1. 编写lvgl界面代码
#include "yang.h"
#include "lvgl.h"
#include "stdlib.h"
#define card_img_type_count 15
#define left_count 20
#define right_count 20
#define mid_count 100
#define bottom_count 8
#define max_layer 4
#define layer_row_count 8
#define layer_col_count 6
#define mid_x_start 230
#define mid_y_start 20
#define card_width 40
#define card_height 50
#define left_x_start 190
#define right_x_start 570
#define left_y_start 150
#define right_y_start 150
#define left_y_distance 5
#define right_y_distance 5
#define bottom_start_x 256
#define bottom_start_y 395
LV_IMG_DECLARE(grass2_img)
LV_IMG_DECLARE(grass1_img)
LV_IMG_DECLARE(yang_start_btn_img)
LV_IMG_DECLARE(bottom_dock_img)
LV_IMG_DECLARE(yang_card1_img)
LV_IMG_DECLARE(yang_card2_img)
LV_IMG_DECLARE(yang_card3_img)
LV_IMG_DECLARE(yang_card4_img)
LV_IMG_DECLARE(yang_card5_img)
LV_IMG_DECLARE(yang_card6_img)
LV_IMG_DECLARE(yang_card9_img)
LV_IMG_DECLARE(yang_card7_img)
LV_IMG_DECLARE(yang_card8_img)
LV_IMG_DECLARE(yang_card10_img)
LV_IMG_DECLARE(yang_card11_img)
LV_IMG_DECLARE(yang_card12_img)
LV_IMG_DECLARE(yang_card13_img)
LV_IMG_DECLARE(yang_card14_img)
LV_IMG_DECLARE(yang_card15_img)
typedef enum
left =0,
mid,
right,
bottom,
}area_enum;
typedef struct
lv_obj_t * obj;
bool alive;
char x;
char y;
area_enum area;
char layer;
char img_index;
}card_typedef;
card_typedef left_card[left_count]={0,};
card_typedef right_card[right_count]={0,};
card_typedef mid_card[max_layer*layer_col_count*layer_row_count]={0,};
card_typedef bottom_card[bottom_count]={0,};
static const lv_img_dsc_t * card_img[card_img_type_count] = { &yang_card1_img ,&yang_card2_img ,&yang_card3_img,&yang_card4_img,&yang_card5_img,
&yang_card6_img,&yang_card7_img,&yang_card8_img,&yang_card9_img,&yang_card10_img,&yang_card11_img,&yang_card12_img,&yang_card13_img,&yang_card14_img,&yang_card15_img,};
static const lv_img_dsc_t * grass_img[2] = { &grass1_img,&grass2_img,};
lv_obj_t * screen,* map1,* start_btn,*dock;
static void game_start(lv_event_t * e);
static void cover_test();
static void clicked_cb(lv_event_t * e);
static void left_cover_test();
static void right_cover_test();
static void move_to_right(char index);
static char find_same_card(char img_index);
static void del_same_card();
static void x_move_cb(void * var, int32_t v);
static void y_move_cb(void * var, int32_t v);
static void move_to_left();
static void move_done_cb(lv_anim_t * a);
static void game_over();
static void card_anim_cb(void * var, int32_t v);
static void card_del_cb(lv_anim_t* a);
static void right_x_move_cb(void * var, int32_t v);
void yang_game()
lv_memset_00(left_card,sizeof(left_card));
lv_memset_00(right_card,sizeof(right_card));
lv_memset_00(mid_card,sizeof(mid_card));
lv_memset_00(bottom_card,sizeof(bottom_card));
screen=lv_tileview_create(lv_scr_act());
lv_obj_set_size(screen,800,480);
lv_obj_set_style_bg_color(screen,lv_color_hex(0xcdfd8b),0);
lv_obj_clear_flag(screen, LV_OBJ_FLAG_SCROLLABLE);
for(int i=0;i<20;i++)
lv_obj_t * g=lv_img_create(screen);
lv_img_set_src(g,grass_img[rand()%2]);
lv_obj_set_pos(g,rand()%750,rand()%450);
dock=lv_img_create(screen);
lv_img_set_src(dock, &bottom_dock_img);
lv_obj_align(dock,LV_ALIGN_BOTTOM_MID,0,-5);
start_btn=lv_img_create(screen);
lv_img_set_src(start_btn, &yang_start_btn_img);
lv_obj_center(start_btn);
lv_obj_add_flag(start_btn, LV_OBJ_FLAG_CLICKABLE);
lv_obj_add_event_cb(start_btn,game_start,LV_EVENT_RELEASED,0);
int i,j;
lv_obj_del((lv_obj_t *)e->target);
for(i=0;i<left_count;i++)
left_card[i].obj=lv_img_create(screen);
left_card[i].alive=true;
left_card[i].y=i;
left_card[i].area=left;
left_card[i].layer=i;
left_card[i].img_index=rand()%card_img_type_count;
lv_img_set_src(left_card[i].obj, card_img[left_card[i].img_index]);
lv_obj_set_pos(left_card[i].obj,left_x_start,left_y_start+i*left_y_distance);
left_card[i].obj->user_data=&left_card[i].obj;
lv_obj_set_style_img_recolor(left_card[i].obj,lv_color_hex(0x000000),0);
lv_obj_set_style_img_recolor_opa(left_card[i].obj,100,0);
lv_obj_clear_flag(left_card[i].obj, LV_OBJ_FLAG_CLICKABLE);
lv_obj_add_event_cb(left_card[i].obj,clicked_cb,LV_EVENT_RELEASED,0);
for(i=0;i<right_count;i++)
right_card[i].obj=lv_img_create(screen);
right_card[i].alive=true;
right_card[i].y=i;
right_card[i].area=right;
right_card[i].layer=i;
right_card[i].img_index=rand()%card_img_type_count;
lv_img_set_src(right_card[i].obj, card_img[right_card[i].img_index]);
lv_obj_set_pos(right_card[i].obj,right_x_start,right_y_start+i*right_y_distance);
right_card[i].obj->user_data=&right_card[i].obj;
lv_obj_set_style_img_recolor(right_card[i].obj,lv_color_hex(0x000000),0);
lv_obj_set_style_img_recolor_opa(right_card[i].obj,100,0);
lv_obj_clear_flag(right_card[i].obj, LV_OBJ_FLAG_CLICKABLE);
lv_obj_add_event_cb(right_card[i].obj,clicked_cb,LV_EVENT_RELEASED,0);
for(j=0;j<max_layer;j++)
for(i=0;i<layer_row_count*layer_col_count ;i++)
mid_card[j*layer_row_count*layer_col_count+i].obj=lv_img_create(screen);
mid_card[j*layer_row_count*layer_col_count+i].alive=true;
mid_card[j*layer_row_count*layer_col_count+i].x=i%layer_row_count*2+j%2;
mid_card[j*layer_row_count*layer_col_count+i].y=i/layer_row_count*2+j%2;
mid_card[j*layer_row_count*layer_col_count+i].area=mid;
mid_card[j*layer_row_count*layer_col_count+i].layer=j;
mid_card[j*layer_row_count*layer_col_count+i].img_index=rand()%10;
lv_img_set_src(mid_card[j*layer_row_count*layer_col_count+i].obj, card_img[mid_card[j*layer_row_count*layer_col_count+i].img_index]);
lv_obj_set_pos(mid_card[j*layer_row_count*layer_col_count+i].obj,mid_x_start+mid_card[j*layer_row_count*layer_col_count+i].x*card_width/2,mid_y_start+mid_card[j*layer_row_count*layer_col_count+i].y*card_height/2);
mid_card[j*layer_row_count*layer_col_count+i].obj->user_data=&mid_card[j*layer_row_count*layer_col_count+i];
lv_obj_set_style_img_recolor(mid_card[j*layer_row_count*layer_col_count+i].obj,lv_color_hex(0x000000),0);
lv_obj_set_style_img_recolor_opa(mid_card[j*layer_row_count*layer_col_count+i].obj,0,0);
lv_obj_add_flag(mid_card[j*layer_row_count*layer_col_count+i].obj, LV_OBJ_FLAG_CLICKABLE);
lv_obj_add_event_cb(mid_card[j*layer_row_count*layer_col_count+i].obj,clicked_cb,LV_EVENT_RELEASED,0);
cover_test();
left_cover_test();
right_cover_test();
int i,j,k,m;
card_typedef * card=(card_typedef *)((lv_obj_t *)(e->target)->user_data);
card->alive=false;
cover_test();
left_cover_test();
right_cover_test();
m=find_same_card(card->img_index);
move_to_right(m);
bottom_card[m].alive=true;
bottom_card[m].obj=e->target;
bottom_card[m].img_index=card->img_index;
lv_obj_clear_flag(bottom_card[m].obj, LV_OBJ_FLAG_CLICKABLE);
lv_obj_move_foreground(bottom_card[m].obj);
lv_anim_t a1;
lv_anim_init(&a1);
lv_anim_set_var(&a1,bottom_card[m].obj);
lv_anim_set_exec_cb(&a1,x_move_cb);
lv_anim_set_time(&a1,300);
lv_anim_set_path_cb(&a1,lv_anim_path_ease_out);
lv_anim_set_values(&a1,lv_obj_get_x(bottom_card[m].obj),bottom_start_x+m*(card_width+2));
lv_anim_start(&a1);
lv_anim_t a2;
lv_anim_init(&a2);
lv_anim_set_var(&a2,bottom_card[m].obj);
lv_anim_set_exec_cb(&a2,y_move_cb);
lv_anim_set_time(&a2,300);
lv_anim_set_path_cb(&a2,lv_anim_path_ease_out);
lv_anim_set_deleted_cb(&a2,move_done_cb);
lv_anim_set_values(&a2,lv_obj_get_y(bottom_card[m].obj),bottom_start_y);
lv_anim_start(&a2);
del_same_card();
move_to_left();
int i,j;
for(i=0;i<layer_row_count*layer_col_count*(max_layer);i++)
if(mid_card[i].alive==true)
for(j=i+1;j<layer_row_count*layer_col_count*max_layer;j++)
if(mid_card[j].alive==true&&mid_card[j].layer>mid_card[i].layer)
if((mid_card[j].x- mid_card[i].x)<2&&(mid_card[i].x- mid_card[j].x)<2&&(mid_card[j].y- mid_card[i].y)<2&&(mid_card[i].y- mid_card[j].y)<2)
lv_obj_set_style_img_recolor_opa(mid_card[i].obj,100,0);
lv_obj_clear_flag(mid_card[i].obj, LV_OBJ_FLAG_CLICKABLE);break;
lv_obj_set_style_img_recolor_opa(mid_card[i].obj,0,0);
lv_obj_add_flag(mid_card[i].obj, LV_OBJ_FLAG_CLICKABLE);
if(mid_card[layer_row_count*layer_col_count*max_layer-1].alive==true)lv_obj_add_flag(mid_card[layer_row_count*layer_col_count*max_layer-1].obj, LV_OBJ_FLAG_CLICKABLE);
int i;
for(i=left_count-1;i>=0;i--)
if(left_card[i].alive==true)
lv_obj_set_style_img_recolor_opa(left_card[i].obj,0,0);
lv_obj_add_flag(left_card[i].obj, LV_OBJ_FLAG_CLICKABLE);
return;
int i;
for(i=right_count-1;i>=0;i--)
if(right_card[i].alive==true)
lv_obj_set_style_img_recolor_opa(right_card[i].obj,0,0);
lv_obj_add_flag(right_card[i].obj, LV_OBJ_FLAG_CLICKABLE);
return;
int i;
for(i=6;i>index;i--)
bottom_card[i].alive=bottom_card[i-1].alive;
bottom_card[i].img_index=bottom_card[i-1].img_index;
bottom_card[i].obj=bottom_card[i-1].obj;
bottom_card[i-1].alive=false;
if(bottom_card[i].alive==true)
lv_anim_t a1;
lv_anim_init(&a1);
lv_anim_set_var(&a1,bottom_card[i].obj);
lv_anim_set_exec_cb(&a1,right_x_move_cb);
lv_anim_set_time(&a1,200);
lv_anim_set_values(&a1,bottom_start_x+(i-1)*(card_width+2),bottom_start_x+(i)*(card_width+2));
lv_anim_start(&a1);
int i,j;
for(j=0;j<6;j++)
if(bottom_card[j].alive==false)
for(i=j+1;i<7;i++)
bottom_card[j].alive=bottom_card[i].alive;
bottom_card[j].img_index=bottom_card[i].img_index;
bottom_card[j].obj=bottom_card[i].obj;
bottom_card[i].alive=false;
lv_anim_t a1;
lv_anim_init(&a1);
lv_anim_set_var(&a1,bottom_card[j].obj);
lv_anim_set_delay(&a1,500);
lv_anim_set_values(&a1,bottom_start_x+(i)*(card_width+2),bottom_start_x+(j)*(card_width+2));
lv_anim_start(&a1);
break;
int i,j,k;
for(i=5;i>=0;i--)
if(bottom_card[i].alive&&bottom_card[i].img_index==img_index)
return i+1;
for(i=5;i>=0;i--)
if(bottom_card[i].alive)
return i+1;
return 0;
int i,j,k;
for(i=0;i<7;i++)
for(j=i+1;j<7;j++)
if(bottom_card[j].alive==true&&bottom_card[i].img_index==bottom_card[j].img_index)
for(k=j+1;k<7;k++)
if(bottom_card[k].alive==true&&bottom_card[j].img_index==bottom_card[k].img_index)
bottom_card[j].alive=false;
bottom_card[k].alive=false;
lv_anim_t a1;
lv_anim_init(&a1);
lv_anim_set_exec_cb(&a1,card_anim_cb);
lv_anim_set_delay(&a1,300);
lv_anim_set_deleted_cb(&a1,card_del_cb);
lv_anim_set_values(&a1,256,1);
lv_anim_start(&a1);
lv_anim_init(&a1);
lv_anim_start(&a1);
lv_anim_init(&a1);
lv_anim_set_var(&a1,bottom_card[k].obj);
lv_anim_start(&a1);
lv_img_set_zoom(var,v);
lv_obj_set_style_img_opa(var,v-1,0);
lv_obj_del(a->var);
lv_obj_t * xxx=(lv_obj_t *)var;
lv_obj_set_x(xxx,v);
lv_obj_set_y(xxx,v);
if(bottom_card[6].alive==true){game_over();}
lv_anim_del_all();
lv_obj_del(screen);
yang_game();
}复制代码
