二,nPM1300 EK 概述
用户可通过nPM1300评估套件对nPM1300电源管理IC(PMIC)进行简便的评测和配置。通过连接到nRF Connect for Desktop中的nPM PowerUP应用程序,可以运用直观的图像用户界面(GUI)轻松配置nPM1300的全部设置,并将其作为代码导出,在MCU应用中运行。
- 通过nPM PowerUP桌面应用程序实现无缝集成和配置
- 通过公头引脚访问所有的nPM1300 PMIC连接,轻易连接Nordic开发套件(DK)和外部测试设备
- 使用集成的LED和按钮,可对PMIC的内置LED驱动器和GPIO进行评测
nPM1300评估套件自带JST电池连接器,用于带有或不带内部NTC的电池,以及用于访问全部nPM1300连接的公头引脚。此外,该套件还带有3个LED和4个按钮,简化了PMIC的GPIO和LED驱动功能的评估工作。
要初步评估nPM1300内的电量测量能力,用户可以使用nPM PowerUP中已经包含的预配置电池模型之一。电量计量表解决方案配合电池模型,可准确测量设备充电状态。分析电池并生成电池模型是一次性的工作,你需要一些额外的硬件。
nPM1300旨在为Nordic的nRF52®和nRF53®系列,以及nRF54H20先进无线多协议系统级芯片(SoC)提供高效的电源调节功能。这款PMIC还适用于基于蜂窝物联网nRF91系列系统级封装(SiP)的应用的电池充电,方法是使用PMIC的非稳压输出为SiP的内部降压稳压器供电。
三,下载工具
https://www.nordicsemi.com/Products/Development-tools/nrf-connect-for-desktop/download#infotabs
三,Set up the nPM1300 Evaluation Kit (EK) to start using the nPM PowerUP app.
- To power the nPM1300 Power Management Integrated Circuit (PMIC), connect a USB-C cable with 1.5 A current capability to USB PMIC on J3.
- Insert the battery ensuring the correct polarity as shown on the EK. Depending on your battery, use one of the following alternatives:
- For a battery with an integrated Negative Temperature Coefficient (NTC) thermistor, use the battery connector on J2.
- For a battery without an integrated NTC thermistor, use the battery connector on J1. Connect a jumper between NTC (pin 2) and 10 kΩ (pin 3) on pin header P3 to use the integrated 10 kΩ resistor.
- Download and install nRF Connect for Desktop.
- Open nRF Connect for Desktop and install the nPM PowerUP app.
- Open nPM PowerUP.
- Click Select Device on the left-side panel.
- Select the nPM1300 Evaluation Kit.
- Set the termination voltage and current limit in the Charger panel on the DASHBOARD.
You can now see status of your battery and use the built-in battery models in nPM PowerUP. - Use a USB-C cable with USB 2.0 High Speed compatibility to connect from your computer to nPM CONTROLLER on J4.
Use a ferrite bead around the USB cable to reduce electromagnetic interference.
A green LED light (LD4) indicates a successful connection with the nPM Controller.
