pop cx
pop ax
ret
RestoreMemoryManager:
test cs:Status, XMSbit
jz @@1
call LoadXMSstatus
@@1:
test cs:Status, EMSbit
jz @@2
call LoadEMSstatus
@@2:
ret
LoadEMSstatus:
lodsw
cmp ax,'ME'
jz @@_0
call Beep
ret
@@_0:
lodsw
mov cx, ax
xor dx, dx
@@_1: push ds
push si
push dx
push cx
@@0: cmp dx, ds:[si]
jz @@1
add si,4
loop @@0
push cx
mov cx,5
@@0: mov ah,45h ; Deallocate Handle and Memory
int67h
or ah, ah
jz @@1
loop @@0
@@1: pop cx
@@1:
pop cx
pop dx
pop si
pop ds
inc dx
cmp dx,100h
jb @@_1
shl cx,1
shl cx,1
add si, cx
ret
LoadXMSstatus:
lodsw
cmp ax,'MX'
jz @@_0
call Beep
ret
@@_0:
lodsw
mov cx, ax
jcxz @@5
@@1:
lodsw
mov dx, ax
@@2: push dx
mov ah,0ah ;free
call dword ptr cs:xms_control
or ax, ax
pop dx
jnz @@4cmp bl,0abh
jnz @@4
push dx
mov ah,0dh ; unlock
or ax, ax
pop dx
jmp @@2
@@4: loop @@1
@@5: ret
endp
CloseSpeaker:
in al,61h
and al,0fch
out61h, al
ret
RestoreClockSpeed:
mov al,00110110b
out43h, al
xor ax, ax
out40h, al
out40h, al
ret
ResetDisk:
xor ax, ax
xor dx, dx
int13h ; Restore A
inc dx
int13h ; Restore B
mov dl,80h
int13h ; Restore C
ret
ClosePRN:
mov ah,51h ; Get PSP seg
int21h
mov es, bx
mov ax, es:[16h] ; Prev PSP seg
cmp ax, bx
jnz @@9
mov ax,3e00h ; COMMAND
mov bx,4int21h
@@9:
ret
InitPRN:
mov ax,3e00h
mov bx,4; PRN
int21h
mov ax,3d01h
mov dx, offset PRNname
push cs
pop ds
int21h
ret
PRNname db'PRN',0
InitMouse: ;2/16/1993by Mr. Lei
push es
xor ax, ax
mov es, ax
cmp word ptr es:[33h4+2],0
jz @@0cmp word ptr es:[33h4],0
jz @@0
mov ax,21h
int33h ; Hook Mouse Interrupt
@@0: pop es
ret
; ------------- CMOS CLOCKsetto System -----------------------------------
UpdateTime:
call GetRealTime
mov ah,2dh
int21h
ret
GetRealTime:
mov ah,2int1Ah
mov al,ch
call bcdxchg
mov ch,al
mov al,cl
call bcdxchg
mov cl,al
mov al,dh
call bcdxchg
mov dh,al
mov dl,0
ret
BCDxchg:
push ax
push cx
mov cl,4
shr al,cl
pop cx
mov bl,0Ah
mul bl
pop bx
and bl,0Fh
add al,bl
ret
; Displaystring
ColorPrintStr:
lodsb
mov bh, al ; color
xor cx, cx
mov dx,014fh
mov ax,0600h
int10h
mov ah,02; GotoXY (0,0)
xor dx, dx
mov bh,0int10h
PrintStr:
push cs
pop ds
xor bx, bx
@@1: lodsb
cmp al,'
jz @@2
or al, al
jz @@2
mov ah,0eh
int10h
jmpshort@@1
@@2: mov al, cs:clsStrcolor
mov cs:clsStr, al
ret
Self dw0
clsStrcolor db17h
clsStr db17h ; Color (White in Blue)
db' RAMinit Version 2.12 (c) 1989-1994 by KingSoft Ltd. Mr. Leijun'
db0dh,0ah
db' ['
ShowCopies db''
db '] Activate...',0ah,0dh,'
endTSR equ $
mcbList equ offset endTSR +2+2
vecList equ mcbList +710+2+10h +1+400h
devLink equ vecList +4+526+4+1030h +4
xmsList equ devLink +2+ MaxHandles 2
emsList equ xmsList +4+1024
crtMode equ emsList +2+1Dh +4+10h
tsrLen equ crtMode +1
; DOS Environment Reserved by RI
; Flag'XX'2bytes
; Environment Segment1word
; Free MCBs <=710bytes
; MCB segment1word
; MCB5bytes
; End flag'MM'1word
; COM LPT ports10h bytes
; LEDs status1bytes
; Packed vectorslist<=400h bytes
; Flag 'CV' 2 bytes
; CVT First DPB pointer 4 bytes
; DPBs data <=526 bytes
; First DCB pointer 4 bytes
; Pointer to NUL 4 bytes
; All device driver datas <=30h10 bytes
; Flag 'XM' 2 bytes
; XMSfreehandle counter 2 bytes
; EMSfreehandlelist<=100h4 bytes
; Flag 'EM' 2 bytes
; EMSfreehandle counter 2 bytes
; EMSfreehandlelist<=1024 bytes
; EMS handle 1 word
; Number of pages 1 word
; Flag '--' 1 word
; Equipment List 1 word
; CRT 40:49h-66h 1dh bytes
; 40:A8h 1 dword
; BIOS User Data Area 40:F0--FF 10h bytes
main: jmp main0
Print Macro Str
Lea dx, Str
call DisplayStr
endm
InstMsg db 'RAMinit Version 2.12 '
db 'Copyright (c) 1989-1994 by KingSoft Ltd. ',0dh,0ah,'
Msg0 db 'Already installed !',0dh,0ah,0ah
db 'For Help, type "RI /?". ',0dh,0ah,'
Msg_0 db 0ah,'Residents anewRAMinit copy [y/n] ?
Msg_2 db 'OK, RI No.'
Msg_RI db '2'
db ' residents successful !', 0dh,0ah,'
Msg1 db 'Activate with:
KeyMsg db 'Right_Shift
db 'Left_Shift$ '
KMsg1 db 'Left_Ctrl$ '
db 'Left_Alt$ '
db 'Right_Ctrl$ '
db 'Right_Alt$ '
KMsg2 db 'Ctrl$ '
db 'Alt$ '
db 'Ctrl$ '
db 'Alt$ '
PlusMsg db ' +
crlf db 0dh,0ah,'
HelpMsg db 'Programmed by Mr. Leijun Dec 1992', 0dh,0ah,0ah
db 'Usage: RI [options]',0dh,0ah,0ah
db '/H,/? Displaythisscreen',0dh,0ah
db '/CLS Removes all TSR programs after current RI',0dh,0ah
db '/RET Removes TSR programs include current RI',0dh,0ah
db '/NEW Residents anewdata copy of current environment',0dh,0ah
db '/ALL Removes all RI copies and all other tsr programs',0dh,0ah
db '/Sxyy.. Define Hotkey x=AuxHotkey yy..=shift status',0dh,0ah
db ' x=auxiliary hotkey (defaultis "X") ',0dh,0ah
db ' x equ "1" means need AuxHotkey',0dh,0ah
db ' yy..=shift status [CAScas]',0dh,0ah
db ' C: Left Ctrl A: Left Alt S: Left Shift',0dh,0ah
db ' c: Right Ctrl a: Right Alt s: Right Shift',0dh,0ah,0ah
db 'Example: "RI /S1c" means Hotkey is Right_Ctrl+X',0dh,0ah
db ' "RI /S0Cc" means HotKey is Left_Ctrl+Right_Ctrl',0dh,0ah
db ' "RI /CLS" equals simply press hotkey',0dh,0ah
db ' "RI /RET" Removes all TSRs after current RI andthisRI',0dh,0ah
db 0ah
db 'Contact meforRAMinit problems: (01)2561155 Call 1997',0dh,0ah
db '
ErrMsg db 'ERROR: Invalid options !',0dh,0ah,0ah,'
WinErr db 7, 'Sorry, I cannot work in Windows DOS environment.',0dh,0ah,'
SetMsg db 7, 'DefinesnewHotkey successful !',0dh,0ah,0ah,'
tsrOK db False
Main0:
cld
Print instMsg
call IsWinDos
or ax, ax
jz @@1
Print WinErr
mov ax, 4c00h
int21h
@@1:
call HotKeyValid
mov cs:Status, 0
call EMS_test
call CmpDosVer
call CmpSideKick
call GetMachineID
call ModifyHotKeyPrompt
mov ax, 0c0d7h
int2fh
mov es, ax
cmp word ptr es:[101h], 'IE' ; 'LEI'
jnz @@0
mov cs:Self, ax
@@0:
call CmdLine
call PrintHotKeyPrompt
cmp cs:tsrOK,true
jz @@2
call tsrReplyOK
@@2: cmp cs:tsrOK,true
jnz @@_2
call PrintCopies
@@_2:
mov word ptr cs:[100h], 'EL'
mov byte ptr cs:[102h], 'I'
push cs
pop es
push cs
pop ds
std
mov si, offset eof
mov cx, eof - offset Here
mov di, tsrLen
add di, cx
inc cx
rep movsb
cld
mov bx, tsrLen
jmp bx
Here:
mov ax,cs
mov es,ax
mov di,offset endTSR
mov cs:DataBegin, di
mov cs:NextDataSeg, -1
mov ax, 'XX'
stosw
in al, 0a1h
mov ah, al
in al, 21h
push ax
mov word ptr cs:old_8259, ax
xor ax, ax
out 21h,al ; CLI
call SaveOthers
call SetSelfInt
call BackupVecList
cmp cs:Power,true
jnz @@20
call BackupCVTchain
call BackupMemoryManager
@@20:
call BackupBiosData
sti
mov cs:Flag, ' ' ; no busy
mov cs:StopFlag, 0 ;
mov cs:tsrLength, di
call SetDosEnvSeg
cmp cs:Self, 0
jz @@29
push cs
pop ds
push cs
pop es
cld
mov cx, cs:tsrLength
mov si, cs:DataBegin
sub cx, si
mov di, 120h
rep movsb
@@29:
pop ax
out 21h, al ; STI
mov al, ah
out 0a1h, al
mov dx, cs:tsrLength
inc dx
int27h
SetDosEnvSeg:
push ds
push es
mov ax, cs
@@10: mov es, ax
mov ax, es:[16h] ; Get father process psp segment
or ax, ax
jz @@11
mov bx, es
cmp ax, bx
jnz @@10
@@11:
mov es, word ptr es:[2ch] ; Get father process env segment
mov cs:DosEnv, es
pop es
pop ds
ret
SaveOthers:
mov ax, cs:[2ch] ; Env Seg
stosw
call backupMCB ; Current MCB
mov ax, 40h ; COM LPT Port
mov ds, ax
mov si, 0h
mov cx, 8
rep movsw
mov si, 17h ; LED status
lodsb
stosb
; call OpenLEDs
ret
backupMCB:
mov ax, 'ZM'
stosw
push ds
push es
mov ah, 52h
int21h ; Get MCB chain head
mov ax, es:[bx-2]
pop es
@@0: mov ds, ax
cmp byte ptr ds:[0], 'Z' ; End ?
jz @@20 cmp byte ptr ds:[0], 'M' ; Memory control block
jnz @@30 cmp word ptr ds:[3], 0 ; Nul mcb
jz @@10 cmp word ptr ds:[1], 0 ; Free MCB
jnz @@10
call SaveFreeMCB
@@10: inc ax
add ax, ds:[3]
jmp @@0
@@20:
call SaveFreeMCB
cmp ax, 0a000h
inc ax
jnb @@30
mov ax, 9fffh ; MS-DOS UMB
jmp @@0
@@30:
cmp ax, 0c000h ; 386MAX
ja @@90
mov ax, 0c020h
jmp @@0
@@90: ; Error ?
pop ds
mov ax, 'MM' ; Set MCB flag
stosw
ret
SaveFreeMCB:
stosw
xor si,si
movsb
movsw
movsw
ret
; push ax
; stosw
; xor si,si
; movsb
; movsw
; movsw
; pop ax
; cmp ax, 09fffh
; jnb @@3
; push ax
; push ds
; mov ds,ax
; cmp byte ptr ds:[0], 'M'
; pop ds
; pop ax
; jnz @@4
; mov ax, 09fffh ; MS-DOS UMB
; jmp @@0
; @@4: cmp ax, 0c000h
; ja @@3
; mov ax, 0c020h ; 386MAX
; jmp @@0
OpenLEDs: push ax ; Open all LEDs
or al, 070h
mov ds:[17h], al
mov ah, 1int16h
mov cx, 4 ; Delay
@@20: push cx
xor cx, cx
@@21: loop @@21
pop cx
loop @@20
pop ax
mov ds:[17h], al
mov ah, 1int16h
ret
SetSelfInt:
push es
push di
cmp cs:self, 0
jnz @@1
push cs
pop ds
mov ax,3509h
int21h
mov word ptr cs:oldInt9_addr,bx
mov word ptr cs:oldInt9_addr[2],es
mov dx,offset NewInt9
mov ax,2509h
int21h
mov ax,352Fh
int21h
mov word ptr cs:oldInt2F_addr,bx
mov word ptr cs:oldInt2F_addr[2],es
mov dx,offset newInt2F
mov ax,252Fh
int21h
mov ax,351Ch
int21h
mov word ptr cs:oldInt1C_addr,bx
mov word ptr cs:oldInt1C_addr[2],es
mov dx,offset newInt1C
mov ax,251ch
int21h
cli
jmp @@2
@@1:
mov es, cs:Self
inc es:Copies
@@_0: cmp es:NextDataSeg, -1
jz @@_1
mov es, es:NextDataSeg
jmp @@_0
@@_1: mov es:NextDataSeg, cs
@@2:
pop di
pop es
ret
SaveCounter:
mov word ptr es:[di], 'EL'
mov byte ptr es:[di+2], 'I'
mov byte ptr es:[di+3], bl
xor bx, bx
add di, 4
ret
DisplayStr: push cs
pop ds
mov ah, 9int21h
ret
CmdLine:
push cs
pop ds
xor ax, ax
mov si, 80h
lodsb
or al, al
jnz @@1
ret
@@1:
mov cx, ax
dec ax
push ax
push si
@@0: lodsb
cmp al, ' '
jz @@0 cmp al, '/'
jnz @@2
lodsb
cmp al, 'S'
jz @@_2
cmp al, 's'
jnz @@2
@@_2:
call SetHotKey
Print SetMsg
mov ax, 4c00h
int21h
@@2:
pop si
pop ax
push ax
push si
@@_3: lodsb
cmp al, 'A'
jb @@3 cmp al, 'Z'
ja @@3
add byte ptr ds:[si-1],20h ; DownCase
@@3: loop @@_3
pop si
pop cx
add si, cx
lodsb
cmp al, 's' ; CLS
jnz @@5 cmp word ptr ds:[si-3], 'lc'
jnz @@5 cmp cs:Self, 0
jz @Err
mov ax, 0c0d7h+1int2fh
@@5: cmp al, 'h' ; HELP
jz @help
cmp al, '?'
jz @help
cmp al, 't' ; RET
jnz @@6 cmp word ptr ds:[si-3], 'er'
jnz @@6
@@7:
cmp cs:Self, 0
jz @Err
mov ax, 0c0d7h+2int2fh
@@6: cmp al, 'w' ; NEW
jnz @@8 cmp word ptr ds:[si-3], 'en'
jnz @@8
mov cs:tsrOK,true
ret
@@8:
cmp al, 'l' ; ALL
jnz @@9 cmp word ptr ds:[si-3], 'la'
jnz @@9
mov ax, 0c0d7h+3int2fh
@@9:
cmp al, ' '
jnz @Err
ret
@Err:
Print ErrMsg
@help:
Print HelpMsg
mov ax, 4c00h
int21h
tsrReplyOK:
cmp cs:Self, 0
jz @@1
Print Msg0
push es
mov ax, cs:Self
@@_10: mov es, ax
mov ax, es:NextDataSeg
cmp ax, -1
jnz @@_10
mov ax, es
@@_0: push ax
dec ax
mov es, ax
mov bx, es:[3]
pop ax
add ax, bx
inc ax
mov es, ax
cmp word ptr es:[0], 'OC'
jz @@_0
mov bx, cs
cmp ax, bx
pop es
jz @@2
Print Msg_0
mov ah, 1int21h
push ax
Print crlf
pop ax
cmp al, 'y'
jz @@3 cmp al, 'Y'
jz @@3
@@2: ; Print Msg_1
mov ax, 4c01h
int21h
@@3:
@@1: mov cs:tsrOK,true
ret
PrintCopies:
cmp cs:Self, 0
jz @@1
push es ; Added -by- Mr. Lei
mov es, cs:Self ; Aug 24, 1993
mov al, es:Copies
inc al ; Total RI copies
push ax ; Set es = current mcb
mov ax, cs
dec ax
mov es, ax
pop ax
mov cx, 5 ; Search end of file name
mov bx, 8
@@10: inc bx
cmp byte ptr es:[bx], 20h
jz @@20 cmp byte ptr es:[bx], 0ffh
jz @@20 cmp byte ptr es:[bx], 00h
jz @@20
loop @@10
@@20: ; Set current RI no
mov byte ptr es:[bx], ':' ; "RI:2"
mov byte ptr es:[bx+1], al
cmp bx, 8+7
jnb @@30
mov byte ptr es:[bx+2], 0
@@30:
pop es
mov cs:Msg_RI, al
Print Msg_2
@@1: ret
; Backup Interrupt Vector List
BackupVecList:
push ds
push cs
pop es
xor si,si ; Vectors
mov ds,si
movsw
movsw
xor bx, bx
mov cx,00ffh
@@0: lodsw
xchg dx, ax
lodsw
cmp ax, es:[di-2]
jnz @@1 cmp dx, es:[di-4]
jz @@2
@@1: or bx, bx
jz @@3
call SaveCounter
@@3: xchg dx, ax
stosw
xchg dx, ax
stosw
loop @@0
jmp @@4
@@2: inc bx
loop @@0
call SaveCounter
@@4:
pop ds
ret
BackupCVTchain:
mov ax, 'VC'
stosw
push ax
push bx
push cx
push ds
push es
mov ah, 52h
int21h ; ES:BX -- DOS table as described below
push es ; DPB chains
push bx
lds si, es:[bx]
push cs
pop es
mov ax, si
stosw
mov ax, ds
stosw
mov bx, cs:cvtOfs
xor cx, cx
@@1: mov al, ds:[si+1]
stosb
mov ax, ds:[si+bx+12h]
stosw
mov ax, ds:[si+bx+14h]
stosw
inc cx
lds si, ds:[si+bx+18h]
cmp si, -1
jnz @@1
; mov ax, 5
; mul cl
; add ax, 4
; add cs:tsrLength, ax
pop bx
pop es
push es ; DCB file control blocks
push bx
les bx, es:[bx+4]
@@11: cmp word ptr es:[bx], -1
jz @@10
les bx, es:[bx]
jmp @@11
@@10:
mov ax, es
xchg ax, bx
push cs
pop es
stosw
xchg ax, bx
stosw
pop bx
pop es
; add cs:tsrLength, 4
push es ; Device Driver Chains
pop ds
add bx, 22h
mov si, bx ; NUL
pop es
mov ax, si
stosw
mov ax, ds
stosw
xor cx, cx
xor bx, bx
@@9: push si
mov cl, 5
rep movsw
inc bx
pop si
lds si, ds:[si]
mov ax, si
inc ax
jnz @@9
pop ds
pop cx
pop bx
pop ax
ret
BackupBiosData:
mov ax, '--'
stosw
push ds
push si
mov si, 40h
mov ds, si
mov si, 10h
movsw
mov si, 0a8h
movsw
movsw
mov si, 49h
mov cx, 1dh
rep movsb
mov si, 0f0h
mov cx, 8
rep movsw
pop si
pop ds
ret
BackupMemoryManager:
push cs
pop es
push ds
push es
call SaveXMSstatus
call SaveEMSstatus
pop es
pop ds
ret
SaveEMSstatus:
test cs:status, EMSbit
jnz @@1
ret
@@1:
mov ax, 'ME'
stosw
inc di
inc di
push di
mov ah, 4dh
int67h
pop di
mov es:[di-2], bx
shl bx, 1
shl bx, 1
add di, bx
ret
SaveXMSstatus:
call XMS_test
test cs:status, XMSbit
jnz @@1
ret
@@1:
mov ax, 'MX'
stosw
mov dx, 1
call XMS_alloc
jnz @@_1
xor cx, cx ; XMS alloc failure
stosw
ret
@@_1:
push dx
sub dx, MaxHandles 10
@@2:
push dx
call XMS_Lock
pop dx
jnz @@3 cmp bl, 0a2h
jnz @@4
add dx, 10
jmp @@2
@@3: push dx
call XMS_unlock
pop dx
@@4:
mov cs:handle_begin, dx
pop dx
push dx
call XMS_bstat
xor cx, cx
mov cl, bl
inc cx
pop dx
call XMS_Free
mov dx, cs:Handle_begin
push cx
push cs
pop es
mov ax, cx
stosw
@@5: push dx
call XMS_Lock
pop dx
jnz @@6 cmp bl, 0a2h ; Handle invalid
jz @@7
@@6: call XMS_unlock
add dx, 10
jmp @@5
@@7: mov ax, dx
stosw
add dx, 10
loop @@5
pop cx
ret
XMS_test:
push es
mov ax, 4300h
int2fh
cmp al, 80h
jnz @@9
mov ax, 4310h
int2fh
mov cs:XMS_control, bx
mov cs:XMS_control[2], es
or cs:Status, XMSbit
@@9:
pop es
ret
XMS_stat:
mov ah, 0
mov hma_exist, dl
ret
hma_exist db 0
XMS_alloc:
mov ah, 9
or ax, ax
ret
XMS_lock:
mov ah, 0ch
or ax, ax
ret
XMS_unlock:
mov ah, 0dh
or ax, ax
ret
XMS_bstat:
mov ah, 0eh
or ax, ax
ret
XMS_free:
mov ah, 0ah
or ax, ax
ret
EMS_test:
push cs
pop ds
mov dx, offset EMMname
mov ax, 3d00h
int21h
jc @@2
mov bx, ax
mov ah, 3eh
int21h
or cs:Status, EMSbit
@@2:
ret
EMMname db 'EMMXXXX0',0
SetHotKey:
xor bx, bx
lodsb
push ax
@@1: lodsb
cmp al, 0dh
jz @@9 cmp al, 'C'
jnz @@2
or bl, LeftCtrl
jmp @@1
@@2:
cmp al, 'c'
jnz @@3
or bl, RightCtrl
jmp @@1
@@3:
cmp al, 'A'
jnz @@4
or bl, LeftAlt
jmp @@1
@@4:
cmp al, 'a'
jnz @@5
or bl, RightAlt
jmp @@1
@@5:
cmp al, 'S'
jnz @@6
or bl, LeftShift
jmp @@1
@@6:
cmp al, 's'
jnz @@7
or bl, RightShift
jmp @@1
@@7: pop ax
jmp @Err
@@9:
mov cs:HotKey, bl
pop ax
mov cs:AuxHotKey, 2dh ; 'X' scan key
cmp al, '1'
jz @@29
mov cs:AuxHotKey, 0
@@29:
cmp cs:Self, 0
jz @@30
push es
mov es, cs:Self
mov es:HotKey, bl
mov bl, cs:AuxHotKey
mov es:AuxHotKey, bl
pop es
@@30:
call GetRunFileName
mov ax, 3d02h
int21h
jc @@10
push cs
pop ds
mov bx, ax
mov cx, 4
mov dx, 100h
mov ah, 40h
int21h
jc @@10
mov ax, 4200h
xor cx, cx
mov dx, 17h
int21h
jc @@10
mov cx, 1
mov dx, offset AuxHotKey
mov ah, 40h
int21h
jc @@10
mov ah, 3eh
int21h
@@10:
ret
GetRunFileName:
; Return:
; DS:DX Pointer ofthisrun file name ASCIIZstring
push ax
push bx
push cx
push si
push di
push es
push cs
pop es
mov ax, es:[2ch]
mov es, ax
xor di, di
mov cx, 1000h
xor al, al
@@1: repnz scasb
cmp es:[di], al
loopnz @@1
mov dx, di
add dx, 3
push es
pop ds
pop es
pop di
pop si
pop cx
pop bx
pop ax
ret
GetMachineID:
push es
mov KBD102,True
mov ax,40h
mov es,ax
test byte ptr es:[96h], 00010000b
jnz @@1
mov Kbd102,False
@@1:
xor ax,ax
dec ax
mov es,ax
mov al,es:[0eh]
mov cs:MachineID, al
pop es
ret
ModifyHotKeyPrompt:
cmp cs:Kbd102, True
jz @@9
push cs
pop es
push cs
pop ds
mov cx, 124
mov si, offset KMsg2
mov di, offset KMsg1
rep movsb
@@9: cmp cs:MachineID, 0fch
jna @@10
mov cs:clsStrcolor, 70h ; Mono
mov cs:clsStr, 70h
@@10:
ret
PrintHotKeyPrompt:
Print Msg1
mov al, cs:HotKey
mov ah, al
shr al, 1
shr al, 1
and ax, 33ch
or al, ah
mov dx, offset KeyMsg
@@40:
or ax, ax ; Mr. Lei 4/25/1993
jz @@_42
shr al, 1
push ax
jnc @@41
push ax
call ColorDisplayStr
; mov ah, 9
;int21h
pop ax
or al, al
jz @@42
push dx
mov dx, offset PlusMsg
; Print PlusMsg
pop dx
@@41: add dx, 12
pop ax
jmp @@40
@@42: pop ax
@@_42: cmp cs:AuxHotKey, 0
jz @@43 cmp cs:HotKey, 0 ; Mr. Lei
jz @@_43
; Print PlusMsg
@@_43: mov dx, offset AuxHotKeyName
; Print AuxHotKeyName
@@43:
Print crlf
ret
ColorDisplayStr:
push bx
push cx
push dx
push si
mov bl, 0fh
mov si, dx
xor bh, bh
mov cx, 1
@@1: lodsb
cmp al, '
jz @@2
or al, al
jz @@2
push cx
mov ah, 09h
int10h
mov ah, 3int10h
inc dl
mov ah, 2int10h
pop cx
jmpshort@@1
@@2:
pop si
pop dx
pop cx
pop bx
ret
CmpSideKick:
xor ax, ax
mov es, ax
les bx, es:[20h]
cmp word ptr es:[bx-4], 4b53h
jnz @@1 cmp word ptr es:[bx-2], 4942h
jz @@2
@@1: mov es, ax
les bx, es:[94h]
cmp word ptr es:[bx-2], 4b53h
jz @@2
ret
@@2: or cs:Status, SKbit
ret
CmpDosVer: mov ah, 30h
int21h
cmp al, 3
jb @@1 cmp al, 3
jna @@2
mov cs:cvtOfs, 1
ret
@@2: mov cs:cvtOfs, 0
ret
@@1: Print DosVerErr
mov ax, 4cffh
int21h
DosVerErr db 'Sorry, DOS version too lower !',0dh,0ah,'
HotKeyValid:
cmp cs:HotKey, 0
jnz @@_1
cmp cs:AuxHotKey, 0
jnz @@_1
Print HotKeyErr
mov ax, 4cfeh
int21h
@@_1: ret
HotKeyErr db 'Sorry, please setup hotkey again. ',0dh,0ah,'
eof:
ends
end Start
; ------------- The End !---------------------------------------------------
复制代码
