二哲科技 发表于 2020-10-2 15:30
因为不能用加法呗
就像C语言指针里面有些可以用加法和减法,不能用乘除法;
就类似于2的3次方+3的3次方不能 ...
卢杰 发表于 2020-10-21 14:49
100mW + 3dBm = 20dBm + 3dBm = 23dBm
100mW + 3dBm = 100* 2mW = 200mW
10*lg200mW 等于 23dBm
hxm3000_852564689 发表于 2020-10-12 21:08
100mW + 3dBm = 100mW + 2mW = 102mW
计算有错,不能 mW这样加,10提出来用对数括号加。
10 * ...
dBm为对数运算,可以直接相加,23dBm,其实对应200mW;这个计算是正 ...
1个基准:
2个原则:
1)+3dB,功率乘以2;-3dB,功率除以2
2)+10dB,功率乘以10;-10dB,功率除以10
几乎所有整数的dBm都可用以上的“1个基准”和“2个原则”转换为W。
例1:100mW + 3dB = ?W
100mW + 3dB = 100×2 = 200(mW)
例2:100mW + 10dB = ?W
100mW + 10dB = 100 × 10 = 1000(mW)
例3:100mW + 7dB = ?W
100mW + 7dB = 100mW + (10dB - 3dB)
=100 × 10 ÷ 2
= 500(mW)
例5:44dBm= ? W
44dBm = 30dBm + 10dB + 10dB-3dB-3dB
=1W×10×10÷ 2 ÷ 2
= 25W
例2:32dBm= ? W
32dBm = 30dBm + 3dB + 3dB + 3dB + 3dB-10dB
= 1W×2×2×2×2÷10
= 1.6W
+1dB和+2dB的计算技巧
+1dB = +10dB-3dB-3dB-3dB
= X×10×1/2×1/2×1/2
= X×1.25
+2dB = -10dB+3dB+3dB+3dB+3dB
= X×0.1×2×2×2×2
= X×1.6
在计算中,有时候也可以根据上面的规律变换为-1dB和-2dB,达到快速口算的目的,即:
-1dB = -10dB+3dB+3dB+3dB
= X×0.1×2×2×2
= X×0.8
-2dB = -3dB+1dB
= X×1/2×1.25
= X×0.625
例1:
51dBm = 30dBm+10dB+10dB+1dB
= 1W×10×10×1.25
= 125W
例2:
38dBm = 30dBm + 10dB-2dB
= 1W×10×0.625
= 6.25W
