/*============================================================================* * LOGIC CORE: I2C协议基本数据数据字节传输模块 * MODULE NAME: i2c_bit_shift() * COMPANY: 武汉芯路恒科技有限公司 * http://xiaomeige.taobao.com * author: 小梅哥 * Website: www.corecourse.cn * REVISION HISTORY: * * Revision: 1.0 04/10/2019 * Description: Initial Release. * * FUNCTIONAL DESCRIPTION: ===========================================================================*/ module i2c_bit_shift( Clk, Rst_n, Cmd, Go, Rx_DATA, Tx_DATA, Trans_Done, ack_o, i2c_sclk, i2c_sdat ); input Clk; input Rst_n; input [5:0]Cmd; input Go; output reg[7:0]Rx_DATA; input [7:0]Tx_DATA; output reg Trans_Done; output reg ack_o; output reg i2c_sclk; inout i2c_sdat; reg i2c_sdat_o; //系统时钟采用50MHz parameter SYS_CLOCK = 50_000_000; //SCL总线时钟采用400kHz parameter SCL_CLOCK = 400_000; //产生时钟SCL计数器最大值 localparam SCL_CNT_M = SYS_CLOCK/SCL_CLOCK/4 - 1; reg i2c_sdat_oe; localparam WR = 6'b000001, //写请求 STA = 6'b000010, //起始位请求 RD = 6'b000100, //读请求 STO = 6'b001000, //停止位请求 ACK = 6'b010000, //应答位请求 NACK = 6'b100000; //无应答请求 reg [19:0]div_cnt; reg en_div_cnt; always@(posedge Clk or negedge Rst_n) if(!Rst_n) div_cnt <= 20'd0; else if(en_div_cnt)begin if(div_cnt < SCL_CNT_M) div_cnt <= div_cnt + 1'b1; else div_cnt <= 0; end else div_cnt <= 0; wire sclk_plus = div_cnt == SCL_CNT_M; assign i2c_sdat = i2c_sdat_oe?i2c_sdat_o:1'bz; reg [7:0]state; localparam IDLE = 8'b00000001, GEN_STA = 8'b00000010, WR_DATA = 8'b00000100, RD_DATA = 8'b00001000, CHECK_ACK = 8'b00010000, GEN_ACK = 8'b00100000, GEN_STO = 8'b01000000; reg [4:0]cnt; always@(posedge Clk or negedge Rst_n) if(!Rst_n)begin Rx_DATA <= 0; i2c_sdat_oe <= 1'd0; en_div_cnt <= 1'b0; i2c_sdat_o <= 1'd1; Trans_Done <= 1'b0; ack_o <= 0; state <= IDLE; cnt <= 0; end else begin case(state) IDLE: begin Trans_Done <= 1'b0; i2c_sdat_oe <= 1'd1; if(Go)begin en_div_cnt <= 1'b1; if(Cmd & STA) state <= GEN_STA; else if(Cmd & WR) state <= WR_DATA; else if(Cmd & RD) state <= RD_DATA; else state <= IDLE; end else begin en_div_cnt <= 1'b0; state <= IDLE; end end GEN_STA: begin if(sclk_plus)begin if(cnt == 3) cnt <= 0; else cnt <= cnt + 1'b1; case(cnt) 0:begin i2c_sdat_o <= 1; i2c_sdat_oe <= 1'd1;end 1:begin i2c_sclk <= 1;end 2:begin i2c_sdat_o <= 0; i2c_sclk <= 1;end 3:begin i2c_sclk <= 0;end default:begin i2c_sdat_o <= 1; i2c_sclk <= 1;end endcase if(cnt == 3)begin if(Cmd & WR) state <= WR_DATA; else if(Cmd & RD) state <= RD_DATA; end end end WR_DATA: begin if(sclk_plus)begin if(cnt == 31) cnt <= 0; else cnt <= cnt + 1'b1; case(cnt) 0,4,8,12,16,20,24,28:begin i2c_sdat_o <= Tx_DATA[7-cnt[4:2]]; i2c_sdat_oe <= 1'd1;end //set data; 1,5,9,13,17,21,25,29:begin i2c_sclk <= 1;end //sclk posedge 2,6,10,14,18,22,26,30:begin i2c_sclk <= 1;end //sclk keep high 3,7,11,15,19,23,27,31:begin i2c_sclk <= 0;end //sclk negedge /* 0 :begin i2c_sdat_o <= Tx_DATA[7];end 1 :begin i2c_sclk <= 1;end //sclk posedge 2 :begin i2c_sclk <= 1;end //sclk keep high 3 :begin i2c_sclk <= 0;end //sclk negedge 4 :begin i2c_sdat_o <= Tx_DATA[6];end 5 :begin i2c_sclk <= 1;end //sclk posedge 6 :begin i2c_sclk <= 1;end //sclk keep high 7 :begin i2c_sclk <= 0;end //sclk negedge 8 :begin i2c_sdat_o <= Tx_DATA[5];end 9 :begin i2c_sclk <= 1;end //sclk posedge 10:begin i2c_sclk <= 1;end //sclk keep high 11:begin i2c_sclk <= 0;end //sclk negedge 12:begin i2c_sdat_o <= Tx_DATA[4];end 13:begin i2c_sclk <= 1;end //sclk posedge 14:begin i2c_sclk <= 1;end //sclk keep high 15:begin i2c_sclk <= 0;end //sclk negedge 16:begin i2c_sdat_o <= Tx_DATA[3];end 17:begin i2c_sclk <= 1;end //sclk posedge 18:begin i2c_sclk <= 1;end //sclk keep high 19:begin i2c_sclk <= 0;end //sclk negedge 20:begin i2c_sdat_o <= Tx_DATA[2];end 21:begin i2c_sclk <= 1;end //sclk posedge 22:begin i2c_sclk <= 1;end //sclk keep high 23:begin i2c_sclk <= 0;end //sclk negedge 24:begin i2c_sdat_o <= Tx_DATA[1];end 25:begin i2c_sclk <= 1;end //sclk posedge 26:begin i2c_sclk <= 1;end //sclk keep high 27:begin i2c_sclk <= 0;end //sclk negedge 28:begin i2c_sdat_o <= Tx_DATA[0];end 29:begin i2c_sclk <= 1;end //sclk posedge 30:begin i2c_sclk <= 1;end //sclk keep high 31:begin i2c_sclk <= 0;end //sclk negedge */ default:begin i2c_sdat_o <= 1; i2c_sclk <= 1;end endcase if(cnt == 31)begin state <= CHECK_ACK; end end end RD_DATA: begin if(sclk_plus)begin if(cnt == 31) cnt <= 0; else cnt <= cnt + 1'b1; case(cnt) 0,4,8,12,16,20,24,28:begin i2c_sdat_oe <= 1'd0; i2c_sclk <= 0;end //set data; 1,5,9,13,17,21,25,29:begin i2c_sclk <= 1;end //sclk posedge 2,6,10,14,18,22,26,30:begin i2c_sclk <= 1; Rx_DATA <= {Rx_DATA[6:0],i2c_sdat};end //sclk keep high 3,7,11,15,19,23,27,31:begin i2c_sclk <= 0;end //sclk negedge default:begin i2c_sdat_o <= 1; i2c_sclk <= 1;end endcase if(cnt == 31)begin state <= GEN_ACK; end end end CHECK_ACK: begin if(sclk_plus)begin if(cnt == 3) cnt <= 0; else cnt <= cnt + 1'b1; case(cnt) 0:begin i2c_sdat_oe <= 1'd0; i2c_sclk <= 0;end 1:begin i2c_sclk <= 1;end 2:begin ack_o <= i2c_sdat; i2c_sclk <= 1;end 3:begin i2c_sclk <= 0;end default:begin i2c_sdat_o <= 1; i2c_sclk <= 1;end endcase if(cnt == 3)begin if(Cmd & STO) state <= GEN_STO; else begin state <= IDLE; Trans_Done <= 1'b1; end end end end GEN_ACK: begin if(sclk_plus)begin if(cnt == 3) cnt <= 0; else cnt <= cnt + 1'b1; case(cnt) 0:begin i2c_sdat_oe <= 1'd1; i2c_sclk <= 0; if(Cmd & ACK) i2c_sdat_o <= 1'b0; else if(Cmd & NACK) i2c_sdat_o <= 1'b1; end 1:begin i2c_sclk <= 1;end 2:begin i2c_sclk <= 1;end 3:begin i2c_sclk <= 0;end default:begin i2c_sdat_o <= 1; i2c_sclk <= 1;end endcase if(cnt == 3)begin if(Cmd & STO) state <= GEN_STO; else begin state <= IDLE; Trans_Done <= 1'b1; end end end end GEN_STO: begin if(sclk_plus)begin if(cnt == 3) cnt <= 0; else cnt <= cnt + 1'b1; case(cnt) 0:begin i2c_sdat_o <= 0; i2c_sdat_oe <= 1'd1;end 1:begin i2c_sclk <= 1;end 2:begin i2c_sdat_o <= 1; i2c_sclk <= 1;end 3:begin i2c_sclk <= 1;end default:begin i2c_sdat_o <= 1; i2c_sclk <= 1;end endcase if(cnt == 3)begin Trans_Done <= 1'b1; state <= IDLE; end end end default:state <= IDLE; endcase end endmodule
复制代码
