光耦,场效应MOS管,IGBT管,二三极管现货型号,欢迎咨询。
最新到货光耦现货型号:
TLP521-4(GB,F) TLP525G-2(F) 6N139(F)
TLP250(F) TLP521-2(GR,F) TLP521-1(GB,F)
TLP521-1(GR,F) TLP109(TPL,E(T TLP627-2(F)
TLP627(F) TLP627 TLP350(F)
TLP350(TP1,F) TLP350(TP5,F) TLP176G(TP.F)
TLP185(GB-TPL,E(T TLP185(GB-TPL,SE(0 TLP185(GB-TPL,SE
TLP185(GB-TPL,SE(T TLP185(GR-TPL,E(T TLP185(GR-TPL,SE(T
TLP185(GR-TPL,SE(0 TLP184(GB-TPL,SE(T TLP185(GB-TPL,E(0
TLP559(F) TLP126(TPL,F) TLP127(TPL,U,F)
TLP127 TLP560J(C,F) TLP180(GB-TPL.F)
PC817X4NSZW PC817X3NSZW PC817X2NSZW
TLP781(GB-TP6,F) TLP781(GB,F) TL181
TLP785(GB-TP6,F) HCPL2731 TLP181(GB-TPL,F)
TLP759(TP1.J.F) TLP2362(TPL,E(T TLP2301(TPL,E(T
TLP291(GB-TP,SE(T TLP291(GB-TP,SE(0 TLP291(GR-TP,E(T
TK10A80E,S4X(S TLP719(TP,F) TLP715(TP,F)
6N137SDM 2SK4013 TLP701(TP,F)
TLP759(IGM-TP1,J,F TLP227GA-2(TP1,F) TLP351(F)
TLP155E(TPL,E(T TLP291-4(GB-TP,E(T PC357N1J000F
PC817X3NIP0F TLP781(D4-BL,F) TLP184(GB-TPL,SE)
最新现货场效应MOS管,IGBT管:
2SK4108 2SK3878 IRFP250NPBF
SPP20N60C3XKSA1 IRFP460PBF VS-40TPS12APBF
IRF7314TRPBF IRF640NPBF IRFZ44NSTRLPBF
MDP13N50(TH) MDF18N50(TH) IKW50N60T。
IKW30N60T、 FMH23N50E FDA50N50
IKW50N60H3, IKW30N60H3, IKW30N60H3FKSA1
IRF1407PBF IRF9540PBF TK8A65D(STA4,X,M)
SPA11N80C3 IRFP4768PBF TK13A65U(STA4.X.M)
TK13A65U MDF4N60TH IRF9Z24NPBF
IRFZ24NPBF IKW75N60T MDF11N60TH
ITW25N50A ITW20N50A FGH60N60SMD
FGH40N60SFDTU FGH40N60SMD FGH60N60SFDTU
FGH40N60UFDTU FGA6560WDF FGA60N65SMD
IRFR3910TRPBF IRF9540NSTRLPBF IRF1404ZSTRLPBF
IRFB3607PBF IR2103STRPBF SPW47N60C3XKSA
SPW47N60C3 FSW25N50A FQP4N90C
FQA9N90C FQA11N90C SSM3J56MFV,L3F(T
SSM3K37MFV,L3F(T SSM3K37MFV,L3F(A SSM3K37MFV,L4F(A
FGL60N100BNTDTU FGL40N120ANDTU IRFU9024NPBF
ULN2803AFWG IRFB3206PBF IRFP4468PBF
IRFB20N50KPBF IRFB42N20DPBF SPP21N50C3
FDA59N25 FQA28N50 IRGIB10B60KD1P
MDF11N60TH TK80E07NE FCH104N60F
IRF530PBF IRF7103TRPBF IRF7036TRPBF
IRF840STRLPBF IRFP460APBF IRF7416TRPBF
IR2520DSTRPBF IRLR7843TRPBF IRFR540ZTRPBF
IRG4PC50UDPBF IHW15N120R3 IHW20N120R3
IHW30N160R2 IRFR6215TRPBF IRFR220NTRPBF
IRFR120NTRPBF 2SK3476(TE12L,Q) IPP030N10N3G
IPB042N10N3G FDD8424H SSM3K324R,LF(T
SSM3K324R,LF(T SSM3J331R,LF(T SSM3J331R,LF(A
STP28NM50N SGH40N60UFDTU IRFR5505TRPBF
IRFB4115PBF IRF7342TRPBF IRG4PH40UD2-EP
SPW35N60C3 IRF9640PBF IRFP4227PBF
IRFB4332PBF NGTB45N60S1WG NGTB75N60FL2WG
IRFP350PBF IRLML6244TRPBF IRLML6402TRPBF
NGTB50N65S1WG IRFU320PBF IRFB4127PBF
IRFB4227PBF IRF2907STRLPBF IRFD9120PBF
IRFP1405PBF IRFB4019PBF IRLR8259TRPBF
IRFP140NPBF IRFS3607TRLPBF IRF9310PBF
IRF9310PBF IRFB260NPBF IRLR8743TRPBF
SIHP18N50C-E3 FDPF20N50FT IRF7343TRPBF
IRFPE50PBF IRFPS40N50LPBF IRFBE30PBF
IRFP4868PBF TK10A60D(STA4,X,M) SSM3K35MFV,L3F(T
IKA15N60T STP100N8F6 SSM3J328R,LF(T
TK6A60D(STA4,X,M) IKD06N60RF SSM3K56MFV,L3F
SSM3K56MFV,L3F(T SSM3K333R IXFN132N50P3
IRFR310TRPBF IPP075N15N3G IXFB60N80P
TXFN150N65X2 CC2541F256RHAR MJD122T4G
STP33N60M2 IRF4905PBF IRFP360PBF
最新到货二三极管现货型号:
VS-HPA50PA60CPBF VS-42CTQ030PBF VS-50WQ10PNTRPBF
VS-HFA08SD60STRPBF VS-12CWQ10FNTRPBF VS-12CWQ10FNTR-M3
VS-32CTQ030STRLPBF VS-12CWQ06FNTRPBF VS-50WQ03FNTRPBF
VS-HFA50PA60CPBF MUR460RLG BAT41-600B
MBRF2060CT MUR1660CTG BYV26E
RHRP1560 VS-30CTQ060PBF VS-60CPQ150PBF
MBR10150CT RHRG30120 APT30D60BCTG
SB360A SB360 SB360A
B5817W VS-30CPQ150PBF VS-MBR6045WTPBF
VS-12CWQ04FNTRPBF VS-MUR3020WTPBF LL4148CNC
LL4148 1N4148W BZT52C15
1N4148 1N4148WS MM1Z20
SS16 JDP2S12CR(TE85L,QM 1SV307(TPH3,F)
DF10G7M1N,LF(D VS-HFA08TB60PBF SS12
SS510 VS-6CWQ10FNTRPBF VS-6CWQ10FNTRPBF-M3
RHRG75120 RClamp0542T,TCT VS-12CWQ04FNTR-M
VS-12CWQ06FNTR-M3 VS-40TPS12AP-S1 VS-50WQ03FNTR-M3
VS-30ETH06PBF 1SV308,L3F(T TDP2S12CR(TE85L,QM
1SV325(TPH3,F) VS-63CPQ100PBF HFA15TB60PBF
ES1D-E3/61T NUP2105LT1G RHRP860-F102
RHRP3060 1SV305(TPH3,F) CMF03(TE12L,Q,M)
TCR2EF33,LM(CT MUR1560G VS-63CTQ100PBF
B5819W BAV21W IRFP260NPBF
IRFR3710ZTRPBF IRF5210STRLPBF IRF2807STRLPBF
IRF2807PBF VS-30CTQ045STRLPBF IRLR024NTRPBF
2SC4140 IRFP150NPBF IRFP450PBF
IRFP9240PBF IRFI4212H-117P TIP127
TIP122 IRFPS43N50KPBF IRF640NPBF
IRFZ44NPBF IRFD120PBF IRF840PBF
IRF840APBF IRF7351TRPBF IRF530NPBF
IRF9530NPBF IRF9Z34NPBF IRF9630PBF
IRFR9024NTRPBF IRFR210TRPBF IRF540NPBF
IRF7309TRPBF IRFZ34NPBF IRF740PBF
IRF510PBF IRF1404PBF IRF9640STRLPBF
IRFP054NPBF IRF3205PBF IRFP2907PBF
IRF520PBF IRF9540NPBF TK13A60D(STA4.X.M)
2SA1837(F,M) 2SC4793(F,M) 2SA1020-Y(TE6,F,M
2SC2655-Y(TE6,F,M IRFB23N20DPBF IRF9610PBF
IRFP4242PBF 2SA1015-GR(SP,F,T) IRFP064NPBF
IRFP240PBF IRF240NPBF IRFB3207PBF
78M05 IRFB4020PBF IRLZ44NPBF
IRLZ34NPBF IRFR110TRPBF IRLL110TRPBF
IRF4905STRLPBF IRF3710PBF IRFP264PBF
IRFBG20PBF IRFPG50PBF IRFPG30PBF
SIHG20N50C-E3 IRF3415PBF 2SC2625-34SC
MBR1060AC SS8550 IRF3808PBF
IRGP35B60PDPBF IRG4PH50SPBF SPW20N60C3
IRFB31N20DPBF IRGP20B60PDPBF IRF1405PBF
IRF5305PBF IRF530NSTRLPBF IRFR5305TRPBF
IRFU3910PBF IRFU5410PBF IRFZ46NPBF
IRL2203NPBF IRL3713PBF IRGP4063DPBF
IRLR3410TRPBF IRLZ24NPBF IRFR6215TRLPBF
IRLR2905TRPBF IRFB4110PBF 2SA1213-Y(TE12L,ZC
2SC2873-Y(TE12L,ZC 2SK2962(TE6,F,M) IRFR5410TRPBF
IRLR2703TRPBF IRFR9014TRPBF IRLR8726TRPBF
IRF7853TRPBF IRF9530NSTRLPBF IRFR9120NTRPBF
IRFU024NPBF IRFB4321PBF IRF7406TRPBF
IRFB52N15DPBF IRG4BC30UDPBF IRFP4368PBF
SD101CWS IRFP4568PBF IRFBC30PBF
IRFP9140NPBF IRLL2703TRPBF IRGP4062DPBF
IRF3205STRLPBF IRFP4110PBF IRFB3077PBF
2SC4672 B772 CJ431
CJ78L05 D882 S8050
S8550 SS8050 SS8550
MMBTA05 MMBT8050 MMBT8550
MMBR2907ALT1G BZT52C33-7-F 2SK208-GR(TE85L,F)
2SC5066-Y,LF(T TTA1943(Q) 2SA1736(TE12L,ZC)
2SC5200-0(Q) 2SA1943-0(Q ) 1SV307(TPH3,F)
IRF7380TRPBF IRF7452TRPBF IRFB4310ZPBF
IRLR3110ZTRPBF IRL7313PBF IRLU024NPBF
IRFRC20TRPBF IRFB4229PBF IRFP4332PBF
IRFP4229PBF AO3401A 2SC3326-B,LF(T
2SC3326-A,LF(T 2SC3324-GR(TE85L,F) 2SC1312-GR(TE85L,F)
FQD18N20V2TM MMBT3904LT1G 2SA1312-GR(TE85L,F
CJ78L15 2SA1013
因为产品库存数量变动较大,请客户下单前提前确认数量。
深力科电子,专营牌系列产品,型号繁多,未能列全
有需要找我!!!
