SmartZap:
The SmartZap is a fully automated ESD gun tester with automatic failure detection capability, providing far superior performance than manual zap gun test. It is complying IEC61000-4-2 test standard.
Advantage of SmartZap, fully automated ESD Gun Tester
SmartZap Main Features: Standard Features:
- Support of any ESD gun model
- Five sides zap (top and four sides)
- Automated failure detection
- Pick and placing
- Gun tip change (contact ←→ air)
- Connector plug/unplug
- DUT flipping
Standard Features:
- Customizable report generation
- Test point definition by graphic interface
- Test point definition by DUT CAD model
- Automatic DUT offset correction
- Key press and touch screen fingers
- Discharge brush
- IEC 61000 – 4 – 2 compliant zap table
- Pin test
Zap point definition: - Zap point are defined either over pictures taken by five cameras or DUT CAD model
Failure detection: - FD module includes monitoring of four analog and four digital signals, input from photo sensors and 1KHz sound, communication with a call box, a relay and a 120V/5Amp power supply for DUT power cycle.
- Boolean operation of monitoring signals to sort out failure type.
- Macro function for step by step control of failure detection and power cycle procedures.
Automated features: –All automated functions done by pneumatic without additional electrically powered accessories.
- DUT pick-and-placing
- Gun tip change
- DUT flipping
- DUT offset correction: automatic adjustment of defined test points when the DUT is placed slight off from the original position.
Report generation: - User can customize report templates
Welcome to communicate with me , billion.xiao@outlook.com 18573116298
- Pick and placing
- DUT flipping
Standard Features:
- Discharge brush
- Pin test
- Gun tip change
- DUT flipping
